C63 AMG (W204) 2008 - 2015
Water Dripping On My Feet!
Old Sep 1, 2020 | 04:07 PM
Bonesxxx's Avatar
2016 GTs, 2014 C63 AMG and 2014 C350 Sport (wife's car, she thinks it's an AMG - shhhhhh)
Hey folks,
Got a strange one for you. Car sat outside for a day in the rain because we had carpet installers using the garage. My car is garage kept and rarely driven in the rain.
Anywho... I jumped in it yesterday to run an errand before putting it back and was getting cold water drips on my feet (which normally I would not have felt but I was also wearing flip-flops). I can't see any obvious source but I'm guessing a windshield seal? Anything else I could check?
Thanks,
Old Sep 1, 2020 | 04:18 PM
doncmleon's Avatar
2012 C63
Originally Posted by Bonesxxx
Hey folks,
Thanks,
If you have a moisture meter, that would help A LOT! If you have kids or pets (I have both lol) these things are a life saver.
https://www.amazon.com/General-Tools-MMD4E-Moisture-High-Medium-Low/dp/B00275F5O2/ref=asc_df_B00275F5O2/?tag=hyprod-20&linkCode=df0&hvadid=309823018507&hvpos=&hvnetw=g&hvrand=3029601906475087877&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9028244&hvtargid=pla-486293511837&psc=1&tag=&ref=&adgrpid=60862048799&hvpone=&hvptwo=&hvadid=309823018507&hvpos=&hvnetw=g&hvrand=3029601906475087877&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9028244&hvtargid=pla-486293511837 https://www.amazon.com/General-Tools-MMD4E-Moisture-High-Medium-Low/dp/B00275F5O2/ref=asc_df_B00275F5O2/?tag=hyprod-20&linkCode=df0&hvadid=309823018507&hvpos=&hvnetw=g&hvrand=3029601906475087877&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9028244&hvtargid=pla-486293511837&psc=1&tag=&ref=&adgrpid=60862048799&hvpone=&hvptwo=&hvadid=309823018507&hvpos=&hvnetw=g&hvrand=3029601906475087877&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9028244&hvtargid=pla-486293511837
If not, you may end up having to recreate the ordeal with a garden hose and work your way up.
Old Sep 1, 2020 | 04:29 PM
Bonesxxx's Avatar
As luck would have it, I happen to have one of those.
Problem is it seems to be dripping down from the area of the hood release. I don't know that a moisture meter helps much once you cross the divide from carpet to hard surface, does it? I'm thinking it's got to be visual.
Old Sep 1, 2020 | 04:32 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Not sure if it applies to the C63 but a lot of cars have the sunroof drains come down the A pillar and sometimes the plastic line splits or has a joint that comes undone in that area.
Could also be a leaky windshield - has it ever been replaced?
Old Sep 1, 2020 | 04:46 PM
doncmleon's Avatar
2012 C63
Rob has a point....it could be the drain...Using the meter and going into the softer materials (pillar/headliner areas) could rule out that area.
Old Sep 1, 2020 | 05:12 PM
Bonesxxx's Avatar
Not that I am aware of. I'll give it a good inspection tonight and see how the seal looks. Thank you.
Old Sep 1, 2020 | 06:40 PM
QuartzBlueP31's Avatar
2010 C63 P31
Take the A pillar trim off and check the Sun Roof drain line. They tend to slip and kink then the water travels in to the dash area and makes a mess.
Had this happen on the Wife's X5
Old Sep 2, 2020 | 12:16 PM
mcderpa's Avatar
09 C63 AMG
I had similar issues while going through a car wash. I used some 14GA wire out of some ROMEX (so I could mold and form it to make the bends in the drain hose) and a small-nozzle adapter on my air compressor to "break up" and blow out the blockage in my sunroof drains. Pull the A-Pillar and check for any breaks first to make sure you're not just making things worse.
