Is my manifold cracked?
AMG
So after doing a oil change i noticed this crack where the fuel rail bolts, there are no CEL or whine... I do hear a psssss (vaccum sound) while car is idling around the front of manifold..
also how can I check if the gaskets are bad? I just got this 09 with 60k on it
thanks
thanks
AMG
I did sprayed some carb cleaner but idle didnt change at all, maybe a lil but not noticeable.
Theres a sort of struggle around 2k rpm when im light on throttle.
I dont want to take off the manifold and find that is good.
That crack isn't going all the way though yet. I would try to relive the stress/tension a little by loosening the bolt and adding some spring washers.
Received 2,836 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
That looks just like the crack on the R63 manifold from a few years back. It will only get worse. Better to repair it correctly now and get it over with before it causes a problem or becomes unrepairable and ends up costing big $.
doncmleon (09-04-2020)
AMG
AMG
anyway Today I sprayed more carb cleaner on the front part of the manifold under the engine cover and the car started to stall when I sprayed..
Start calling around locally for anyone who can weld magnesium. It’s a fairly specialized skill but it should be cheap. Your manifold doesn’t need rebuilding, but while it’s off you may as well check the throttle plate to make sure it’s not corroded.
doncmleon (09-06-2020)
AMG
I will take the manifold apart and check on the throttle plate.. Does that need to be taken apart or just looking the underside of the manifold will show the plate
