Transmission Rebuild
#102
Received 2,842 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
#103
Nice. On a hot day I was seeing it peak at 115°C. Will see how it is with the Weistec trans pan. I'd like to think with the cooling fins and extra capacity it should be good for a couple degrees.
#104
Don't get your hopes up. I’ve had mine on since 2016 and still killed my trans.
#105
With the track abuse you do to the car... you might as well consider this:
https://southernhotrod.com/shr-war-viking-722-9/
Way more throughly done. And, you’ll have a piece of mind.
#107
SPONSOR
2007 Mercedes E63 AMG
I agree...adding capacity and fins really doesn't do anything for actual racing. it'll help for short bursts but in actual usage, you need a full on external cooler to manage temps.
BLKROKT (03-28-2021)
#108
Agree. After this past weekend I’m reevaluating everything. Aux cooler parts are on order, I need it now.
hachiroku (02-23-2021)
#109
#110
Thank.you
#112
#113
#114
Well, finally got motivated to dig into the car again.
My track day at Big Willow last month was a little disappointing. Didn’t have my suspension sorted, totally misaligned with ride height all wrong too. Without rear aero (sold that ugly but effective RENNtech wing) the car isn’t nearly as good around a track like that with a bunch of high speed turns. And also had a catastrophic electrical failure which I haven’t started figuring out yet (cooked alternator most likely). To add insult to injury, the trans is still getting too hot and shifting poorly even after the full rebuild. Will have to tear it down again to look at the valve body solenoids as the next possible problem area and redo the adaptations and just generally check things over again. No slipping at least, just slow shifting and lockouts after 20min or so. So I took a little break to get my head clear on things.
Started tearing the car apart this week to knock off a bunch of things on my huge to-do list which just keeps growing. Priority #1 is to fit an aux trans cooler to combat my heat issues. Cleared out space in the drivers side front by removing horns, smog pump and windshield washer reservoir. Look at all that space, it’s beautiful. Going in will be the Mocal 34 row oil cooler (9”x10”x2” core - same size as the BS aux oil cooler on the other side) and Mocal gear pump I ordered, to be controlled by a 200F temp switch and connected with AN lines (-8 AN fittings on everything including the Weistec trans pan). No more fuking around on this thing, I’m pissed now.
The following 6 users liked this post by BLKROKT:
chrisridebike8 (03-28-2021),
Diabolis (03-29-2021),
Kriston (03-31-2021),
mcderpa (03-28-2021),
mthis (03-28-2021),
and 1 others liked this post.
#115
The price of a new-from-the-dealer transmission for the pfl is $3146. To this there would be an additional core charge, but you ship your transmission core in, via freight.
The price I am seeing for this at an online dealer, does not include the shipping to my location, because I'm too lazy to add the item to the basket and see how much they would charge for that.
If I had transmission problems at my level of car usage, I would probably take this route.
My experience with transmission shops was (with other, more simple gearboxes), that they tend to get things wrong on assembly, or do an incomplete clean-up job etc. I had a relatively simple 5 speed gearbox in my Subaru, which was guaranteed to implode, once I reached 320 ftlb going through it. I did and 3rd gear went. Transmission shop did an incomplete cleanup, the car ran with the rebuilt transmission for 6 months, then a piece of debris came out of ....where ever it jammed itself and a second rebuild was then needed, this time by the dealer. Third time, I bought a brand-new-from-the-dealer gearbox, the 6-speed model, with no particular torque limitation.
Oh, do you want to know the price for a black series transmission?
hm...lets see
$5027. But here, the core sent in could be a problem. But I would not let this obstacle stop me.
If I wanted a black series transmission in my car (well mine can't accommodate one, but let's just say)
I would contact the online dealer and I would plead my case. Both the online dealer Aaaaaand Mercedes are on the side of wanting to make a profit and wanting to sell you the transmission. If the dismantling boys in Affalterbach have to work a little harder when taking parts out of your transmission and puting them into ... different part trays than they would if your core was a true black seris transmission core.. then let that happen. They ... do.. get.. a salary to do this after all..
hm...lets see
#116
Received 3,995 Likes
2017 GLE350 4MATIC
Great thread. Thanks to all contributors and looking forward to @BLKROKT next update with the cooler.
#117
First cooler duct/shroud mock up out of cardboard done. Will repeat on other side, and make out of riveted aluminum sheet with duct tape and neoprene weatherstripping to seal any gaps. Need to make sure air is getting forced in, and what I had there before was hacked up to death. I’m going to integrate my brake ducts into these because being attached to the bumper grill is a real pain to get in place as I have to remove the front bumper frequently. Feels good to make progress.
The following 7 users liked this post by BLKROKT:
chassis (03-28-2021),
Dr.Speedfellow (03-30-2021),
DRBC43AMG (03-31-2021),
mcderpa (03-29-2021),
and 2 others liked this post.
BLKROKT (03-29-2021)
#119
Unrelated, but APR carbon hood vents arrived today. Pretty.
#120
Some of us don’t need little hood louvers for downforce buddy
#122
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
Big functional louvers do have a possible downside... if your engine blows up and/or pukes up the oil, most of it ends up on your windshield which does affect your vision. On the other hand, based on whether there are metal chunks in the mess and whether the wipers clear the fluid or just smear it, you'll have a pretty good idea of what it is even before you get towed back to the pits and open the hood...
BLKROKT (03-31-2021)
#123
They also pull more air through them as well.
That's assuming I have my eyes open if the engine grenades
#125
Time to stop screwing around with carbon fiber. I have to learn how to hook all this stuff up. Cooler, pump, hoses, temp switch, wires, fluid, etc. It’ll all be ok...
I imagine it’ll sit right about here. At least I got the core size perfect.
If anyone has any experience doing something like this, please comment, I’m all ears.
Some unexpected good news - getting rid of all that stuff gave me a new side access point to the engine block. I think I might just be able to fish that dumb SAI pipe out over the headers without totally removing the power steering pump. Bonus.
The following 5 users liked this post by BLKROKT:
chassis (04-17-2021),
chrisridebike8 (04-17-2021),
Diabolis (04-17-2021),
DRBC43AMG (04-17-2021),
Phil_T (04-18-2021)
