C63 AMG (W204) 2008 - 2015
Is this the finned diff cover?
Old Oct 13, 2020 | 12:00 AM
aguita's Avatar
AMG
Hello, so I have this 09 Euro model P30 and wondering if this is the diff cover everyone talks about (not available on usa model?) is this the same as the BS?
will this be good for track days?
Old Oct 13, 2020 | 12:06 AM
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
That's the C63 diff cover that standard on PP Aussie models.
As for the black series I thought they had an active diff cooler with external oil cooler.
Old Oct 13, 2020 | 12:09 AM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Yes, that’s the ‘rectifier’. It makes little difference.
Cwagon is talking about the optional “Track Pack” for the BS which comes with active diff cooling among other things.
Old Oct 13, 2020 | 08:32 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Originally Posted by BLKROKT
Yes, that’s the ‘rectifier’. It makes little difference..
Have you tested this before/after or know someone who has? This was on my list for the off season but I didn't record any diff temps. I figured better than nothing but if it's pointless to swap I won't bother.
Old Oct 13, 2020 | 10:47 AM
BLKROKT's Avatar
I didn’t take measurements. But Wobble64 was puking diff oil on track before installing the rectifier, and it lessened after.
Old Oct 13, 2020 | 11:59 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Found the thread thanks https://mbworld.org/forums/c63-amg-w...l-cooling.html
Old Oct 13, 2020 | 06:27 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
For serious track duty you'd probably want an active diff cooling solution of some sort. I am sure the casing with the fins helps somewhat, but it is not going to be enough if you're going to be torturing the LSD unless your clutch packs are completely worn out. The finned "rectifier" may be sufficient for an aftermarket gear-based diff (Torsen or helical) as these generally don't produce as much heat.
Old Oct 14, 2020 | 12:29 PM
Duffer4126's Avatar
2015 Mercedes C63 amg 507
Yep... just got one installed on the 507 when the new diff was installed at 30k miles...
Old OEM vs New finned cover...
