C63 AMG (W204) 2008 - 2015
Drag Radials - Lowered Suspension
Old Dec 7, 2020 | 02:48 PM
Cammer88's Avatar
E63s
Good morning Gents,
First off I've searched threads dating back to 2010, but I'm hoping experienced members can chime in with relevant first hand experience.
This up coming spring I plan on tracking my car and have picked up a set of 275/40/17 MT ET Streets, to be mounted on 17" OEM wheels. Having said that I do also want to lower it, and have a set of H&R Springs w/ new 17mm pads.
Has anyone ran this set up (I'm sure they have), did it rub? I know the H&R's won't help at the drag strip but this is a daily driver with the odd run down the track.
Would love to hear peoples input and suggestions.
Old Dec 7, 2020 | 09:44 PM
eschow's Avatar
W204 C63
I'm on H&R springs, with -2.5deg camber in the rear. Tire is a 275/40/17 ET Street R. Wheel is a 17x9 +48 Enkei PF01. Had to shave the rear pad tabs down, but no rubbing.
This was a 17x9.5 +52 Motegi wheel, with 275/40/17 NT05R's.
You'll need to know the width and offset of the 17" wheel you want to go with, in order to gauge how much it'll poke out
Old Dec 8, 2020 | 07:34 PM
thebug44's Avatar
2012 P31 C63
did you have to shave down rear pads with that motegi wheel setup?
Old Dec 8, 2020 | 08:24 PM
eschow's Avatar
W204 C63
Yeah. I'm pretty sure all 17's will require you to shave down the pad tabs
Old Dec 8, 2020 | 10:02 PM
mthis's Avatar
Anything W/4Wheels
If you got to shave the pads mine as well go for 16s you save a lot of weight over stock wheels 27lbs each side. the other pictures with 18s are to get a idea how low my car is and super stiff and still cuts a 1.60 60 foot with 225 wide tire.
Old Dec 8, 2020 | 10:06 PM
eschow's Avatar
W204 C63
What Mercedes wheel is that?
Old Dec 8, 2020 | 10:09 PM
mthis's Avatar
Anything W/4Wheels
old clk320
Old Dec 8, 2020 | 10:11 PM
eschow's Avatar
W204 C63
old clk320
Thanks. Are you running 225/50/16?
Old Dec 8, 2020 | 10:13 PM
mthis's Avatar
Anything W/4Wheels
yes
Old Dec 9, 2020 | 03:46 PM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
Not true I have 17 tsw Bathurst drag setup no shaving fits perfect
Old Dec 13, 2020 | 02:10 AM
Phil1305's Avatar
C63
no my 17x9 weld wheels fit perfectly with no mods
this is also stock height with 275/40/17 hoosiers
Old Dec 13, 2020 | 02:24 PM
DARRYL D's Avatar
2014 C63 AMG 507 Edition
love the setup! The welds look on point 👌
any more pictures?!? Do you think you’d rub if you were lowered on H&Rs?
Subbed! This thread is exactly what I was looking for! I’m lowered on H&R springs with the thicker 17mm pads in the rear.
looking for information on a rear setup. 17s with 275/40/17 with MT street ss is what I was leaning towards but not sure if I’d rub being lowered on springs.
Old Dec 13, 2020 | 04:10 PM
AMGonFire's Avatar
here you go 17s 275/40/17 mt ss I’m not lowered though seems like enough room though
Old Dec 14, 2020 | 01:59 AM
yfz rock's Avatar
2011 raptor 2010 C63 AMG P31
how can someone buy these any other styles?
Old Dec 14, 2020 | 11:01 AM
Cammer88's Avatar
E63s
https://www.weldwheels.com/street-strip-wheels
Old Dec 14, 2020 | 12:52 PM
Phil1305's Avatar
C63
You need to have them custom redrilled thought. They don't make our bolt pattern
Old Dec 15, 2020 | 07:52 PM
KXC's Avatar
KXC
C63
16”s can fit factory brake set up with shaving the pads ?
Old Dec 16, 2020 | 04:47 PM
mthis's Avatar
Anything W/4Wheels
yes
Old Dec 16, 2020 | 09:11 PM
KXC's Avatar
KXC
C63
Not trying to steer the thread off course too far but what wheels can I look for in 16” ? I can’t seem to find much.
Also, what exactly needs to be shaved for 16s to fit? Looks like the silver pieces on the outside of the pad, anyone know what they are even for ?
Old Dec 17, 2020 | 01:56 PM
mthis's Avatar
Anything W/4Wheels
a sawzall with metal blade works best
i only know of the 16s from old clks that work.
Old Dec 17, 2020 | 10:42 PM
KXC's Avatar
KXC
C63
Thanks for the info. Why are the tabs there ? Some type of heat sink ?
Old Dec 17, 2020 | 11:53 PM
mthis's Avatar
Anything W/4Wheels
honestly i dont know but my guess would be to pull them out easier when your changing them.
Old Dec 21, 2020 | 01:02 PM
elementsk8erq's Avatar
Evo IX, 2001 E55 AMG, 2004 E55 AMG, 2012 P31 C63 AMG, 2005 S2000
Its most likely there to cancel out vibrations that a huge brake pad may be subject to.
Old Dec 22, 2020 | 12:58 AM
Mort's Avatar
I figured the tabs are there to dampen vibrations and reduce low pressure squeal that seems to be a problem with semi-metallic brake pads.
Old Apr 26, 2022 | 11:53 AM
Cammer88's Avatar
E63s
Ended up going with Hoosier DR2’s in 245/40/18 mounted on Konig Hypergrams 18x8.5 +43
