W204 C63 - Tire Profile on Stock 18 Rims
Subscribe
Dec 15, 2020 | 01:23 PM
I did some searching about tire profile sizes in the forum but most of the discussions were about fitting wider tires on the stock 18 rims.
I was wondering if anyone on the forum has increased the side profile size on these.
I love my W204 but the ride is a bit punishing sometimes as the asphalt in Brazil is kind of ****ty. Making it ride a little higher could also benefit me on some driveway entrances.
Would it be too sacrilegious from a performance standpoint to move from 265/35r18 rears to 265/40r18?
Reply 0
Dec 15, 2020 | 04:05 PM
On the rear you can run 265/40x18 if running stock suspension.
I recently fitted w205 c63s wheels to my C63 estate with std suspension and the rears (9.5"x19 ET52 with 4mm spacer)came with 265/35x19 over std 255/30x19 and they fit with no scrubbing.
my old setup was 275/35x18 on E400 9" rears (same et54 as C63 wheels)
Old set up with 275/35x18
Reply 0
Dec 15, 2020 | 09:48 PM
@Cwagon Why do you need a 4 mm spacer in the rear? Does it rub the strut without it?
Reply 0
Dec 15, 2020 | 10:28 PM
Quote: @Cwagon Why do you need a 4 mm spacer in the rear? Does it rub the strut without it?
No I was using the 4mm spacer with my old 18x9" ET54 to give an ET50 for a more flush with the guards look instead of tucked under.
If you wanted to get technical I had effectively widened the track by 8mm (2x4mm).
On the front I ran a 10mm spacer with longer bolts on 235/40x18 x 8.5" ET48 rim for a ET38 again with no rubbing.
As my C63s W205 rear rims are 19x9.5" ET56 I just decided to use the 4 mm spacer again for ET52
My current front rims are 19x8.5" ET38 std with 245/35x18 tire.
Reply 0
Dec 16, 2020 | 08:16 AM
Thanks for the feedback! I'm on stock suspension so I think 265/40r18 should fit on the back on problem.
I understand that it might affect performance and speedo reading, but might improve the ride a little bit.
My car is currently running 225/40r18 in the front and 265/35r18 in the back. They're Toyo T1Rs and I think they're VERY stiff. Might be because of their age.
I'm going to go ahead and try swapping to 235/40r18 in the front and 265/40r18 in the back.
Reply 0
Dec 16, 2020 | 02:48 PM
Quote: I'm going to go ahead and try swapping to 235/40r18 in the front and 265/40r18 in the back.
That combo should work fine and run 36psi F&R for a good comprimise between ride and handling.
Reply 0
Dec 16, 2020 | 05:06 PM
Quote: No I was using the 4mm spacer with my old 18x9" ET54 to give an ET50 for a more flush with the guards look instead of tucked under.
Thanks for the response. Those w205 wheels look and fit well on the w204.
Reply 0
Dec 22, 2020 | 02:35 PM
I was checking my tires today and saw that I have 225/40/18s on the front and 265/35r18s on the back.
The front tires are a bit smaller than the OEM size (235/40) and the back ones are wider than stock (255/35).
Do you think I'd get a decent increase in ride height/ground clearance if I went with 245/40r18s on the front and 275/35r18s on the back?
I'm not going up in sidewall height, but the wider tires (by 20mm in the front an 10mm in the back) should be taller, right?
Reply 0
Explore
Dec 23, 2020 | 01:30 AM
Both the 245/40x18 and 275/35x18 are a good choice and should fit the std wheels fine.
Just check how much tire clearance you have on front to the strut.
On the rear the 275/35x18 will fit the std 9" rim and will be slightly wider and a tiny bit taller.
Reply 0
Subscribe
Currently Active Users (1)
