C63 AMG (W204) 2008 - 2015
What did you do to your C63 today?
Old Mar 5, 2023 | 09:13 AM
  #226
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Originally Posted by sickSVT
Relocated my power steering tank with a nice billet tank.
What tank is that? Does it have a replaceable filter?
Old Mar 5, 2023 | 09:15 AM
  #227
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Nice, that looks clean. Is it higher capacity? What tank and fittings did you use? Did the OE hoses stretch to the new location ok? Did you flush/fill when you did this? And last question, does the new tank have a filter, is it replaceable, or did you install one in-line?
Old Mar 5, 2023 | 09:16 AM
  #228
BLKROKT's Avatar
LOL Jason jinx!
Old Mar 5, 2023 | 11:44 AM
  #229
sickSVT's Avatar
Top Answer: 1
3.0L Whipple E63 AMG
It's a MAP power steering tank, it was made for the EVO but works great for any setup.
Stock hoses slid on perfectly, I just need to get some nice hose clamps for them.
It does come with a screen filter, and sight glass for easy view of fluid levels.
https://www.maperformance.com/produc...liart-evox-psr
Old Mar 5, 2023 | 04:12 PM
  #230
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I'm not sure I would trust only having a screen filter in this system.
Old Mar 5, 2023 | 05:24 PM
  #231
sickSVT's Avatar
Top Answer: 1
Do factory reservoirs have filters in them? Either way I consider this an upgrade, had to relocate the power steering with the supercharger upgrade.
Old Mar 6, 2023 | 03:45 AM
  #232
GRP's Avatar
GRP
2010 C63 and 2018 GLC63s
OEM has an inbuilt filter within the reservoir (non-replaceable)
Old Mar 6, 2023 | 08:49 AM
  #233
BLKROKT's Avatar
Yeah I agree, no way a screen filter is enough bud. That OEM filter - and the fluid if you don’t change it enough - gets BLACK. It needs heavy duty filtering, I don’t know why. I’d look for another solution sorry.
Old Mar 6, 2023 | 09:32 AM
  #234
sickSVT's Avatar
Top Answer: 1
Looks like the factory reservoir uses a tiny screen filter, I should be good!
Old Mar 6, 2023 | 11:44 AM
  #235
BLKROKT's Avatar
Interesting, I thought I remembered the filter being more robust. So that’s similar to the one in your billet tank?
Also… it looks like the new tank fluid capacity is 375ml. I believe the OE reservoir holds 800ml. That’s a problem. Maybe I’m wrong, but guys like me and Jason who boil power steering fluid on track are looking for more fluid capacity, not less. Just a data point, if it’s working for you great.
Old Mar 6, 2023 | 12:23 PM
  #236
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
From what I remember it's a multi layer screen filter that filters small particles. Is the screen filter in the billet tank only for larger chunks? It was hard to see from the pics on the website.
Old Mar 7, 2023 | 02:30 AM
  #237
Phil_T's Avatar
C63 AMG Saloon
Finally dialled in all the suspension at 1 finger gap ride height to work with 255 front & 275 rears. I had to get Renntech adjustable rear toe arms & k mac rear adjustable camber arms, then added a kw helper spring & a shorter main spring to the kw clubsports. I am glad after all the work I was able to get the ride height I wanted with full travel & good handling after a full geo.
Old Mar 7, 2023 | 07:03 AM
  #238
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
SEE SPOILER (All part of a TOTAL SYSTEM)
Spoiler
AUDI to VOLVO - K-MAC The Experience Of Resolving OEM Suspension Shortcomings Since 1964 !
Old Mar 8, 2023 | 12:42 AM
  #239
K-Mac's Avatar
SPONSOR
Yes, as well - we do have for earlier W204 C63 A TOTAL SYSTEM !
Including all the very latest design updates providing the biggest, quickest, strongest adjustment breakthroughs.
See Spoiler
Spoiler
Old Mar 8, 2023 | 11:09 AM
  #240
Sparft78's Avatar
AMG
Changed the oil..
Old Mar 8, 2023 | 04:29 PM
  #241
Gene Gorman's Avatar
05 SL55, 10 C63, 12 SLK3, 20 S560, 08Bentley GT Speed, 16 Aston Martin Vanquish
Installed the latest (2019) navigation discs. It worked perfectly, just make sure you have your battery at full charge. I kept mine plugged into the battery tender. Make sure that you turn off anything that could be using any power. EG, lights, ac blower, radio. Now the street we live on is on the map. It takes about two and a half hours to install both disks.
Old Mar 9, 2023 | 10:53 AM
  #242
blay127's Avatar
W204
not really on the C63, but its for the C63. Installed a two post lift
Old Mar 9, 2023 | 10:24 PM
  #243
sickSVT's Avatar
Top Answer: 1
Well... Tried to install my $600 Weistec Heat Exchanger and the oil cooler brackets have horrible fitment.
Talk about paying for premium quality. lol
Old Mar 11, 2023 | 12:13 PM
  #244
sickSVT's Avatar
Top Answer: 1
Mounted the Weistec heat exchanger and got my trunk tank kit.
Old Mar 11, 2023 | 02:06 PM
  #245
sickSVT's Avatar
Top Answer: 1
The OEM reservoir uses a very small screen filter, also after cutting up the stock reservoir I can confirm my billet tank holds a bit more fluid than the stock reservoir.
Old Mar 11, 2023 | 02:42 PM
  #246
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Nice! How fine is the screen filter on the billet tank? Comparable to OEM you think?
Old Mar 11, 2023 | 02:59 PM
  #247
sickSVT's Avatar
Top Answer: 1
They're about the same as fine, but the billet tank feels more durable. The OEM screen is very thin and tore easily when I ran a flat head screw driver through it.
Old Mar 11, 2023 | 07:28 PM
  #248
BLKROKT's Avatar
Awesome thanks for doing that work. I’ll probably order one and do the same.
Old Mar 12, 2023 | 09:54 AM
  #249
W205C43PFL's Avatar
Posting here because the video is actually about the W204 C 63 (basically his video was clickbait but in a good way I guess?):
Old Mar 12, 2023 | 10:45 AM
  #250
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Sweet upgrade! It blows my mind there's no service interval on the PS fluid.
