What did you do to your C63 today?
#301
Took it out for a test drive, it's been raining for the last week so haven't been able to data log much for some WOT runs.
The following 6 users liked this post by sickSVT:
blay127 (05-13-2023),
Chemical7 (09-16-2023),
Cwagon (05-14-2023),
duuder (05-13-2023),
Fernando2007 (05-13-2023),
and 1 others liked this post.
#302
Got my Blackboost Thermostat, very high quality machined piece. Going to be running this in the summer to help keep the engine and oil temps cooler now that I'm supercharged.
sickSVT (05-28-2023)
#304
Took it out today for some data logging and snapped some quick pics.
The following 8 users liked this post by sickSVT:
Bahnstormer (05-29-2023),
duuder (07-10-2023),
Elemento Tuning (07-12-2023),
eurosdn (08-29-2023),
INS1GNIA (05-28-2023),
and 3 others liked this post.
#307
Had my TE37 SL's re-powder coated, curb rash repaired, replaced the old peeling AMG stickers with Volks OG stickers since I like the look more than the SL versions, replaced air valve caps with Rays caps, and added centercaps. Some before and after pics. Also the old tires were replaced with a set of Falken Azenis FK510's.
Also been chasing down a P0171 cel code for a few weeks, opened up the airboxes to clean to the mafs and discovered the passenger side airbox screws can't torque down from the plastic screw holes being stripped and one screw was missing. Ordered a used right side box today, hopefully it resolves the issue.
The following 5 users liked this post by DarkMirror:
BLKROKT (07-11-2023),
lo-fi (07-10-2023),
thesaintusa (07-12-2023),
Thrilla (11-01-2023)
#308
Received 2,827 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
TE37’s look great on ANY car. Love it.
The following 3 users liked this post by BLKROKT:
eurosdn (08-31-2023)
#310
Had all fluids changed, diff, oil and SC coolant. New injectors to avoid hydrolocking, new 1 step colder plugs (standard for the SC) and then I hand washed it.
Hand washing it knocked .2 off my 1/4 mi time. 😏
AMGSPY (07-12-2023)
BLKROKT (07-13-2023)
#312
Finally was able to do a WOT pull and some street driving with new tuning setup by V-Tech Georgia.
The following 3 users liked this post by sickSVT:
#313
In actually did this a while ago, but in case anyone has a lowered C63, make sure to use the shorter Whiteline sway bar links to fit to the new ride height. Previous owner put cheap links and for some reasons forgot to reinstall the sway bar bracket bolts (which I bought from the dealership for 134 sick i posted in another thread) on one side. Now that the front is nice and quiet I noticed the rear links also clunk lol. Those I will be repairing soon.
Also if the recessed torx is rusted or stripped when removing the old link you can use a plier clamp over the rubber bushing to hold the bolt still while loosening the nut.
Also the replacement passenger side airbox I installed solved the P0171 cel for bank 1 lean condition I was having. Turns out loose screws on the airbox really do cause issues.
#314
Can't believe I'm excited over a free sticker. Removed the ugly Daimler scribble one, eyeballed the Private Lounge hologram in.
Also used some water spot remover on my hood, fenders, and trunk, then my arms got tired.
#316
2008 C63 ///AMG
#317
My tint is 35%, the safety inspections laws for tint became more stringent recently and I had to remove my 20% tint to the current 35% to get my safety and registration up to date.
#318
Installed some custom 3.5" intakes on my VRP supercharger kit.
Should definitely pick up some horsepower and lower IAT's!
Bahnstormer (09-15-2023),
Cwagon (09-15-2023),
DarkMirror (09-15-2023),
QuartzBlueP31 (09-18-2023),
#320
I've done a test on a turbo car with screen off and screen on thr dyno and difference was 40whp
sickSVT (09-16-2023)
#323
Installed a custom 8" OEM style Android HU and designed some custom AMG gauges to log my Supercharger IAT's, Engine Coolant Temp, Trans Temp, Oil Temp, Fuel Pressure, Voltage and Timing.
This should be a much more seamless setup than hooking up my laptop and HP tuners for data logging.
WidowrRacing (10-19-2023)
#324
What app are you running to display and what device are you using to grab the data?
Also, if you figure out the PID for Engine Oil Temp let me know lol
#325
Love the setup tho, looks very similar to the AMG Performance Media option.
