C63 AMG (W204) 2008 - 2015
Oil leak infront of the car!!!
Old Mar 6, 2021 | 02:17 PM
kevin song34's Avatar
2012 c63 amg
I have a 2012 c63 and past couple days the car was driving good with no issues. Yesterday I noticed oil on the ground standing infront of the car so means you can see the oil leaking without looking under the car. I checked engine oil levels and power steering and it was fine I took it to the mechanic to check and he said that it is the transmission oil cooler leaking because the leak is located right behind the front bumper. I was wondering if any of you guys can help me out and let me know what I can do before I spend money unnecessarily
Old Mar 6, 2021 | 04:03 PM
See63Run's Avatar
2013 C63 (W204)
What side of the car?
the oil cooler is on the passenger side behind the front bumper
Old Mar 6, 2021 | 07:19 PM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
Well transmission fluid is generally red. Should be easy to tell what type of liquid it is I would imagine.
Old Mar 6, 2021 | 08:13 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Would be blue in a 2012
Old Mar 6, 2021 | 08:20 PM
G_Money's Avatar
**** really? Learn something every day! Thanks for the tip big dog!
Old Mar 6, 2021 | 08:41 PM
See63Run's Avatar
2013 C63 (W204)
Trans - blue
coolant - blue
power steering - clear/amber
brakes - clear/amber
oil - amber/brown/black
Old Mar 6, 2021 | 10:16 PM
The Machinist's Avatar
11’ C63 AMG; D2 Audi A8; 15’ Golf TDi; 97’ F350PSD; B6 Audi S4; D1 Audi V8; A2 VW GTi
If it’s had a recent trans fluid change and had the updated fluid, the trans fluid could be the new gold color too.
Old Mar 7, 2021 | 08:32 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Is it a new spec for the MCT? Or just the Mercedes fluid changed colour?
The Pentosin and Fuchs from https://bevo.mercedes-benz.com/bevol...236.15_en.html all still say they're blue.
Old Mar 7, 2021 | 09:21 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
i did mine 6 months ago and the stuff the dealer sold my based off my VIN for my 2014 was still blue, just needed a top up after changing my pan.
Old Mar 7, 2021 | 09:33 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
There's another spec for the 9 speed. https://bevo.mercedes-benz.com/bevol...236.17_en.html
Old Mar 8, 2021 | 07:54 PM
2012 c63 amg
its literally in the middle right behind the front bumper I think it’s coming from the long black oil cooler right behind the front bumper near the bottom
Old Mar 8, 2021 | 07:56 PM
2012 c63 amg
It looked kind of dark I’ll send you guys a picture
Old Mar 8, 2021 | 08:01 PM
2012 c63 amg
It’s coming from the passenger side and it’s dripping from the front and cause I drove it home from the air it spread to the middle where the cover is
Old Mar 8, 2021 | 09:02 PM
See63Run's Avatar
2013 C63 (W204)
duplicate
Old Mar 8, 2021 | 09:03 PM
See63Run's Avatar
2013 C63 (W204)
my goodness that's a lot of oil to be losing. if it were my car, I'd stop driving it until I had it fixed and would definitely be checking oil levels if I had to drive it. keep in mind that when you drive your oil is both thinner and under pressure so if you are losing that much when your car is parked, I can only imagine how much you're losing while driving.
did you hit a curb or something that could have damaged your oil cooler? i think you need to get those plastic pans off so you can see exactly where the oil is coming from. If you're not able/willing to do that, you should have the car towed to a shop for evaluation.
Old Mar 9, 2021 | 12:58 AM
Mort's Avatar
There is a connection at the right end of the center oil cooler going to the cooler in the wheel well that could be leaking. There is also a drain plug at that end of the oil cooler that could be the source of the leak. As suggested remove the plastic belly pans and have a look or get to someone that can.
Old Mar 9, 2021 | 04:31 AM
DRBC43AMG's Avatar
I would also get the underside and protection shields cleaned to remove all traces of oil. That may also help sourcing where the leak(s) is/are coming from
Old Mar 10, 2021 | 02:41 AM
2012 c63 amg
The thing. Is my dad checked the power steering and engine oil and it was normal and I took it to my friend that’s a mechanic we put it on a hoist and removed all the covers and stuff and it was dripping a lot of oil from this black long oil cooler in the front in the middle but near the passenger side. I asked the mb dealer near me and he quoted me 650+ tax Canadian for that black oil cooler is that a good price or is there anywhere else I can get it oem
Old Mar 10, 2021 | 03:38 AM
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
One of the members on here that has upgraded his cooler may have the old one for sale.
Before you rush out and buy anything give the area/cooler a good degrease to determine exactly where the leaks is coming from.
It may turn out to be something simple like an O ring or even the drain plug copper gasket.
Old Mar 10, 2021 | 06:09 AM
DRBC43AMG's Avatar
^^Agree
Old Mar 10, 2021 | 12:04 PM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
My ML63 had an oil leak from the oil filter housing gasket and the crank pulley seal. It would leak 2ltr per 800 km. I found some oil was dripping on the oil lines traveling until it reaches the oil cooler.
Old Mar 13, 2021 | 03:30 PM
Mikdat23's Avatar
2012 c63 amg
I have concluded that it’s coming from engine oil cooler coming from the long black cooler right where the front bumper is
Old Mar 14, 2021 | 08:05 AM
DRBC43AMG's Avatar
Is it possible to point out the source of the leak on the oil cooler? Photo is worth a 100 words...
