C63 AMG (W204) 2008 - 2015
Stock C63 cyllinder head flow vs. ported Ford Voodoo
Old Mar 25, 2021 | 05:02 PM
djr48312's Avatar
2009 c63
Hi all. I was reading about some 600+rwhp N/A manual tranny Ford voodoo builds out of stock cubes ( albiet high-rpm ). So I was able to accumulate flow data vs STOCK c63 heads to show how much head we have even stock. Stock C63 has 40mm intake valves and the Ford Voodoo has 38mm intake valves.
Intake port flow numbers ( C63 vs ported Ford Voodoo ):
lift c63 voodoo
.2 202.9 192.0
.3 300.0 267.0
.4 348.0 312.0
.5 358.0 338.0
.6 359.0 357.0
Stock C63 camshaft is 12mm (.476" ) lift on the intake and 11 mm on the exhaust. I don't have duration or timing events. Our heads actually have more low lift flow than some high dollar BIG BLOCK heads.
Old Mar 25, 2021 | 05:16 PM
deadlyvt's Avatar
2010 C63 AMG
Yes, it’s the game camshafts that are holding back some pretty serious na power builds. Would be nice is tasos got his finished, I have been talking to someone about getting a custom set built.
tame camshafts! Damn autocorrect
Old Mar 26, 2021 | 10:36 AM
djr48312's Avatar
2009 c63
Just throwing the Weistec C63 ported head numbers on there.
lift c63 weistec voodoo
.2 202.9 205.94 192.0
.3 300.0 318.71 267.0
.4 348.0 372.53 312.0
.5 358.0 389.76 338.0
.6 359.0 397.88 357.0
Old Mar 26, 2021 | 01:01 PM
djr48312's Avatar
2009 c63
Camshafts and then the intake manifold. The intake manifold out the box is setup for operation up to around 65-7000. To make power higher needs a shorter runner intake manifold like the SLS. The SLS intake will support power up to around 9000 RPM. The tradeoff is the loss of some lower end torque, in exchange for more higher end torque.
This is just like in the early Ford 5.0 days with the "Cobra or GT40" style long runner tubular intake. It boosted torque at low rpm, but prevented high rpm operation above 6000 rpm. Switching to a shorter runner intake such as the Vic 5.0 would allow power to 8000 RPM plus.
Old Mar 29, 2021 | 02:24 AM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
stock heads, stock cams, high compression pistons, race fuel and individual throttle bodies will net 580-590whp on an M156
we have a lot more to work with. we haven't even scratched the surface of M156 performance.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Mar 29, 2021 | 11:21 PM
djr48312's Avatar
2009 c63
When you take the cover off the SLS manifold, you will realize it literally is individual runner trumpet stacks inside of there. The runner length is shorter with more cross section, which is tuned for power at a higher RPM than the long runner stock C63 intake. It will support power to around 9,000 RPM.
2014 SLS with long tube headers and tuning make around 600-620rwhp.
Old Mar 29, 2021 | 11:41 PM
roadtalontsi's Avatar
10 C six trizzle
A header and tune sls is a quite impressive experience. Best part of the intake manifold is the lack of low end torque, which keeps tire spin down. 3500lb curb weight and dct definitely compliments it too.
Old Mar 31, 2021 | 04:54 PM
Xavier Smith II's Avatar
2010 C63 AMG, 2015 GL450, 2018 GLS 550, 2021 GLS 450
by high compression pistons do you mean like P31s? Or like the weistic kit?
Old Mar 31, 2021 | 05:06 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I believe he’s talking about dkjenis who got 583whp NA out of his crazy car. 14:1 compression pistons. Custom everything.
Old Mar 31, 2021 | 05:07 PM
hachiroku's Avatar
SPONSOR
fully custom forged billet lightweight pistons. 14.5 compression if i recall correctly.
__________________
-BARRY
Old Oct 29, 2022 | 02:57 PM
djr48312's Avatar
2009 c63
What was the rest of djkenis mods?
Going from 11.3:1 -> 14:1 should be worth 10.8% power and torque increase alone
If one is going to be e85 only, 14:1 is a viable option.
Old Oct 29, 2022 | 03:52 PM
djr48312's Avatar
2009 c63
IMO we needed to lose a little torque, with almost 400 cubes we have torque... If torque or off idle acceleration is a concern, we should upgrade our rear end gears. There are some Chrysler models which our rear end components interchange with that will give us a more favorable gear ratio for acceleration.
