C63 AMG (W204) 2008 - 2015
Ac not blowing very cold after condenser replacement
Old Jun 19, 2021 | 01:29 PM
Dokus's Avatar
W211 e500 (Sold), w204 c180, w203 c180, w201 190e, W219 CLS 55
Hello
this is about a w204 c180 but the AC system is to my knowledge the same as C63 and all the action is here.
Just replaced the condenser and vacuumed the system. I found no leaks after 6 hours with vaccum pump and testing.
Filled with 168g of r134a gas can. The AC compressor works and all seems to be good but the AC do not blow very cold.
​​​​​​Some site states that w204 should have around 550g of r134a so I guess I need to fill up with some more.
I've attached a picture of the gauge set with all the valves closed with 31 c outside temp with car off but don't know what to make of it. The car have just been driven.
Can anyone give som guidence on this?
Old Jun 19, 2021 | 01:51 PM
DRBC43AMG's Avatar
I don't recall if the W204 has a sticker mentioning the "weight" of gas to be injected which could be somewhere in the engine compartment. I know my W202 C43 does, so hope the W204 also has it. Check under the hood.
Old Jun 19, 2021 | 02:36 PM
Dokus's Avatar
No sticker.
Found this site and another one stating 590g
https://bads.lt/en/mercedes-benz-ref...34a-an-1234yf/
The gas I used is envirosafe which says it only need 30% of original weight.
I think I just need to fill more. Just what to double check so I don't **** up.
Old Jun 20, 2021 | 12:13 AM
roadtalontsi's Avatar
10 C six trizzle
You really should have a professional pull a vacuum on the system to boil out any moisture and charge it to the correct weight. The entire weight of the can will not be dispensed making it inaccurate. Low side pressure should be in the 25-40psi range. High side will depend on ambient temperature. ambient temp (F* x 3 +/- 25psi) example if its 31C = 88 F . 88x3 = 264psi. +/- 25psi. So ideally 239psi to 289psi on the high side. This would be while revving the engine up to 2000rpm. Id say replace the drier cartridge too but that's part of the condenser on the 204.
I'll also add the weight spec sticker is under the hood. Typically on the hvac intake box but alot of them get blasted off by power washers and used car lots etc....
Old Jun 20, 2021 | 02:57 AM
Dokus's Avatar
Thank you.
​​​​​​I've already had the system under vaccum using a vaccum pump
Can the formula always be used to make an understanding of if you need to fill more?
Old Jun 20, 2021 | 06:55 AM
ygmn's Avatar
2015 E400 Sedan
WHy did you replace condenser?
Did you replace dryer/filter (Not sure if your car has one but most do)
HOw is expansion valve aka orifice tube?
Normally a good AC repair will replace these 2 things whenever the system is open.
MB service book should give pressures required based on ambient temp and humidty this can help to ensure it is charged enough.
Old Jun 21, 2021 | 04:33 AM
Dokus's Avatar
There was a crack in the condenser due to rockchip. I replaced only the condenser and all the o-rings. The rest of the system should be fine. Oh yes, how stupid of me, I can just check wis. I need a vacation.
Old Jun 21, 2021 | 07:14 AM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
Usually as someone here mentioned, whenever the system is opened, you replace the dryer & exp. Valve. Since you are already there and these are cheap items.
as for WIS, AFAIR they don't usually list the pressure, only the weight.
Good luck
Old Jun 21, 2021 | 09:36 AM
fflmlf's Avatar
2013 C63
With the compressor off (car off) both low side and high side pressures should stabilize at the same pressure. That doesn't appear to be the case in the photo.
Why did you choose the alternate refrigerant instead of the R-134a that's spec'd for the system?
Old Jun 21, 2021 | 11:04 AM
studerim's Avatar
2015 Mercedes-Benz M-Class ML 400
It happened to my old Benz. I ended up replacing the compressor.
Old Jun 21, 2021 | 11:58 AM
Dokus's Avatar
The envirosafe should be equivalent to r134. It was the only one I could get my hands on quickly.
If will try another can. If not I just leave it to the pros.
It never stabilised to equal on both hot/cold. Hot always higher psi.
