Wheel Alignment After Header Install ?
I'm going to get an alignment this week, but I just thought it was weird and I didn't see anyone else on here ever talk about it. Has anyone had this same experience?!
Fwiw, I wouldn't recommend "fixing" this just by adjusting the steering wheel angle. You might get your steering wheel back to center, but you car will be dog tracking unless you fix the subframe/alignment issue first.
DO NOT get an alignment because the steering specs are fine, it is only you steering wheel that is off.
Ok so, he checked out all of the steering components and said everything looked good. Took it for a drive, and then performed the alignment and took it out again to check.
Car feels completely fine and drives perfectly straight... I drove it all of yesterday. I think everything is ok ? I do not feel any play in the steering wheel and it handles just as it always has.
