295/30/19 tire fitment on rear axle
Current tire ever so slightly rubs on the inner liner I believe when I have a big dipp at higher speeds.
I want to raise the rear of the car maybe 10mm to be able to clear the 295s. Whats the best way to go about that? I guess there is a 13mm and a 17mm coil rubber spacer from benz available which would give me 4mm lift? Or can coil overs lift the rear by approx. 10mm?
Thanks, looks pretty similar to my car on KW clubsports susp, as I only lowered it 1/2 inch or so to keep rear camber in check for street.
