C63 AMG (W204) 2008 - 2015
Possible Fried ECU?
Old Sep 28, 2021 | 11:27 PM
Black_Mercedes's Avatar
C63 P31, C320
Possible Fried ECU or Fuel Pump
Hey Guys,
Give a little back log of what happened. I drove the car to work perfectly fine no issues. Went to drive home from work. Made it about 2 miles went around a turn. Gave the car some gas it bogged down shifted from second to first no RPM and just died on me.
Pulled the codes and oh boy tons of them.. Shesh.. I will attach pictures to thread. Car cranks fine just doesn't fire up. Brand new battery i got it towed so i won't be able to tinker with it until this weekend.
Car is tuned by eurocharged and has been for 4 years. E85 flexfuel kit for two years no issue besides some no start issues now and then maybe twice a year. Forgot what CC injectors im running. 6-- something and LTH.
I don't trust this scanner too well because its says misfire in cylinder 10??
Anything i should look at first or just tow it to mercedes?
Old Sep 28, 2021 | 11:59 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
check that your accessory belt is still there...i've ejected my belt more than a few times which caused similar.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Sep 29, 2021 | 12:52 AM
C63 P31, C320
I will have to check was too pissed just towed it away. I will check this weekend for sure though. Even if the belt was missing would it still fire up?
Old Sep 29, 2021 | 03:27 PM
hachiroku's Avatar
SPONSOR
yes...until the battery dies, but you'll have a bunch of lights and engine codes.
__________________
-BARRY
Old Oct 2, 2021 | 04:13 PM
C63 P31, C320
Did some research. Fuse 23 was blown. Replaced fuse didn't blow but didn't do anything. Checked voltage at fuel pump no voltage. Checked incoming voltage to this fuel pump control unit perfectly fine 12.4 volts. I tried to jump voltage to fuel pumps I didn't hear a single thing. Out going voltage from fuel pump control unit is zero. So don't know if I need a new control unit and pumps? Anything else I should check?
Old Oct 2, 2021 | 04:50 PM
AMGSPY's Avatar
2014 C63 507 Coupe
My guess is that you just need a fuel pump. They do go. Just a guess and others here will know better, but it looks like it was mis-firing on the way out and then died. I think I would start there and the price online doesn't look too bad. What year is your car and how many miles?
Old Oct 2, 2021 | 04:52 PM
C63 P31, C320
I showed my service adviser this thread he said it's probably the fuel pump. Car is a 2011 c63 with 85k miles. I already replaced fuel sending unit last year because it was leaking. I will probably start with fuel pump.
Old Oct 3, 2021 | 01:18 AM
roadtalontsi's Avatar
10 C six trizzle
lol service writers know best. I know when i want to know how to diagnose cars i talk to parts guys too. They are smart peoples.
Old Oct 3, 2021 | 11:23 AM
AMGSPY's Avatar
2014 C63 507 Coupe
Thanks. I'm a service writer. Marine in my case, but we do electric fuel pumps like we are passing out candy on Halloween.
Old Oct 9, 2021 | 08:01 PM
C63 P31, C320
Awesome fixed the car. I replaced the fuel pump car fired right back up. Fuse 23 has to do with the fuel pump it kept blowing some type of issue within the old fuel pump.
Old Oct 12, 2021 | 02:32 PM
C63 P31, C320
Well that was short lived. Went to start the car this morning died after ten seconds of idling fuse 23 is blown again. Tried replacing it and it blew as soon as I put it in. I wish I could find a diagram for the wiring for that fuse. These are the new codes pulled
Old Oct 13, 2021 | 06:24 PM
AMGSPY's Avatar
2014 C63 507 Coupe
Well, that s**ks. So much for my service writer mojo. I'm out of my league here, but when the fuse blows are you key on or key off? Any recent work to your car? A dead short on that circuit out of nowhere doesn't make sense to me, and as you say a wiring diagram would be helpful. At about this level of problems, I'm having it dragged to the shop.
Old Oct 13, 2021 | 06:49 PM
hachiroku's Avatar
SPONSOR
maybe this would work?
Amazon Amazon
Tool Aid SG 25100 Short Tester
| Price: $33.10
  • Used to locate shorts quickly in 12 volt automotive circuits
  • Operates through metal parts, panels, fiber and plastic materials
  • Schematic included with instructions
  • Furnished in a clear box
__________________
-BARRY
