C63 AMG (W204) 2008 - 2015
2013 C63 AMG - Two questions (Key & Brakes)
Old Mar 29, 2022 | 08:05 PM
twiz718's Avatar
2013 C63 AMG Sedan
Question 2013 C63 AMG - Two questions (Key & Brakes)
I have a 2013 C63 AMG.
1) I've been having some issues with the car not starting using the key. I have replaced the battery and like 50% of the time it will let me get in the car with the key in my pocket but when I press the button it just doesn't do anything.
I have to remove the button and put the key in. Sometimes it starts, sometimes I have to remove the key and put it back in before it recognizes it being there. Is it a faulty key, or is it some kind of a starter module problem?
2) I am looking to replace brakes/rotors as the car is nearly 40k miles now on original parts. Any recommendations for what I should buy?
Thanks!
Old Mar 29, 2022 | 08:50 PM
skullbox15's Avatar
2014 C63
Assuming you just have the 1 key? No keyless go?
Old Mar 29, 2022 | 09:06 PM
twiz718's Avatar
2013 C63 AMG Sedan
I have 2 keys and Keyless go
Old Mar 29, 2022 | 11:27 PM
roadtalontsi's Avatar
10 C six trizzle
Does it do the same thing with both keys? When you say replaced the battery - do you mean the car or the key?
I would recommend girodisc rotors as an upgrade or just standard oem brakes. You should check out the local to you shop modern mercedes repair specialists.
Old Mar 30, 2022 | 10:55 AM
BalanBro's Avatar
2012 C63 P31 Sedan
Put fresh batteries in both fobs. If you have intermittent issues with only one key, then that one is defective. If you have the same issue with both, then your issue is likely on the car side.
For brakes, I'd personally go with one of the options that FCP Euro recommends for your car. They go from expensive to surprisingly affordable. Choose what works best for your budget. Nothing they sell is junk, so you really cannot go wrong. Plus, everything they sell has a lifetime replacement warranty (yes, even wear items like brakes or motor oil).
Old Mar 30, 2022 | 11:17 AM
twiz718's Avatar
2013 C63 AMG Sedan
thanks @BalanBro I just bought them from FCP Euro, will try the 2nd fob, I haven't been using it because the backing plastic kind of cracked when I dropped it once
Old Mar 30, 2022 | 03:32 PM
sventastic82's Avatar
2010 C63 AMG RIP. 2021 Toyota Tacoma TRD Off Road, 2013 C63 coupe
Are the brakes worn down? I didn't replaced the rotors on my old C63 until it hit 120k miles.
Your pads are probably still good as well.
Old Mar 30, 2022 | 10:53 PM
10 C six trizzle
Drive harder man. That's the grandpa S65 territory for rotor / brake replacement mileage. Had one with 80k still on original brake pads and not highway mileage.
Old Mar 31, 2022 | 07:39 AM
Rotors should last two to three times longer than pads, unless some non OEM, harder pads are used.
And if you use manual shifting that can reduce the wear as well, at least on the brakes.
I'll drive harder I'll just start randomly slamming the brakes on the interstate going 80mph.
