New to posting but we’ve lurked on and off for years. Thank you all for participating here and sharing info - it’s proven invaluable for us. Many thanks.
Current: 2012 C63 Coupe, Perf Pack
Former: 2012 C63 Coupe, Perf Pack and 2015 507
Old 12’ was our fav but we got creamed in a t-bone. Big sad. But back in action. Going through the new rig; brakes incl rotors and flush, ps res and flush, trans service, filters, pulleys, belt, clean up, headers, tune, and anything else we come across.
The odd question: anyone have a photo from their last transmission service? The fluid condition was not as I would have expected. Magnet debris was acceptable. Curious what’s “normal” presentation for old trans fluid. (Coming from old trucks, powerstroke, and general redneck maintenance).
PS fluid was typically filthy.
Side note:
picked up a QuickJack because I’ll be swapping multiple PITA cars in/out of garage… so far we love it. Couldn’t be further from mechanics but this C is absolutely the least friendly vehicle in our fleet to lift. Definitely don’t dig the jack point design (subjective, or course).
Side note:
lekoza
close
- Join DateApr 2021
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2013 c63 AMG P30 Coupe
Liked:27 Times in 21 Posts
Might get more responses if you post a picture of your oil. Most of us don't take pictures during those procedures unless we think something is wrong.
Side note:
i also recently got a quickjack- I’ve lifted our 4runner and GX, but haven’t lifted the c63 yet. I bought a set of jack pads that fit in the slot on the side rail, but it looks like it’s going to be a real hassle to get it lined up appropriately.Originally Posted by Phor
New to posting but we’ve lurked on and off for years. Thank you all for participating here and sharing info - it’s proven invaluable for us. Many thanks.Current: 2012 C63 Coupe, Perf Pack
Side note:
Quote:
My experience was that the QuickJack was not quite long enough to accommodate 100% contact @ the C63. I wound up justifying the jacks forward ever so slightly, which gave full contact at the front perch and 50-60% at the rear - plenty stable. I opted not to use the jack pads that “fit” the car, though they’re on the shelf if you find that they worked well for you. (Just a single, tall QuickJack pad at each corner)Originally Posted by See63Run
Best of luck! I felt very spoiled using these after many prior jobs with floor jacks and gravel 🥴
Quote:
wait a second - you dont use puck adapters that fit into the slots in the C63 jack points? you just use the flat pads and lift from those?Originally Posted by Phor
My experience was that the QuickJack was not quite long enough to accommodate 100% contact @ the C63. I wound up justifying the jacks forward ever so slightly, which gave full contact at the front perch and 50-60% at the rear - plenty stable. I opted not to use the jack pads that “fit” the car, though they’re on the shelf if you find that they worked well for you. (Just a single, tall QuickJack pad at each corner)Quote:
Yep. I wasn’t comfortable with where the pucks were sitting. I’ll have the rig out and up again next week and will size things up again - it’s possible I just missed something obvious in the setup but as things sat, the pucks gave me a bad feeling. Secondary/safety stand and jack placed during work, and the vehicle was very stable given a pretty honest “shove and rock” test from a less than petite person.Originally Posted by See63Run
Quote:
interesting. this would make things a lot easier to just use the flat rubber blocks against the plastic outer rim of the stock jacking locations. i've struggled to get all 4 puck adapters to line up at the same time. Originally Posted by Phor
has anyone else used flat blocks on the jack points?
BLKROKT
close
- Join DateJun 2008
- LocationLos Angeles
- Vehicle(s) I drive2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Liked:2,867 Times in 1,684 Posts
That’s what pretty much everyone already does as far as I can tell. Who has time to hunt around for the Mercedes “pucks”, it just doesn’t matter. Flat rubber blocks are fine. The car isn’t going to go anywhere as long as you’re smart about placement.
ExploreMember
Quote:
thanks, blkrokt. I think I had (perhaps incorrectly) assumed that the Mercedes pucks are necessary for proper weight distribution while lifting the car but perhaps they are only for stability and the full weight of the vehicle can actually be supported by the outer rim of the jack points. This would make my life a lot easier bc I could just use the rubber blocks that came with the quickjack Originally Posted by BLKROKT
https://reverselogic.ecwid.com/Jack-...C218-p21256090
Hey, I recently acquired one of these and test fit without jacking and it seemed to be rather quality in fit.
I understand that $200-300 bucks depending on how many you get may not be worth it but to each their own.
$200-300? Originally Posted by GarlicBread
https://reverselogic.ecwid.com/Jack-...C218-p21256090Hey, I recently acquired one of these and test fit without jacking and it seemed to be rather quality in fit.
How would you need more than 4?
They sell it with a spacer, but the spacer is about 15 bucks. 4 pucks + 4 spacers = 200 bucks roughly.Originally Posted by See63Run
$200-300?How would you need more than 4?
I didn't look where you live so you could pay shipping.
Pistols at dawn and wear your nicest wig.
I went with these, and they work fine. They snap into the MB lift point so that you can line up easily.Originally Posted by See63Run
Search SiteSearch mercedes jack pad - 203589023100 - Lifting Adapter Kit (ecstuning.com)
