C63 TCU Tune - any recomendations
ive got a 2014 507 edition and been thinking about doing a TCU update.
Has anyone done it before?
are they worth it?
what brand did you use?
anyone used this one before? https://elite-flash.com/product/merc...ox-tcu-tuning/
Thanks!
I will say it's a crap ton cheaper than when it was first released out of Germany and Eurocharged Houston did it with Dave going around. I know they started passing the laptop around and i know theirs did make a difference. This may be a knock off copy style so if this is the same style then yes its worth it.
Not really sure how many in the wild have done it with this one, maybe someone here has and can give feedback on this particular one.
Mine is a torque convertor one so it did adjust my lock up some and allow a bit more torque to get through sooner for the gears I wanted. The MCT guys felt it and the quicker shifting a bit more as well.
One of my gripes was a slipping feeling in 3rd and 4th gear sometimes in early RPMs that Daves tune did help resolve. I can't remember the name of the german tuner that started this for our 7G's but if you search you will find threads when Dave did the kind of national tour and tuned a good few of ours from mbworld, still one of the more fun hang out days I've had, there were some nice E63s getting it done and made me drool. We had one 507 edition on that day as well as mine for the C63 portion.
One thing I will say, since it ups the pressure some you will want to switch to 20k service intervals for your transmission. And no, don't ask how much we paid hahaha.
I'll say this, no point in a video or describing really, it's something you need your dragy and your butt to feel and notice.
And yes Doug, 100ms is way too slow.
With that said, go with a known tuner. Don’t plug just anything into your car unless you can afford to replace your transmission, ECU, TCU, engine, whatever.
Would be interesting to see "bang" shifts in someone's upgraded car but even the best tuners seem reluctant to provide any concrete proof (Or I've just missed it). From what I'm gathering it comes down to updating both the ECU and TCU in order to achieve results approaching something worthwhile.
Unless the valvebodies / solenoids in the transmission have also been upgraded, I can't see how a TCU tune on an otherwise stock MCT transmission would do much. If you've changed the valvebodies that is a different thing altogether, but again, the main issue is the delay between the paddle pull and the shift execution as opposed to the time it takes to shift. In M mode full throttle shifts are as fast as anything... shift times are ALMOST comparable to a proper dogbox.
If you're serious and anyone wants true info get in the TCU tune whatsapp conversation.
I am happy with my "stock" 722.9 in the sense that it upshifts quite quickly when flooring and also allows some pretty aggressive downshifts, it's just the "delay" in M mode that irks me a bit, coming from a VW DSG box.
Now did I use a stop watch and get the exact millisecond it cut, no, but M mode feels so much more fun now. And let's all be honest, no one NEEDS a TCU tune, no one is forcing anyone to favor it or say it's magical. The value and benefit will always be in the eye of the beholder.
Only thing I can say is I sure don't regret it and I'm sure after I decide to have Barry do my ECU tune it will feel even better combined. It does increase line pressure, keeps within limits from what I was told and that is what helps for a faster shift as it was explained to me, it can't help the delay from paddle to gear box. It adjusts your torque setting that your TCU see's coming from your ECU etc to help better match what your ECU tune is pushing now. At the core it's a miniscule of difference and for many that aren't trying to get that extra 10'th of a second shaved off won't ever care about this TCU tune. But if you're actively trying to get a track time down a smidge or better quarter mile times down it can be a helpful thing.
In my earlier AMG(c55) i changed the solenoids to bluetops AND had a eurocharged tune, still disappointed of the lag between pulling the paddle and actual shift.
I don´t want to 'time' the shift at say 6800rpm so it shifts at 7200rpm.
Literally night and day difference between the butter/quick shifts of the DSG paddles vs the MCT paddles.
Personally, S+ results in the best balance of quick shifts and power band at least for highway pulls but I can't speak for anyone trying to drag/circuit race.
It is an odd overlook on AMG's part imo...
I also can't say i believe in the modified valve bodies as I looked at mine and all they did was cut the filter/mesh screens off some of the solenoids. How about no.
Fight me.
Its the question of owning 1 GT-R vs owning an R35, C6Z, and a GT350R. And its not an easy choice.
Also, thou can displace deez nuts sir.
