C63 AMG (W204) 2008 - 2015
Inner Tire Edge wear
Old Jul 23, 2022 | 02:39 PM
lekoza's Avatar
2013 c63 AMG P30 Coupe
I jacked up my car to change the oil today and noticed that I could see the bands on the inner edges of the front tires! After replacing the tires I want to know what I should do to avoid the issue going forward. What are the most likely culprits. Alignment, suspension wearing out, or something else? My car has 53k miles. When the car is jacked up and I try to push the wheels left to right or up and down, they don't budge. I would guess that means it's not a control arm issue?
Old Jul 23, 2022 | 06:57 PM
sventastic82's Avatar
2010 C63 AMG RIP. 2021 Toyota Tacoma TRD Off Road, 2013 C63 coupe
There are several threads out there, with some headed debates.
Just read through them.
Old Jul 23, 2022 | 10:08 PM
lekoza's Avatar
Yes, there doesn't seem to be a consensus from what I've been able to find. I think I will just take it in for an alignment after the tires are changed. If the inner inch of the tires wear out more quickly in order to provide better handing I guess it is what it is.
Old Jul 23, 2022 | 10:26 PM
As long as you have it aligned per MB spec you should be fine.
Old Jul 24, 2022 | 05:43 AM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
https://mbworld.org/forums/c63-amg-w...side-edge.html
Old Jul 24, 2022 | 10:12 PM
roadtalontsi's Avatar
10 C six trizzle
bought sports car... upset goes through tires differently than economy car.
Old Jul 24, 2022 | 11:58 PM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Except OEM there is only front and rear Toe directional adjustment. OK for showroom height conditions !
But Camber adjustment is essential for day to day commuting encountering high cambered roads, wheel squat / altered height through load carrying or lowering, fitting wide profile tires or just having ongoing adjustability to cater for curb knocks.
Because of ever increasing speed of auto assembly lines OEM front and rear Camber (and front Caster) has been deleted !!
We saw the need and have reinstated from the early 90's once again Camber and Caster adjustment capability.
EXAMPLE for all W204 Models front Camber kit P/N 502616-1i is $345 - less then cost of 1 hi performance tire. Replaces the 2 front lower arm inner bushings. Designed to fit without need for arm removal. Is precise single wrench adjustable accurately (under load) - direct on alignment rack.
SEE SPOILER RE TOTAL SYSTEM FOR W204 MODELS
Spoiler
Old Jul 25, 2022 | 10:44 PM
lekoza's Avatar
I didn't say that I'm upset; I'm just trying to understand what is going on... If the angle the tires are set at is helping performance but causing odd tire wear, then it's just something I need to be aware of and check on occasionally.
Old Jul 30, 2022 | 11:58 AM
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
Both my C63 and E63 are susceptible to 'odd wear' with improper air pressures.
Much higher air pressure than I prefer (for feel), but at the recommended pressures I have/had pretty even wear.
At lower pressures up front the inner edge wear was accelerated A LOT.
Old Jul 30, 2022 | 09:51 PM
skullbox15's Avatar
2014 C63
What's considered "lower?"
Old Aug 2, 2022 | 11:26 AM
Dogtag114's Avatar
2009 c63
I lost my front inner edges in a few thousand miles of pure commuting. Changed alignment to Zero Toe up front and never had an issue again.
On PS4S now like many here.
Old Aug 2, 2022 | 01:02 PM
deadlyvt's Avatar
2010 C63 AMG
this I just can't type it out any more. In run 1/16" of total toe in front and have much better wear and no noticeable handling difference over the stock toe
Old Aug 3, 2022 | 03:13 AM
LARSLEMANS's Avatar
2008 C63 AMG
No you are just OFFset
Old Aug 5, 2022 | 01:14 PM
nastypoker's Avatar
W212 E63 2015
Old Aug 5, 2022 | 03:43 PM
Less than recommended on the door jamb.
I preferred how it felt at a few psi less than recommended but the tire wear was definitely accelerated.
Running the recommended pressures and the wear is pretty even for me now on my E63.
