Hi, my car is a 2009 with only 19 thousand miles. Coolant still the original from car was made. Is it time to replace it? Of so what's the easiest way to do it? Just drain from radiator and flush with distilled water a few times? Coolant life goes more by the miles or age?
BLKROKT
close
- Join DateJun 2008
- LocationLos Angeles
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Liked:2,867 Times in 1,684 Posts
Did you read the owners manual?
I just did this after replacing the thermostat.
easy to drain from the red petcock at the bottom of the radiator.
I did not do a distilled water flush but you can if you feel like your system is contaminated.
refill with a 50:50 mix of MB coolant and distilled water. There is no bleeder on the system - I had to go through several cycles of bringing the car up to temp, letting it cool, and topping off fluid before I got all the air out.
Ok thanks, i didn't feel comfortable to leave 13 years old coolant in there. I'm gonna do it this simple way and do it every 2 or 3 years. As i hear it helps preserve the headbolt from rusting(untill i change them)Originally Posted by See63Run
I just did this after replacing the thermostat.easy to drain from the red petcock at the bottom of the radiator.
Diabolis
close
- Join DateJan 2013
- LocationThe Great White North
- Vehicle(s) I driveW204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
Liked:811 Times in 554 Posts
Mercedes specifies that the coolant needs to be replaced every two years. If you have never done yours, it has long ago lost its protective seal conditioning, anti-corrosion and anti-bacterial properties as well as its ability to effectively transfer heat and thus cool the engine.
Quote:
The service booklet that came with my 2010 says to replace coolant every 240k km or 15 years.Originally Posted by Diabolis
Quote:
This has pretty much been my method for any car I've ever owned. I do a full drain/refill every 2-3 years. The only time I would do a full flush would be if I bought a used car and didn't know what fluid was in there, if someone had put the wrong fluid, if I was replacing a component of the cooling system, or had some reason to believe the system was contaminated. Originally Posted by Cashrolling
Diabolis
close
- Join DateJan 2013
Quote:
I stand corrected. On all turbocharged engines it is 30,000 miles or 2 years, however, I don't see the same for the NA motors. Originally Posted by Jasonoff
Even on a non-turbo motor though, I'd still replace the coolant every three or four years because it does lose its ability to absorb and transfer heat just like it loses its seal conditioning and anti-oxidation properties.
ExploreQuote:
What's even more insane, there's absolutely no service interval for the PS fluid.Originally Posted by Diabolis
eightysixtuned
close
- Join DateApr 2022
- Vehicle(s) I driveW211 E63 AMG
Liked:133 Times in 99 Posts
Quote:
the service interval is...wait til it whines...Originally Posted by Jasonoff
BLKROKT
close
- Join DateJun 2008
Somebody once told me that if you change the coolant too often, you’ll lose some of the system efficiency or cooling properties. It’s 15yr coolant. If you don’t change out the overflow reservoir every time, which has an additive pack integrated into it, you’re not making things better, just worse.
I’ve also read that the packet in the tank is to extend the life of the coolant.
Either way, the coolant is designed to be used for a very long time. Don’t change it if you don’t absolutely need to.
