Intake manifold Upgrade
Hey guys so my 2013 C63 threw a check engine light about a month ago finically got it diagnosed intake manifold is leaking not sure if it’s just gaskets or the common issue of a cracked center plate on the intake manifold I’m preparing for the worst at this point I’ve priced a new intake from Benz and its $4200 which is pretty ludicrous but with that said it seems as though the aluminum/magnesium material is very prone to cracking so it seems pointless to spend that much too only have the same problem again down the road and Mercedes does not offer just the center plate you gotta buy the whole plenum so what are options a supercharger which would eliminate the oem intake ? Or have my welded if it’s cracked which can be very challenging depending on where it’s cracked by the sounds of it from other owners ? I’ve also been researching aftermarket options which I’ve only come across one that may be worth considering it’s the lower intake center plate only and it’s available from German muscle Co in Arizona for $1100 I’ve attached pic id greatly appreciate any insight into what other owners have done to remedy this issue if their is any thanks again Chris
2013 W204 C63 AMG P31 Estate wagon
I bought this one from the US.
And yes, it does fit 2013/14 C63
OEM NEW M156 V8 Engine Intake Manifold Center Mounting Plate Repair Kit | Mercedes-Benz C63 AMG 2008-2012 (rebuildmastertech.com)
I have an intake manifold from a 507 for a very affordable price!
12 C63BS Magno Alanite Grey, 22 X3M Brooklyn Grey, 08 BMW E93, 22 Ducati Desert Sled, John Deere 3R
That plate you linked is for running bigger throttle bodies, you can get a replacement aluminum plate for a few hundred and replace it if that is all that is wrong and typically is the first place they fail.
https://www.ebay.com/itm/Mercedes-CL...edirect=mobile
I appreciate all the feedback guys I’m gonna hopefully get it torn down soon and see exactly what I’m dealing with than I may just buy a used one if in fact it is cracked
