P0153 The coolant thermostat has a short circuit to positive. help?
C63 AMG 2009 / Nissan 350z 2006 / CBR1000RR 2010 - Brazil
p0153: The coolant thermostat has a short circuit to positive.
c63 2009
any ideas on where to start looking ?
c63 2009
Received 2,813 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Did you try replacing the………… coolant thermostat?
That’s probably a good place to start.
For the record, P0153 is an O2 sensor error code (left bank), so your description is totally wrong. Replace your O2 sensors.
12 C63BS Magno Alanite Grey, 22 X3M Brooklyn Grey, 08 BMW E93, 22 Ducati Desert Sled, John Deere 3R
And we don't have electric thermostats in these cars so there is no electrical fault for the thermostat I don't think.
Yeah I thought there’s a connector that sends a signal to the ECU but maybe wrong. He’s got the wrong description for the code anyway which took all of 3 seconds to figure out using the Google machine.
so you dont need to be rude to awnser. I already got an mechanic with it, but he just dont know and dont have right tools to do it, imma bring my scanner later there and see what error code I get, but if you check 0154 is the same error since I seen another guy here in forums
I just want some ideas so I can give the mechanic some directions.
if you can help, ill be glad. You dont need to be ironic or sarcastic while awsering me since Im kinda desesperate to fix this.
Most people here doesnt even speak english, so they cant search around. I tried google 1000x before coming here
the mechanic dont speak english thats why im searching for him
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
there is not, I knew it. My problem is the fan is running non stop, I live in Brazil, idk if you know, but in Brazil we got 200 million people here and we have only 250 units of c63 2009. Literally 0 information, and Mercedes shop here would charge around 30x of regular price.
P0153 is a left O2 sensor fault, but a faulty O2 sensor doesn't make the fan run continuously. A faulty thermostat or any number of other issues might, but that will not generate an 0153 code. You need to start by looking for a new mechanic because yours is obviously clueless.
