KMAC Camber Plate Failure
Hi W204 C63 AMG Community,
I have KW v3 coilovers and purchased and installed this set of KMAC camber plates in February (https://k-mac-camber-kits.com/.../mercedes-w204-x204.../) I ran over an open fissure in the road yesterday at 30 mph and it completely destroyed the passenger side front top mount bushing (pictured). While I know any coilover/camber plate setup is not made to handle fissures in the road, I was surprised at how fragile the KMAC camber plate design is (and is a waste of $600 plus cost of install and alignment in less than 5 months).
Coming from the BMW community, I know there are many camber plate options (Vorshlag, Ground Control, Turner, etc.), but what do you W204 C63 AMG owners with coilovers and lowered suspension use for reliable camber plates?
Thank you in advance for your insights.
The following 2 users liked this post by DRBC43AMG:
A///MG_Power (07-18-2023),
BLKROKT (07-18-2023)
SPONSOR
Depends on the size of the “fissure” - These STAGE 2 (STREET / RACE) W204 front upper strut mounts both Camber and Caster adjustable in production now 6 years. So well and truly proven for competition or day to day long term commuting.
Advise address and will air express replacement. Also return satchel so can check out !
Background is unlike other brands instead of solid centers with no flex to absorb impact loads the K-MAC Stage 2 centers are encased in elastomer !
The universal design “solid centers” / no flex that have been around for decades are our STAGE 3 Full Race kits.
Do point out not only offering ‘2’ versions but also unique - manufacturing using “very highest aircraft 7075 grade aluminum” / not soft billet alloy. With patented design breakthrough providing the “quickest” and “biggest” adjustment system.
STAGE 2 (503016-2) we find rally drivers choose stating doubles the lifetime over the ridged STAGE 3 kits.
Kevin
Kevin
The following 4 users liked this post by K-Mac:
Kevin
Kevin
What's the point of using "very high aircraft 7075 grade aluminum" if that is not the weakest link in that camber plate assembly? Or would it be the weakest link if made out of a softer aluminum?
SPONSOR
As picture clearly shows and we point out it is not the highest 7075 grade aluminum mount but the "elastomer" center!
he already mentioned they offer a Stage 3 that has no elastomer. not sure why you're arguing as they're sending the customer a replacement.
I'm not arguing I'm just asking a simple question.
Received 2,842 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Kevin is a good dude. Great service.
I used his race camber plates for years with no problems at all. Just looks unlucky.
read what again. you're asking a stupid question. why would they use a softer metal to make the part inferior.
It's ok, you don't have to answer if you don't know the answer. Unless you feel that you are an expert in that field as well.
my guess is they are trying to upgrade the life/durability of the part failing. You don't cheapen or weaken other parts to also fail in conjunction with a part that fails to save some money you move onto the next failure point and try improving it.
Did you use the race camber plates on the street? Are those plates the stage 3 plates that are offered by KMAC?
If so, did they make noise (can be expected with metal on metal), were you using coilovers, how low was your C63 from stock and what effective camber were you able to achieve after alignment using the stage 3 plates?
thanks in advance for your insights.
Kevin
Kevin
Kevin’s attention to customer service and satisfaction is great. I am very pleased with the customer service at KMAC and I hope the elastomere bushing holds up this time as I will try and drive more carefully.
I have KW Clubsports which have solid spherical bearing top mounts and you don’t notice any noise on them. It is a little harsher though with them being solid if that bothers you.
Mine is pretty low running 255/35 front & 275/30 rear. If your on Instagram you can check it out there (@phil_t) to see how low.
SPONSOR
To keep up with constant upgrades and new releases for all W204, C207 (including C63 AMG & Black Series) have attached latest copy of current “TOTAL SYSTEM”. Covering both front and rear suspension !
Kevin
SEE SPOILER
Kevin
SEE SPOILER
Spoiler
