Is this normal or am I paranoid?
Hi all,
I’ve recently Purchased a 2012 c63 with P31 package The vehicle has 100,000km (60,000 miles) on it. I have completed quite a few preventative maintenance items so far including:
Coils, spark plugs & fuel injectors
Transmission flush
Diff fluid change
Oil & Filter plus MOS2 liquid Molly anti friction
Have a listen to these two separate clips and let me know if you’re hearing ticking? Keep in mind this is on a cold start. Engine is not at operating temperature.
I will upload a second video shortly.
Transmission flush
Diff fluid change
Sounds like a healthy engine.
I would start looking at replacing the belt and idler pulleys in the next 10k miles.
Zinny84 (10-07-2023)
Sounds pretty normal, possibly a hint of whining from the belt drive system but hard to tell from the video. As mentioned above great idea to replace belt, idlers and belt tensioner around 50-60k miles. Not sure why everyone replaces ignition coils on these all the time, they rarely go bad if plugs are replaced when recommended.
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
The only ticking I hear is the fuel injectors doing their job. There is nothing unhealthy in the engine sound in any of the three clips you posted. Enjoy the car!
Sounds like a healthy M156, congrats on the new ride! Like other members have stated I would recommend changing the pulleys and belt when you get a chance. Also, you didn't specify but make sure you're using 5w-40 and draining the oil cooler when changing the oil every 4-5k miles.
Zinny84 (10-08-2023)
Dang, I must be paranoid too, my engine sounds like this and I was getting worried lol. It especially freaks me out when I drive next to a wall or barricade and you can hear the engine noise reflecting back.
I might do some before and after videos, I think right now my oil has Fuchs 0w-40 which was topped up recently with 1.5 liters of Mobil 1 5w-40, and Liqui Moly Hydraulic Lifter additive (the mech that did it was team BMW and loves Fuchs I guess, I added Mobile 1 when it got low). In a week or two I'm switching to Liqui Moly 5w-40 with Ceratec and see if it makes a audible difference.
