C63 AMG (W204) 2008 - 2015
Oil Temperture sensor location
Old Dec 11, 2023 | 05:08 AM
MrAChuah's Avatar
C63 W204 M156
M156 engine Oil Temperture sensor location
Hi,
Can’t find a definite answer for the exact location of the oil temp sensor on a c63 w204 M156 engine.
Any photos or a diagram would be appreciated.
Thank you.
Old Dec 11, 2023 | 08:21 AM
sickSVT's Avatar
Top Answer: 1
3.0L Whipple E63 AMG
Oil Temp sensor is located behind the AC compressor.
Old Dec 11, 2023 | 09:48 AM
95gsrturbo's Avatar
2000 Acura NSX, 2012 C63 P31 (gone and not forgotten), 2015 C63 507
Is it easily accessible or does the compressor have to be removed?
Mine just went bad
Ordering parts today
Old Dec 11, 2023 | 11:03 AM
MrAChuah's Avatar
C63 W204 M156
The strange thing is on another diagram it is showing the oil temp sensor being on a different spot (photos attached - no 50)
This one would be about an hour or so job to replace. The other one on your photo behind the AC compressor will be like a 10 hour job.
Conflicting info about which one it actually is. I’m sure on this model there’s only 1 oil temp sensor however the same part is used also for coolant temp sensor.
Old Dec 13, 2023 | 06:52 AM
95gsrturbo's Avatar
I'm so more I'm confused again
Thought this thread ended it
Old Dec 13, 2023 | 09:17 PM
MrAChuah's Avatar
C63 W204 M156
I can confirm it’s 100% behind the A/C compressor the other one on the right side near the alternator is the Coolant sensor and they both use the same sensor part number.
sickSVT is correct. 👍
Thanks.
Old Dec 14, 2023 | 02:33 PM
95gsrturbo's Avatar
Does the AC compressor have to evacuated and pulled ?
I haven't been under the car yet. Asking to prepare myself
Old Dec 14, 2023 | 02:39 PM
MrAChuah's Avatar
C63 W204 M156
Yes the A/C has to come off to get to the sensor. Took mine to the mechanic to get it done.
Old Dec 14, 2023 | 03:15 PM
sickSVT's Avatar
Top Answer: 1
You don't have to completely remove it, you'll just have to lower the subframe a few inches to remove the lower bolt of the AC compressor and just set it aside.
Old Dec 14, 2023 | 11:52 PM
95gsrturbo's Avatar
Thank you sir!!
Old Mar 12, 2024 | 08:18 PM
wazc63's Avatar
2009 c63 amg
following from my thread about engine wire harness, saw your comment regarding the same thing on this thread, is there a pic of an actual image of the AC compressor location on the engine i can see so i can know how tight it is? all i need to do is remove the connector to it not the actual oil temp sensor.
Old Mar 12, 2024 | 11:09 PM
Mort's Avatar
There is a pic of the A/C Compressor and Oil Temperature Sensor in post #2 above in this thread.
Old Aug 29, 2025 | 08:26 PM
Howard_Woodard's Avatar
2011 Mercedes E-63 W212 M156 with 88,000 miles
This thread might be a bit old but it's gold. Thanks folks.
One question I've heard asked but not answered is whether you have to remove anything if you don't know if you need to replace the sensor, you just want to pull [and reconnect] the connector. Do any of you know the answer to that?
Also, If I remove the ECU connector and read back through the sensor to ground, any idea what resistance it should read when cold?
When I read the oil temp pid with my iCarsoft scanner, I see that it has almost regular very clean spiky pulses from between -41C up to -32C. Not what I would expect from either a faulty sensor or an oily wire so i'm wondering if what I'm seeing is the actual sensor output or if it's a calculated/test value from the ECU.
Thanks in advance for whatever info you might be able to offer.
Graph of oil temp pid when display is showing only blank underlines
