C63 AMG (W204) 2008 - 2015
Downpipes only vs LTH
Old Feb 2, 2025 | 12:44 AM
intence's Avatar
CLK63 AMG Black Series
Im considering a set of Armytrix (or similar) downpipes which removes primary/secondary cats but retains stock headers and resonator. Does anyone know how much quieter this is compared to a full long tube header setup?
I would assume removal of both cats should be pretty loud but will the stock header quiet it down?
Old Feb 2, 2025 | 03:04 PM
deadlyvt's Avatar
2010 C63 AMG
it will be basically the exact same noise level.
Old Feb 4, 2025 | 07:29 PM
Madcow554's Avatar
2012 C63 P31 and 2011 E550 Luxury
Hey so i was in exactly the same boat as you and played around with a few things over the years. I had the full Armytrix exhuast downpipes, resonator and valvetronic mufflers connected straight to my stock headers and it was loud. However with the valvetronic mufflers it did quiet it down quite a bit when i had the valves closed. I then removed the entire Armytrix exhuast and installed full length ARH with a custom 3" exhuast and to my surprise it wasn't much louder, i would say it is around 5-10% louder. The valvetronic muffler is what quieted it up the most. By the way i have my entire Armytrix trix exhaust with the valve tronic sitting in my storage locker and i would let it go for a killer price if you really want it.
Old Feb 4, 2025 | 08:28 PM
intence's Avatar
Thanks for info. I dont need the catback valvetronic section. Send me details about the rest if you want to separate
Old Feb 4, 2025 | 09:33 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Here is how I would characterize the volume having tried all these things over the years.
Remove secondary cats, Mikes Power Pipe H pipe - 15% louder
remove secondary cats, Mikes Power Pipe straight - 20-25% louder
Armytrix downpipe with 200 cell race cats - 50-60% louder
no cats - full headers or cat less downpipes - 100% louder
this is all with factory back half resonator and mufflers.
Old Feb 6, 2025 | 05:51 PM
Big Worm's Avatar
C63 507 Coupe
I'm interested in this, as well. I don't like the idea of chopping off the secondary cats from the OEM system, so the Armytrix 200 catted down pipes seem like a good solution. With the cats being less restrictive, would I have to have the car tuned to avoid throwing a lambda code?
Old Feb 6, 2025 | 05:58 PM
Madcow554's Avatar
from my experience yes i believe you need a tune, otherwise the light may come on and off at times, or just stay on.
Old Feb 7, 2025 | 09:24 PM
Top Answer: 1
The Mercedes system is very easy to fool, much easier than my older BMW is. With 200 cell cats, the secondaries I just can like 2 inch extensions and never ever saw a light on 2 different cars no tune goes through obd just fine. Happy to look at exactly the length of the extensions exactly for anyone.
Old Feb 15, 2025 | 09:47 AM
Big Worm's Avatar
C63 507 Coupe
Shout out to @roadkillrob for trying to hook a brother up with some catted downpipes. Turns out the shipping would be extortionate, so it just makes sense to buy a new set from Armytrix.
I've seen plenty of clips on YT of the Armytrix catless downpipes with stock resonator & mufflers, but does anyone have the Armytrix 200 cell catted downpipes installed on their car? Better yet, anyone have a sound clip? They don't seem to be a poplar option. Based on Rob's sound level breakdown above, I'm looking to get somewhere in between stock and HOA complaint.
Old Sep 21, 2025 | 03:33 PM
Harshil6.3's Avatar
do you still have it i can buy it
