C63 AMG (W204) 2008 - 2015
W204 C63 AMG 2009 - Replacement engine required, UK based
Old Mar 13, 2025 | 05:53 PM
RazorZero's Avatar
W204 C63 AMG
My W204 C63 AMG recently experienced engine failure so I am looking at replacement options, any advice or leads on a replacement engine is greatly appreciated. UK based.
Thank you!
Old Mar 13, 2025 | 08:08 PM
Mort's Avatar
Have you tried the UK Dismantler network?
Old Mar 14, 2025 | 03:49 AM
Phil_T's Avatar
C63 AMG Saloon
Speak to MSL Performance in Birmingham, Acid will sort it out for you.
Old Mar 14, 2025 | 07:18 AM
RazorZero's Avatar
W204 C63 AMG
@Mort - I haven't and to be honest - I don't know where to start so any steer on this would be amazing.
Old Mar 14, 2025 | 07:20 AM
RazorZero's Avatar
W204 C63 AMG
This is great advice thank you, I called them a few days ago and they have referred me to a place in Kent so there's a potential avenue for rebuild there. Appreciate the advice thanks
Old Mar 14, 2025 | 07:21 AM
RazorZero's Avatar
W204 C63 AMG
Old Mar 14, 2025 | 08:19 PM
Mort's Avatar
I am in Canada and have no personal experience with the auto wrecking yards in the UK. I just put "auto dismantler network united kingdom" in google and it came up with a few sites that should give you a place to start. Best of luck getting your engine replaced or rebuilt.
Old Mar 15, 2025 | 04:16 AM
Phil_T's Avatar
C63 AMG Saloon
👍🏻 I knew he could help as he always helps everyone, done loads for me in the past even over the phone.
Old Apr 11, 2025 | 02:35 PM
C63 UK's Avatar
C63 W204
I'm from the UK and I'd definitely keep an eye out on ebay as engines come up there every now and then. If you do go down this route it is definitely worth getting somebody to go with you to check it beforehand if you aren't mechanically inclined.
How did you engine failure happen +what is the specific issue if known? If rebuilding is definitely not out of the picture it might be worth a go also.
