C63 AMG (W204) 2008 - 2015
W204 C63 exhaust discussion
Old Aug 2, 2025 | 08:51 PM
AJ1999's Avatar
Hey guys just bought a 2012 c63 p31 package with factory exhaust.
im really interested in doing primary cat delete and secondary and resonator delete. Has anyone done this exhaust and if so what’s your experience?
Old Aug 2, 2025 | 10:04 PM
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
Add LTHs, which removes primaries, remove the center resonator, add an H-pipe in its place and leave secondaries or add hi-po cats because the smell will be crazy otherwise.
Old Aug 3, 2025 | 12:13 AM
AJ1999's Avatar
I’m doing this on a budget high flow cats and headers are not an option
Old Aug 3, 2025 | 04:50 AM
DRBC43AMG's Avatar
If you are doing things on a budget all I can recommend is leave things as they are. You don't really need extra noise, but perhaps set some money aside for further down the road. Maintenance of these "beasts" can take large chunks out of your wallet.
Just my 2cts.... but enjoy the experience
Old Aug 3, 2025 | 10:53 AM
Phil_T's Avatar
C63 AMG Saloon
After owning mine since new for 12 years and hearing loads of different exhaust set ups in person there are only two that sound good imo.
- Secondary cat delete with straight pipes and rest of exhaust system stock.
- Headers (MBH or ARH) with or without cats with secondary cat delete with straight pipes and rest of exhaust system stock.
Everyone is going to have different opinions but those two keep the amg tone while increasing the volume, all other options or brands change the 63 amg tone either by material thickness, material, header design or by messing with the resonator or mufflers which is a big no for me as it makes them sound awful.
Old Aug 3, 2025 | 03:06 PM
INS1GNIA's Avatar
'13 C63 AMG P31
+1 for the "Secondary cat delete with straight pipes and rest of exhaust system stock." That's what I have done to mine and it's great. Also lower your rear seats, it will help increase the noise (dead serious).
Old Aug 3, 2025 | 08:16 PM
ShazV6's Avatar
17' C43 Coupe
This is spot on, best and only way to keep the amg v8 sound.
Old Aug 4, 2025 | 01:50 AM
Madcow554's Avatar
2012 C63 P31 and 2011 E550 Luxury
is lowering seats only an option for some c63, i dont think mine lower
Old Aug 4, 2025 | 12:15 PM
0fc5dccf's Avatar
If you want to delete the resonator I have a C63 with the resonators cut out and replaced with straight pipes. Would love to trade with you for a stock exhaust. Only one pipe has to be swapped.
Old Aug 4, 2025 | 12:20 PM
AJ1999's Avatar
why??
Old Aug 4, 2025 | 12:26 PM
0fc5dccf's Avatar
Originally Posted by AJ1999
why??
Because I don't like how loud it is. I bought the car like this.
Old Aug 4, 2025 | 12:47 PM
AJ1999's Avatar
you can buy it
Old Aug 4, 2025 | 12:51 PM
0fc5dccf's Avatar
you can buy it
how much do you want for the stock exhaust then?
Old Aug 4, 2025 | 01:27 PM
AJ1999's Avatar
you just want the resonator ?
Old Aug 4, 2025 | 01:42 PM
0fc5dccf's Avatar
no, I want the whole unmodified pipe that includes the resonator and right muffler. It's one piece all the way up to the front where it mates with the secondary cats.
Old Aug 4, 2025 | 02:19 PM
INS1GNIA's Avatar
'13 C63 AMG P31
There should be levers in the trunk that you pull (similar to image I found). It will pop, then you can go and fold them down. There is also a line/break in between the seats that shows that each fold down.
Old Aug 4, 2025 | 02:35 PM
AJ1999's Avatar
oooo yea I’m not looking to give up the muffler :/
Old Aug 4, 2025 | 02:45 PM
Just search for the center resonator if that's what you're after. Cutting and welding it in is so easy the whole section is overkill. My PO took it off and I added it back on with some hi-flow cats for smell. I can tell you to.lool elsewhere because it did absolutely nothing for sound control. Didn't change the tone or volume at all.
I've read our mufflers are actually just huge resonators and you'd need to find something to replace them if you want less noise. Trust me when I say that extra resonator does nothing. It does contain the stock H-pipe, so there's that. 🤷‍♂️
Old Aug 4, 2025 | 02:49 PM
0fc5dccf's Avatar
none of you are understanding me. My car has the resonator cut out and replaced with a straight pipe. The muffler is the same and stock. The only modification is the resonator. It's a bolt on, bolt off piece and doesn't require welding or cutting. Just replace that one pipe in the picture I showed. I'm offering to meet up, and swap just the one pipe. My P31 still has the factory, stock, unmodified mufflers. Only the resonator and the internal h-pipe was cut out. All I want is to trade that entire exhaust pipe, straight pipe and right side muffler for your stock, unmodified resonator and muffler. Cash on top is fine.
Old Aug 5, 2025 | 11:29 AM
No, I understand that just fine, you already have the muffler, why do you need another?
Old Aug 5, 2025 | 03:36 PM
1JDM911's Avatar
'12 C63BS "SlickTop", '08 CLK63BS, '16 E63S wagon, '12 CLS63, amongst other non-Merc toys
he wants a muffler w/ the original resonator still attached & not welded back on; but i get you what you're pitching, weld the resonator back on and it makes no difference.
Old Aug 6, 2025 | 08:47 AM
sirius9's Avatar
W204 C63 saloon
LTH will remove primaries and secondaries, unless you want to weld the secondaries back into the mid pipe.
Only option is to add high flow sport cats into the mid pipe.
Old Aug 7, 2025 | 08:45 AM
Thguns's Avatar
2009 Mercedes C63 AMG, 2013 Mercedes C350 4Matic Coupe. 2012 GLK 350 4Matic
C63 exhaust mods
secondary cats delete and straight pipe, don’t need X pipe as resonator is X contact me and I can share video of cold start and highway pass.
