C63 AMG (W204) 2008 - 2015
OG’s I need your help!
Old Mar 4, 2026 | 12:05 AM
SROC276's Avatar
2010 C63 P31 AMG
Hello all…been a while since my last post. I still have my 2010 C63 P30…been running well until recently. Currently have 170k miles and recently experienced a thumping vibration on my right wheel when cornering left under load (taking a sweeping corner). Differential fluids changed, no change in vibration. Axle and wheel bearings are still original. Axle boots are ok on both axles no issues. I am not getting any audible rumble, grinding or chatter. When cold in the morning I feel like I am going over a rumble strip at 50-60mph and then it disappears aftern3-5 miles of driving, wheels are balanced and alignment is correct,
Mechanic is saying that axle shaft and bearings look ok to him and that perhaps my OE LSD is toast at this mileage. Not 100%. Anyone experience this type of thumping vibration..feels like wheel hop for sure. No thumping when cornering right and left rear is loaded. Thanks for any input you guys have.
Old Mar 4, 2026 | 01:37 AM
roadtalontsi's Avatar
10 C six trizzle
maybe a rear subframe bushing. Try doing some straight line launches and see if it actually wheel hops. I thought I had a blown shock when my car wheel hopped. It turned out the front bushing of the rear subframe (right side - passenger side) had blown and was starting to leak fluid. I can't say I experienced this noticeably while cornering but I'm also not on a track.
Old Mar 4, 2026 | 02:10 AM
SROC276's Avatar
2010 C63 P31 AMG
I actuallly just and all rear subframe bushings replaced to poly ones recently as part of rear diff seal replacement (they were leaking) and diff was dropped. Everything is essentially new in the back. The thumping vibration was present before and afte so hasn’t left.
Old Mar 4, 2026 | 09:21 AM
Phil_T's Avatar
C63 AMG Saloon
The cars are getting old now and yours has alot of milage, start looking at subframe bushes & all suspension arms. I can guarantee it will be one of those.
Old Mar 4, 2026 | 04:02 PM
HLG600's Avatar
2009 SL63 AMG
When cold in the morning I feel like I am going over a rumble strip at 50-60mph and then it disappears after 3-5 miles of driving, wheels are balanced and alignment is correct.
I'm assuming there was nothing of note in the fluid that drained out, and that you used the correct fluid for your differential.
What's interesting is that the latter symptom goes away once there's a bit of temperature in the car.
If it's just one side / one corner, have you checked and compared some of the basic suspension components like your shocks, springs, mounts, etc.
Old Mar 4, 2026 | 05:07 PM
SROC276's Avatar
2010 C63 P31 AMG
all have been replaced or upgraded over past year… ever had the issues after the work…just started happening
Old Mar 4, 2026 | 05:11 PM
SROC276's Avatar
2010 C63 P31 AMG
well the old fluid was dark s hell…replaced fluid with new…suspension, mounts and arms are essentially all new in the rear…yes the thumping is mainly on the right side of the car….very weird
Old Mar 5, 2026 | 07:38 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
When you say load. Do you mean lateral load (from cornering forces) or longitudinal load (from the application of power) or both?
If if both, what happens if no power is applied? (Incase it wasn't obvious. I'm not recommending you rapidly lift the throttle while in a high G corner)
Cornering forces on throttle vs not on throttle affects components differently.
Old Mar 5, 2026 | 09:50 AM
SROC276's Avatar
2010 C63 P31 AMG
Both……if not throttle applied no thumping on right side
Old Mar 5, 2026 | 12:37 PM
HLG600's Avatar
2009 SL63 AMG
I'd be double-checking the work if everything is new.
Could be that something wasn't torqued enough (or not pre-loaded before torquing, which is a requirement on a number of suspension components in MB cars per WIS).
Old Mar 5, 2026 | 07:54 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I know you mentioned the mechanic said the axle shaft looks ok but this really points to a bad CV. If it was my car, that's where I would start.
Bearing would generally make a sound with lateral load regardless if you're on throttle or not. It could just be more pronounced when under throttle load.
