C63/C63S AMG
Operating Pearls of W205
Old Jun 16, 2019 | 08:46 PM
  #101
Tuxdude's Avatar
2019 AMG C63S
Thanks cyberoth and Xec, your posts in the other thread helped clarify exactly how to bring this up.
Basically you want the screen to be off, the car to not yet be in Accessory mode. Pressing the Ignition button (without depressing the gas pedal) will bring up this animation before turning on Accessory mode.
You can bring up the animation using these two easy ways mainly (thanks again cyberoth and Xec):
- With the car locked initially, unlock your car, get inside, close the door, lock the car, unlock the car. After few seconds, when the screen is still turned off press the Ignition button (without depressing the gas pedal).
- With the car locked initially, unlock your car, get inside, close the door, wait for roughly a minute for the screen to turn off completely. After the screen is completely off, press the ignition button (without depressing the gas pedal).
Old Jun 21, 2019 | 09:36 AM
  #102
bob_ham's Avatar
2019 AMG C63S Coupe
Because I really want to go through some complicated routine and wait an extra minute when starting my car... I don't know why MB put this kick *** graphic in, and then made it nearly impossible to ever see under normal conditions.
Old Jun 22, 2019 | 04:02 PM
  #103
Harangatang's Avatar
C63S AMG
Has anyone found a hideaway stash compartment, you know, for like when you need to hide a ring, or cash or something....
Old Jun 22, 2019 | 09:01 PM
  #104
LessIsMore's Avatar
2017 AMG C63
Well, guess that all depends on the size of the "something" that you want to hide If you want it to fool an experienced thief (or someone) you would probably have to modify/create something custom.
Old Jun 22, 2019 | 10:34 PM
  #105
LessIsMore's Avatar
2017 AMG C63
The warning for side detection only sounds if you have your blinker on. Otherwise a red triangle will show in the mirror with no tone. Good reminder to always use your mirrors and blinker to pass.
Old Jun 23, 2019 | 11:18 PM
  #106
cyberorth's Avatar
2018 AMG GTR, 2017 GLS63, 2019 C63s
Inside center console there’s a shelf above usb connection area but a ring may pop out during driving. Look under the mat in the trunk where the tire goop is for some space. Also check out the rear armrest if you have a sedan.
Old Jun 27, 2019 | 12:42 PM
  #107
selenite_C63s's Avatar
2017 C63s AMG, 2020C300, 2011 G55 AMG
I figured this would be the appropriate thread to ask this question.
Does anyone know how, or if you can turn the media/navi screen off at night without stopping music, etc. I know you can press down on the scroll that adjust the volume to turn the unit off but that shuts off your music as well.
Anyone know?
B
Old Jun 27, 2019 | 03:32 PM
  #108
Spectre-13's Avatar
2019 C63 S Selenite Magno Grey
Originally Posted by Spectre-13
This is true, I have the whole AMG carbon aero package and the trunk opening/closing feature IS on this car. I just haven't been able to get mine to work lately but I think it's more of a setting issue that I haven't quite figured out yet. I'll do some testing later to see why it doesn't seem to be responding lately.
2019 AMG Carbon Package 2
The kick method worked for me yesterday. Maybe I just need to work on my kicking technique.
Old Jun 27, 2019 | 03:49 PM
  #109
Spectre-13's Avatar
I haven't tried this yet but apparently, you can activate the "Brake Hold" function without pressing the electric brake hold switch on the dash. With the vehicle brought to a complete stop using the brakes just give the brake pedal an additional push and that will engage the brake hold function. You can then take your foot off the brake pedal and the car will hold it's position even though the transmission is in drive (regardless of being on incline/decline). When you are ready to go just press the gas pedal and the brake will automatically release.
How to use Brake Hold
Old Jun 27, 2019 | 03:53 PM
  #110
mo11's Avatar
2017 C43
Anyone know?
B
Press Vehicle Menu (car symbol) button, pull down on scroll wheel, it should bring up sub menus at the bottom of the screen. Choose, Display Off.
Old Jun 27, 2019 | 04:08 PM
  #111
Thank you - very much appreciated
Old Jun 27, 2019 | 04:52 PM
  #112
Tuxdude's Avatar
2019 AMG C63S
You could also add "Screen Turn Off" as a Favorite (at least in the facelift models). This was part of the default favorites list and is quite useful and easy to access. I add other things to favorites such as "Engine Data", "Parking Camera", etc.
Old Nov 13, 2020 | 01:18 AM
  #113
glhansenjr's Avatar
2009 SL 63 | 2009 C63
not seeing the eye bolt in my 2009 c63
Old Nov 17, 2020 | 03:17 AM
  #114
Kurzweil's Avatar
C63 S AMG Cabriolet
I'm not finding a tow eye in my trunk either, but that could be because it's a cabriolet (2020 C63 S). Though I haven't checked too thoroughly.
The hands-free "kick" trunk release doesn't work for me either. I tried 10 times the other day, and 10 times again this evening. I even watched a couple videos to make sure I was doing it right. lol I wonder if I'm missing a special technique, or it's because I have a cabriolet?
Fantastic thread, though. Hopefully there are more tricks still to be contributed!
Old Nov 17, 2020 | 10:50 AM
  #115
ShaneN.'s Avatar
2018 e63s edition 1
I'm not sure if this is your issue but if you lock the car by pressing the lock button more then once, it will kill that function as well as the ability to open the door without actually pressing unlock on the fob.
Old Nov 17, 2020 | 02:12 PM
  #116
Kurzweil's Avatar
C63 S AMG Cabriolet
So far, I've only been locking it by touching the outside handle, but that's very good to know about double-locking.
I've just checked the list of standard features my car has, and nothing about the trunk is mentioned, so I wonder if I don't have it for some reason.
Old Nov 17, 2020 | 05:15 PM
  #117
Kurzweil's Avatar
C63 S AMG Cabriolet
I made a wonderful discovery today about my 2020 C63s...it can play FLAC files! (FLAC files are basically high-definition "lossless" audio files, for those unfamiliar.) That was a shock to me, because even iTunes can't handle FLAC files. In reading threads about HD music streaming services, I thought I might as well check the manual about supported files, and sure enough, FLAC is listed. I was still a bit dubious, but I threw a bunch of my FLACs on an SD card, and they worked, sounded great, and I was able to skip through tracks instantly!
It was able to randomly mix the assortment of files I'd put on there, but I'd love to hear any tips you guys might have vis-a-vis organizing collections or perhaps using playlists. I plan to buy a 256-512GB SD Card, but I imagine that could get unwieldy (I have a very large collection), so I'm curious what others are doing to play media files by genre, etc. But for now, I won't look a gift horse in the mouth, I'm just glad it works!
