C63/C63S AMG
Inoperative Assist Functions?
Old Jan 7, 2016 | 12:25 AM
NTRacing's Avatar
2016 C63 AMG
Well... she is going back to dealer for service again.
Pre-safe and Assist functions stop working in the rain. Even light rain. Anyone else seen this problem?
Old Jan 7, 2016 | 06:00 AM
ole85's Avatar
c63s
i had the same thing have you had a hell aliment done
Old Jan 7, 2016 | 08:11 AM
AHI's Avatar
AHI
AMG GTR
All my assists shut down in the rain. I don't think this is anything unusual.
Old Jan 7, 2016 | 09:16 AM
bra10j's Avatar
Aston Martin, Porsche, Alfa Romeo, Land Rover & Mercedes
That is unusual. All the assists should work in all weather. Mine do in the AMG and in the Range Rover.
Old Jan 7, 2016 | 10:41 AM
cyberorth's Avatar
2018 AMG GTR, 2017 GLS63, 2019 C63s
It's been raining hard in SoCal! and no assist problems reporting.
Old Jan 7, 2016 | 01:54 PM
Dasani's Avatar
2020 C63s Coupe, 2016 C63s Sedan
Been raining here for the past couple of days and no problems.
Old Jan 7, 2016 | 02:45 PM
texasmade's Avatar
2016 C63S AMG
The drought is finally ending! At least somewhat...
Old Jan 7, 2016 | 11:51 PM
cyberorth's Avatar
No worries we'll find something else to complain about.
Old Jan 8, 2016 | 02:29 PM
ole85's Avatar
c63s
i got a wheel aliment and they had knock some wire loose which caused all of those codes up
Old Jan 10, 2016 | 09:17 PM
JPMBenz's Avatar
17 C63 S Coupe
Sometimes a near radar while driving, will cause everything to show "inoperative". Take it to your dealer to have it checked.
Old Jan 11, 2016 | 01:52 AM
ole85's Avatar
c63s
sterring assist module was my problem
Old Jan 13, 2016 | 11:49 PM
NTRacing's Avatar
2016 C63 AMG
Here is the update from my dealer. I was seeing this problem, mostly when it rained. Then, the day I drove it to the dealer, it was having the problem even without the rain. They saw the issue but did not see any codes to help find the problem, so it took them some time to figure out. They hooked up tester while on a drive and found that on right turns there would be signal issues.
They traced the issue to the wiring harness resting on sharp metal and found a wire chaffed under the right front fender. They fixed and protected the wire and seems all good now.
See picture.
Old Jan 14, 2016 | 04:04 PM
Rippe's Avatar
polarwhite AMG C63s W205
Several security related systems down due to a problem with a single wire.
This should be subject to recall and check.
Old Jan 14, 2016 | 08:05 PM
Sbpsu354's Avatar
2016 C63 S
Where are those wires? I'd like to check mine
Old Jan 14, 2016 | 08:54 PM
theclutch's Avatar
C8, FF, C63S, 911 C4S, GTI, E350, Boxster S, 355, Esprit S4, Vantage, S5, Z4, M3, Miata, A4, 325is
OMG....NTRacing, thanks for posting! Can you tell us where this wire is?
Old Jan 15, 2016 | 01:37 AM
NTRacing's Avatar
2016 C63 AMG
Per the dealer tech notes; they removed the right front wheel and fender lining to access this connector.
