AMG C63s Tire Size increase
Whats everyones thoughts on this?
My wife just bought a new W205 C250 AMG line for her work car, I was just going to fit the original AMGCross Spoke wheels and tyres to it once I've sourced new wheels for the C63S if there's no off set issues.
I'll look into fitting the 265's to the front but feel free to chime in everyone with your comments.
Have you tried them on track or on high speed(240+kmh)?
I'm looking to do the same with my c63s but use Michelin Pilot Sport Cup 2.
they may fit (not rub) but the rim is too narrow and will pull the bead in and the tread will not be flat with the correct pressure.
go to tire rack and do some research.
I know you are trying to save the cost of new rims but it is usually better to buy the correct width and offset for the tire size you want to run and not try to do with the wrong one just because you have them.
20x9 +41 i believe 255 tire
20x10 +55 and 275 tire
-- id love to get a 295 on rear with a wider rim too. but what should offsets be to make it all work then? i may switch to 19" rims too
I have no idea why the car didnt come from Germany this way..maybe due to costs or EPA Mileage figures, who knows, but the larger tires make a noticeable and significant difference in performance and traction.
If you own a C63S then you know it is a dance between how hard to touch the pedal and getting the tires or back end to spin out. With the larger tires (I have 285's) this is not nearly as easy to do and you have to intentionally mash the pedal to get it to spin out.
I wish I changed them the day I bought the car..
comparing sizes that other have confirmed on their MB Wheels (295/30 285/30 and even 305 on customs) the size of 295/35 should be fine. Only one way to find out I guess.
Also looking at doing it right and getting 19x10 wheels later after the wife approves, this way the rubber can be transferred.
