C63s Coupe Command Issue
I have taken the car to Birmingham Central 3 times now, their technicians don't have a clue whats wrong with, yet persist on software patches resolving the issue. I'm beginning to think if their technicians are useless or if the problem requires the whole unit replacing.
Has anyone else experienced the same issue?
To make matters worse the dealership has given me a E220d to drive as they do not have any other AMGs available. Absolutely shocking.
after doing some 15k km in my sedan, my whole system (navi, radio, media, camera, tele) would turn on and off intermittently. I would be driving on the highway and my media would be on, all of a sudden its a blank screen and it will restart. after several restarts it will do the same thing but wont turn on, and the command screen will only be black. called my service advisor and he told me that apparently this happens to many MBs when you have any USB/Charger/ any device connected to the infotainment system via the sub/ socket ports. he told me to always remove whatever is connected through those ports whenever I turn off the car. once I reached home, I went and removed everything from the ports and turned off the car, and next day in the morning turned on the car drove to work everything was perfect. nevertheless, I didn't continue doing so because I got bored of plugging and unplugging
so far, it did not happen again, but at least now I know what was causing that problem...
In the meantime, the dealership have provided me with a C63 Sedan / Saloon as loan car. But we are still due to discuss compensation.
The second instance, the screen was working but it seems nothing else was. Backup camera did not engage, I could not change the drive mode via middle switch, and I think the AC was not blowing cold air (I wasn't in the car long enough to be able to know for sure).
Both times I would get out of the car, turn off and lock, then get back in and everything was normal.
I hope you are all fine!
I changed the battery from my c63s and after the change my command doesn’t work anymore. My 360 camera, my radio/Bluetooth and my navigation don’t work. Also I got an normal c class interface on my command. Maybe someone has any idea of the problem and can help me with that? Got the code B238a00
thanks in advance !!
Sick of these Mercedes/AMG & all issues that plague this 205. Never, ever had so many issues with other premium brands in my life.
Last edited by Jimmy_c63s; Aug 4, 2022 at 06:58 AM. Reason: Added some more details
