C63/C63S AMG
Coupe is losing individual setting?
Old Nov 9, 2016 | 02:22 AM
jkob5's Avatar
19 E63s
My C63S coupe has lost the individual setting about 5 times, anyone else have this? I will try to put the car into individual, but it doesn't let me go "up". If I turn the car off and then on again, I can go into individual, but the settings are lost, they return back to stock, and I have to redo them. Getting annoying. Anyone else have this problem?
Old Nov 9, 2016 | 03:04 AM
SBH-'s Avatar
C63S 2016
first time I hear about this ... unusual
Old Nov 9, 2016 | 06:51 AM
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
Haven't faced this problem yet... Might be a software update issue
Old Dec 17, 2016 | 08:49 AM
dviolagis's Avatar
2018 GLC 63
I have the same problem. Have you had this issue resolved?
Old Dec 17, 2016 | 05:25 PM
jkob5's Avatar
19 E63s
Unfortunately no, I asked a mercedes master tech about it and he had no idea how to even go about looking into it, as everything else that is memory stays and it's only intermittent.
Old Dec 17, 2016 | 05:27 PM
Mbm6f's Avatar
09 C63 AMG
That's really obnoxious. Not something you should have to deal with on a new almost $100k car.
Old Dec 19, 2016 | 08:22 AM
auditoamg's Avatar
C63s
Same problem here!!!!
Old Dec 19, 2016 | 11:49 AM
ignomini's Avatar
MG PB, MG Midget, Triumph TR4, Morgan 4/4, Mustang, Audi R8
Did you go for the Mid City Engineering mod, or is your car still stock? Mine arrives next week, and I expect to be using individual mode all the time. Important to know why this is happening.
Old Dec 19, 2016 | 11:18 PM
auditoamg's Avatar
C63s
Yes, but they are unrelated. The mod doesn't touch memory. It only puts it into individual mod, the car takes care of the rest, I believe...
Old Dec 20, 2016 | 12:05 PM
fresnobrianb's Avatar
2005 C230
This used to happen to my sedan all the time. Individual settings would be erased sometimes and other times I would not be able to access the individual settting. It went away. Can't pinpoint it to a service, it just stopped. No MidCity mods.
Old Mar 24, 2017 | 05:32 AM
dviolagis's Avatar
2018 GLC 63
Any have resolution on this?
Old Mar 24, 2017 | 02:18 PM
jkob5's Avatar
19 E63s
No but I have a little more info about it. Sometimes when I start the car, the screen stays black for about 10 seconds. During this time, some of the interior dash lights are not on and the green light on the eco button doesn't turn on either. When this happens, I can't get into individual mode. If the car is turned off / on again, I can get in but individual settings are erased. So it has something to do with some of the car electronics not being initiated correctly on some starts, no idea what the reason is though. My car will be fine for a couple of weeks and then do it everyday for a couple of days.
Old Mar 24, 2017 | 03:18 PM
dviolagis's Avatar
2018 GLC 63
Your discription of the problem is identical to mine. You describe it perfectly.
I sent your description of the problem to my dealership so they can figure out the solution.
Old Mar 25, 2017 | 01:01 AM
AmexWest's Avatar
W205 C63S
My 2017 C63S occasionally drops the Individual settings exactly as OP says. In 3300 miles, it's probably happened 4 times.
Old Mar 25, 2017 | 02:38 AM
jkob5's Avatar
19 E63s
4 days in a row
Old Mar 25, 2017 | 03:56 AM
td328's Avatar
C63s coupe
I have had one off incidents in my coupe which resolve themselves when shutdown and restarted.
radio device not found.
heads up not working.
mirrors don't fold out when I unlock the door.
had my car almost 3 months. I hope that's it they say all things come in 3
Old Apr 14, 2017 | 05:59 AM
dviolagis's Avatar
2018 GLC 63
Dealership diagnosed problem and determined I need a new COMMAND Control Unit. They need to order part. I will let you know if that fixes problem.
Old Apr 14, 2017 | 10:14 PM
auditoamg's Avatar
C63s
Dealer blamed low battery voltage, which I know is bull****. My coupe has also lost radio settings, parking lights and climate control presets
Old Apr 14, 2017 | 10:27 PM
jkob5's Avatar
19 E63s
I think your car is the only one losing all those other things, yours might actually be a battery problem
Old Apr 14, 2017 | 11:58 PM
auditoamg's Avatar
C63s
Maybe, but I had to hunt to find they had been lost. And when I say lost, they just reset and the CF card index had to be constantly redone before playback....
Old Apr 18, 2017 | 11:14 AM
Tvall13's Avatar
C63S AMG Coupe
I have the same issue. It seems pretty random but sometimes it happens when i remote start the car with my phone. I mentioned it to my dealer and they are going to look into it next time i'm up there.
Old May 13, 2017 | 02:32 PM
dviolagis's Avatar
2018 GLC 63
Coupe is Losing Individual Setting
I just got my car back. Paper work reads as follows: Internal Fault PTSS Case #95139. Replaced Command Unit. Part number DVD-ROM 205-827-80-00 and Control Unit 205-900-86-30. So far so good not problems.
Old May 13, 2017 | 06:53 PM
auditoamg's Avatar
C63s
Does this imply there's now a bulletin??
Old May 13, 2017 | 07:34 PM
dviolagis's Avatar
2018 GLC 63
Not sure. I just *****ed and complained enough to get it fixed.
Old May 15, 2017 | 02:13 AM
Gunsmd's Avatar
2017 Mercedes C63s coupe
Individual settings
I have same issue with random loss of my Individual settings. Had service tech look at it. They were unable to duplicate it so they had no idea. Apparently, no one else locally has reported the same issue.
