C63/C63S AMG
C63S Coupe wheel sizes and offset
Old Dec 8, 2016 | 10:47 AM
masar's Avatar
Shelby GT350R, Ford Raptor
I just ordered Coupe 63S Edition 1
Anyone knows parameters and offset of 20/19 multi spoke wheels for C63 S Coupe?
I just know its 10.5 x 20 + 9 x 20 but i am not even sure about these numbers. But no info about offset.
I want some aggressive aftermarket wheels with flush look without need to use spacers.
Old Dec 8, 2016 | 10:59 AM
juse's Avatar
c63 coupe
front 255/35 19 x 9j et 25
rear 285/30 20 x 10,5j et 57
Old Dec 8, 2016 | 03:36 PM
masar's Avatar
Old Dec 8, 2016 | 07:16 PM
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
Congrats mate, when do you pick it up?
Looking forward to seeing the new beast and the new wheels.
Have you decided what wheels and brand?
Old Dec 9, 2016 | 04:19 AM
masar's Avatar
Thanks man.. I should pick it up March 2017.
I am searching for the right wheels. Looking at OZ racing, BBS... and some others. Basically i want 11x20 + 9,5 x 20 which is 0,5 inch wider compare stock wheels.
This is my thoughts.
Stock set up
10,5 x 20 ET 57
9 x 20 ET 25
My plan
11 x 20 ET35 - this should be about 28 mm wider compare stock (basically replaces 28 mm spacer)
9,5 x 20 ET10 or 10 x 20 ET15 - this should be about 22-23 mm wider compare stock
Not sure if my calculation is correct, have to check with some wheel guys... And and maybe its too much... however these are my initial thoughts.
Old Dec 11, 2016 | 06:55 PM
Sanch's Avatar
Stock set up
10,5 x 20 ET 57
9 x 20 ET 25
My plan
Very nice, looking forward to seeing the set up!
Old Dec 12, 2016 | 08:08 AM
masar's Avatar
Actually i just got maybe crazy idea... anyone tried to install stock 20" rear wheel on front? Its 10,5 " rim so i doubt it will fit but maybe ??? with different tire 265...???
I really like stock 10 spokes AMG performance wheels with the lip. As was discussed before, bigger lip makes the inner part too small especially on front 19" wheel.
So i am thinking to change order of my car and order amg performance wheels. I would put rear 20" wheel on front and i would order 2 pcs of AMG GT R rear wheels to use on rear. They are 12X20 in same design.
Basically i would have 10,5 x 20 front + 12 x 20 rear - aggressive setup using original 20" amg perfomance wheels. BTW i want lower the car with KW HAS by 2 cm all around.
Old Dec 23, 2016 | 05:42 PM
MarkC63's Avatar
2016 C63 Wagon
The 20's don't fit on the front. They would hit the suspension. Pretty sure I got the numbers right...http://www.willtheyfit.com
Old Feb 8, 2017 | 04:59 AM
Ray_c63s's Avatar
c63s coupe
Ive picked up a set of:
20x10 et 20 hope i have no issues
Old May 15, 2017 | 09:27 PM
ruey220's Avatar
ml55, Ml63, Porsche, C63S ED1
did you ever put these on? I am looking at going 20's all around and am considering a similar setup 20 x9.5 in front 20 x11 in back.
Stock set up
10,5 x 20 ET 57
9 x 20 ET 25
My plan
Old Jun 17, 2017 | 04:12 AM
MUZZIE's Avatar
2017 AMG C63S Coupe , Range Rover Sport
What is the maximum width we can go on a C63S coupe, with 19"front and 20" rear standard rims ?? Can we go 275/35/19 front and 305/30/20 on the rear without any issues ??... What brands are recommended ??.... Hopefully someone has tried this exercise .
Old Jun 22, 2017 | 12:55 PM
auditoamg's Avatar
C63s
On OEM rims, I think this would look pretty "chunky" as the tire would have a LOT of meat over the rim lip/edge.
I am running 265s and 295s and it's perfect, and one size wider than OEM tires.
The OEM sizing has a bit of a stretch to it that I don't like, so if you go even one size wider than I'm running it would probably push the tire out to much over the rim - IMHO.
A2A
Old Jun 23, 2017 | 01:57 AM
MUZZIE's Avatar
A2A
Thanks for that ...... I think the 265s front and 295s rear is a good look but I think someone said you could go 275s and 305s without issues .....but I cant remember if that was on standard Coupe Rims
Old Jun 23, 2017 | 02:54 AM
Sanch's Avatar
You definitely can go 275/ 305 on stocks.
However it will look square and chunky... if you like that look go for it.
I had 295s they looked ideal with a 12mm spacer.
Here is an example of a 305 tire on a 10.5" wheel - Obviously, it will not stick out of the guards like this... but it will look chunky, the fronts especially.
Old Jun 23, 2017 | 03:45 AM
MUZZIE's Avatar
Does it rub with these sizes ????.........on another note .One positive is that it will protect the rim from gutter rash when (if) the misses drives it ....
Old Dec 20, 2019 | 06:02 PM
SilverBullet18's Avatar
C450,GLC 63,VW GTI
reviving this from the dead. the above tire has a different spec than most and has a very bulbous and chunky sidewall.
someone on the forum fit 305 pilot sport 4s and it doesnt look like the above. its at the limit but looks decent and meaty. not overlapping or balloon like
