Secondary Cat delete on C63s Perf Exhaust
My shop replaced mine with bent 3” 304 stainless and it took roughly 1.75 hours.
Pm if you need a good shop in SoCal.
🔹 Hi tech mufflers in Darlinghurst: $1000
🔹 International Auto-haus in Rockdale $900
🔹 Autowerks Beverly Hills $800
🔹 Western Mufflers in Fairfield $250
You get what you pay for though and International Auto-haus is where I got mine. I chose them instead of the cheaper guys because they do all the work on my car and will do a good job without cutting your heat shield or any fu*king around.
How good is it though? Car can be so quiet when you want it to then totally transform into a riot with some downshifting and acceleration 🙉
It's rude.
It's rude.
i ask becasue im coming from another car a 6.2L V8 an instead of doin a whole cat back exhaust system i just cut the mufflers out an put straight pipes to the exhaust tips. cost 0$ and REALLY wakes up the sounds of the car. def more burble an pops but it just raises the exhaust volume by alot, sounds better, deeper an more powerful overall. im wanting to see if it does the same with the C63. or if its too raspy/poppy..... any info helps thanks.
This sounds like a massive headache just to do a secondary delete. So I have come up with another plan, I am in the process of buying a used set of pre facelift OEM downpipe. Once I have that, I will be gutting OEM Secondary CAT, but this creates it’s own issues. An empty secondary cat is going to create a lot of back pressure (counter intuitive I know). So, to get around this, I will have to weld a straight pipe into the secondary cat. Once all this is done, I will install it back into the car and not visit the dealership for a few months until the weld browns and blends. After that they should not technically have any idea.
turbos -> primary cats -> secondary cats -> valved h-pipe -> rear mufflers (valved on performance exhaust)
Options to make louder are to remove one or both cats and/or the rear mufflers. Because of the turbo adding silencing, removing the secondary cats on the W205 is akin to removing the resonator on the W204 (which went primary cats -> secondary cats -> resonator -> rear mufflers)
Here's Weistec catless downpipes as an example vs stock
I just got my mufflers deleted today and damn I wish it did have resonators car is stupid loud. Fml getting resonators installed soon hopefully
