C63/C63S AMG
Exhaust Rattle C63S coupe.
Old Apr 24, 2025 | 07:11 PM
  #401
Jimmy_c63s's Avatar
Originally Posted by KristiyanPetrov
hey @Jimmy_c63s tomorrow im going to grease my muffles flaps on my c43, so to choose 3 holes from total 4 on each side and through the cradle holes to put on each hole 5ml with syringes? (initially i thought high temp copper spray it will work good as the one you suggest) but now im thinking if i should fine somewhere in my city something like yours you used
p.s. should we clean with brake cleaner or something else or just applying the grease?
Are your flaps rattling?
No need to clean anything unless there's mud or crud inside.
The Mercedes techs don't clean, they just hoist the car up and stick the nozzle of their little paste tube into the holes and squeeze. I've watched them when my car was new and I use to bring it in for "warranty" to fix the rattle.
Went so many times I even pinched the paste tube out of their bin and that's how I found out what they use.
But that Mercedes paste is rubbish hence why so many people still get the rattle after a few days when they apply it.
Use any brand of copper grease (copper slip) as long as it's not spray.
Old Apr 24, 2025 | 07:26 PM
  #402
W205C43PFL's Avatar
For context: https://mbworld.org/forums/c450-c43-...bricating.html
Old Apr 25, 2025 | 02:08 PM
  #403
KristiyanPetrov's Avatar
C43 AMG '17 / Stage II
yes i do get some rattle
just placed left/right side on each hole (3of them) 5gr/ml high temp copper grease and will report after few starts how it feels, thank you for the feedback
not sure when i bring in stealer for service if they do that at all because i never saw in the invoice grease charge or anything else or maybe is included in the service who knows haha
Old Apr 25, 2025 | 02:57 PM
  #404
rick hesek's Avatar
2014 CLS550
Originally Posted by speedpeddler
Anyone else got it?
With the exhaust in "open" mode there is a distinct metallic rattle coming from the drivers side under a load that's driving me crazy. Sounds very much like the baffle or flapper in the exhaust is rattling around.
Anyone else having this issue? What did you do about it?
Haven't been to the dealer about it yet but will take it up on the first service.
I had this same noise (vibration) in my car, mostly on deceleration.
It turned out to be the exhaust heat shield, which had come loose.
Dealer fixed it, no charge.
Old Apr 25, 2025 | 03:20 PM
  #405
W205C43PFL's Avatar
It was touching something?
Old Apr 25, 2025 | 08:33 PM
  #406
Jimmy_c63s's Avatar
They don't do it routinely. They'll only use the paste if you have the rattle and complain about it/make a warranty claim.
How did you go with the copper grease?
Old Apr 28, 2025 | 09:33 AM
  #407
no warranty on my side anymore
i think have a bit better tone exhaust now when greased, will do it one more time in next few weeks/months, just don't understand how the grease change the rattle as when they're opened, it shouldn't cause any vibrations isnt it or is because the spring inside?
Old May 23, 2025 | 12:22 PM
  #408
Eldraco's Avatar
C43, now C63
Just fixed my C63 with the death rattle completely free and in 2 hours.
tools needed, 8mm socket and knuckle joint
2 sets of grips
remove H pipe actuator from exhaust mounting, and remove the spring inside. If you have the rattle it will most likely be quite flat, remember the position of how it was situated in the actuator.
Now, stretch the spring so that it is more of a conical shape, rather than flat so that there is more resistance when pressing down on it.
Re install the spring and actuator on the exhaust and Bob’s your uncle, Fanny’s your aunt no more rattle.
I couldn’t believe Mercedes “engineers” wanted £6k for a new exhaust, and all it turned out to be was a over flattened actuator spring, which if you want to get a new one wouldn’t cost no more than £3.
mine now sounds awesome, more pops and bangs and sounds far better in higher rev range than before.
Old May 23, 2025 | 01:38 PM
  #409
W205C43PFL's Avatar
2 sets of grips
Old May 23, 2025 | 08:55 PM
  #410
Jimmy_c63s's Avatar
2 sets of grips
Congratulations. Next time help out the boys and take a pic or two if you can (I honestly don't even know what conical means).
Old May 23, 2025 | 09:35 PM
  #411
W205C43PFL's Avatar
Something like the lug bolts as in cone seat?
Old May 23, 2025 | 09:37 PM
  #412
W205C43PFL's Avatar
https://cdn.shopify.com/s/files/1/05...g?v=1645741248
Old May 23, 2025 | 09:38 PM
  #413
Jimmy_c63s's Avatar
Yeah! Sounds right I wonder what that would look like as the spring 🤔
Old May 23, 2025 | 09:56 PM
  #414
W205C43PFL's Avatar
Good question 😅
Old Dec 23, 2025 | 05:48 PM
  #415
Stunnaboy63's Avatar
C63s
2021 C63s Exhaust Rattle
have a 2021 C63s which is downpipe and tuned but cpc not done, recently my exhaust has been rattling and I swapped out the 3 actuators (2 rear 1 center) but the rattling hasn’t gone away I am thinking it is either the flaps that have failed, the mufflers, or valve module. If anyone has any solution please let me know. Noise comes from the center and rear.
File Type: mov
Old Dec 23, 2025 | 07:18 PM
  #416
Roysup's Avatar
2018 C63S AMG Coupe, 2019 Jaguar F-Pace SVR
@Stunnaboy63 seems like you light have play in the "in and out movement" of the valve flap. The new actuators only affect the twisting action but not the in and out end play. The two fixes are to pack the underside of the actuator solenoid cup area with copper grease... The second is to stretch the spring so that it is more of a cone shape, rather than flat so it pushes in on the valve assembly when you re attach the actuator. The third (most unrealistic) fix is to replace the exhaust or at least the valve sections.
