C63/C63S AMG
new C63S but no backfire in S+ or RACE...
Old Apr 23, 2017 | 06:14 PM
littletiger80's Avatar
C63S
love the new car but what really annoys me is that there is no backfire in S+ or RACE mode! the exhaust sound is pretty loud when engine speed picks up from 1K to 4K (i would say VERY loud) but there is no backfire when i shift down, not a single one in S+ or RACE mode. I played with the invividual mode as well as the exhaust controller with no luck.
is this normal for a new car? Called the dealer and was told he will have a look when the car is due for the first rear LSD oil change when the car hits 1800 miles.
thanks!
Old Apr 23, 2017 | 06:43 PM
ggonzaga's Avatar
2020 E63S
Do you have the AMG performance exhaust?
Old Apr 23, 2017 | 06:45 PM
C63S
yes, it seems to be working fine. I can hear the difference when i turn it on and off.
Old Apr 23, 2017 | 06:50 PM
ggonzaga's Avatar
2020 E63S
That's odd, my car backfires when I let my foot off the gas in S+ mode with the valves open. Maybe bad gas? The car is brand new, so maybe it's just not letting you rev it high enough for the backfiring to happen. Be mindful of the break-in period!
Old Apr 23, 2017 | 07:02 PM
Palpatine's Avatar
2016 C63s Sedan
Revving to 4500+ rpms in 2nd gear and quickly lifting your foot off the gas pedal, in S+ or race mode, should definitely yield multiple backfires.
If not, your car may have the old software... But I'd still think you'd be get something.
NO backfires?
Old Apr 24, 2017 | 07:08 AM
nobbyv's Avatar
2016 Cardinal Red AMG C63 S
Not sure what's going on with your car, OP. I get tons of burbles and pops in Sport+.
Old Apr 24, 2017 | 08:50 AM
supaer's Avatar
Mercedes C63s
Wait.... What do you meant the AMG Performance exhaust, i didnt know there was an option not to have the performance exhaust?
Old Apr 24, 2017 | 10:33 AM
nobbyv's Avatar
The AMG Performance Exhaust is a $1200 option that gives you a button to control some valves in the exhaust that make it louder.
Old Apr 24, 2017 | 10:40 AM
Palpatine's Avatar
2016 C63s Sedan
You'll primarily see sedans without the PE. I believe coupes come standard with it... Even though it shows as optional equipment on the sticker.
Old Apr 24, 2017 | 10:54 AM
supaer's Avatar
Mercedes C63s
just looked into it... Standard on the c63s coupes
Old Apr 24, 2017 | 11:19 AM
Vic55's Avatar
Administrator
Its a 1250 option stateside... I saw several coupes with out it when I was doing a locator search for my options using the dealer internal system.
Old Apr 24, 2017 | 11:40 AM
Souriall91's Avatar
2017 c63 Amg s (almost)
I don't have the PE in my sedan and I have no issues with pops and bangs in S+. Never have.
Old Apr 24, 2017 | 01:19 PM
Mr. J's Avatar
C450, GLC43
Probably Needs The Software Update
OP,
Check out this thread.
https://mbworld.org/forums/c63-c63s-...e-upgrade.html
Bring it in and have your service manager check the software version. You shouldn't need to wait for LSD service. It either has the newest software or it doesn't. If its not the software then it's probably the valves or valve controllers.
And like Palaptine said, if you drive in 2nd gear and goose the throttle a little then quickly let off you should always get the crackle and pop in S+/R.
Old Apr 24, 2017 | 02:58 PM
Vic55's Avatar
Administrator
Not sure why you quoted my post, I was speaking to the exhaust as being an option on the C63S.
Old Apr 29, 2017 | 06:43 PM
C63S
thanks for all your input guys. I brought the car to the dealer and it went through a check. No new software is available for my car (March 2017 Production). However the guys agreed that my car is lack of typical pops and bangs in S+/Race. We tried 3 times in Race mode together and lifted pedal at 4500rpm (given in break-in period). Only one pop was generated once and no pop at all in other 2. He said he had expected "multiple". on the flipside, he said the exhaust sound is much louder than he expected during the acceleration. He suspects AMG may have changed the engine software again although he is not aware of any officially. (this is his first 2017 production C63 drive so he cannot compare this to other March 17 production c63. the demo car in the dealer ship is july 16 production car with upgraded software.). he tried to "update" the engine software to the Nov version and the system didn't allow this version to be installed on my car... He will ask technical support in AMG and get back to me. btw, this car is in UK, if this matters...
Old Nov 9, 2018 | 04:24 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
deleted...posted in the wrong thread. scrolled too far down.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Nov 2, 2021 | 02:40 PM
SafC63s's Avatar
c63s
Hi, did you sort this issue out? Unless I'm going mad, I think I have the same issue. Mines a 2017 c63s.
Old Nov 3, 2021 | 08:59 AM
djprov431's Avatar
2021 C63S Coupe
A four year old thread --- ehhhh
Old Nov 3, 2021 | 10:42 AM
SafC63s's Avatar
c63s
So??
Old Nov 3, 2021 | 12:17 PM
djprov431's Avatar
2021 C63S Coupe
Originally Posted by SafC63s
So??
There's likely a thousand things that have changed since then and the OP never stated the resolution (Euro spec car as well - but your profile is empty so no clue if that matters)
