C63/C63S AMG
2017 Coupe Body Defects from Factory????
Old 05-23-2017, 04:17 PM
auditoamg's Avatar
C63s
Ok - see attached pictures.
Just noticed these two defects - only 3k on the car.
They are clearly from the factory.
Dealer has stated that ALL of their AMG Coupes have the same issue.
So, help requested:
Can anyone with a 2017 and a 2018 (if available) Coupe look to see if you have the same defects on the lower driver side a-pillar, and the right front fender where it meets the door???
Attached Thumbnails 2017 Coupe Body Defects from Factory????-img_0585.jpg   2017 Coupe Body Defects from Factory????-img_0586.jpg
Old 05-23-2017, 05:22 PM
Sawadeeka's Avatar
AMG C63s Coupe
So, help requested:
Can you state exactly what the defect is? Are you referring to the alignment of the body panels? If that's the case, none of my panels align properly like it does on any mass-produced cars (i.e. Honda, Toyota, etc.). For example, driver side door doesn't align with the left quarter rear panel, and it almost looks like it's been in an accident. My hood is grossly misaligned with the front plastic grill. When I noticed this when I picked up my car in Sindelfingen, the guy said it's because the entire car is put together like an after-market mod (i.e. front hood extension).
Old 05-23-2017, 09:15 PM
auditoamg's Avatar
C63s
Yes, the fender is a panel alignment issue, while the pillar is a paint issue....
Not worried about the paint issue, but the fender fit to the door is an eyesore.... And, it's actually not alignment, it's a body panel shape issue... It's how it's flared!. Big issue for me.
Old 05-24-2017, 12:29 AM
hotdognobun's Avatar
C63S Coupe/CLA45
2017 c63s coupe
My hood in the front is lower than my front bumper but I made some adjustments with these adjustable knobs and it's ok now. I also went back to dealership to check other AMG Coupe and they had same alignment issue but notice most non AMG models were perfect. Oh well
Old 05-24-2017, 12:19 PM
auditoamg's Avatar
C63s
So - your right front fender is flush to the right door and right a-pillar. Can you check the junction of the right front fender to the a-pillar and door??
Old 05-24-2017, 03:05 PM
Uga Uga's Avatar
2021 C63S coupe
I have a similar problem with my Coupe.
Passenger Side (UK so left side)
The left side bonnet/hood is closer to the A pillar than the right by approx 2mm.
I will have it looked at when I take it in for the LSD oil change.
Old 05-24-2017, 06:02 PM
C63S Coupe/CLA45
Mine lines up even on both sides. i think when I had it wrapped when they put all my doors and panels back they did an alignment. Have you went dealership to check the other cars? I'm wondering where my car was made too maybe quality control is lower than in Germany? Here is a picture which shows lines pretty matched up
Old 05-24-2017, 07:17 PM
RDOCA's Avatar
2016 C63S Sedan
All the coupes made for the US are made in Germany but they have just as many problems as the US made sedans or the European sedans.
Old 05-24-2017, 09:33 PM
auditoamg's Avatar
C63s
This problem cannot be aligned.
Have you run your hand over the right door, starting under the mirror Ann's proceeding to the front fender???
It's hard to see but mine is at least 4mm off.
Old 05-24-2017, 10:56 PM
C63S Coupe/CLA45
Sorry mine is not off by that much. I can't believe Mercedes let your car leave out like that I am even bummed now cause I can actually visualize what you described.
Old 05-24-2017, 11:02 PM
C63S Coupe/CLA45
Trying to take picture to mimic yoursso you can see difference
Old 07-30-2017, 05:58 PM
Uga Uga's Avatar
2021 C63S coupe
Uneven hood gap corrected.
Attached Thumbnails 2017 Coupe Body Defects from Factory????-img_3638.jpg   2017 Coupe Body Defects from Factory????-img_3637.jpg
Old 07-30-2017, 11:50 PM
auditoamg's Avatar
C63s
Ok, what did they do?????
Can you send me copy of the dealer RO?
Quick Reply: 2017 Coupe Body Defects from Factory????
