C63/C63S AMG
c63 sedan tire questions
Old Jun 18, 2017 | 01:49 AM
xxxPaulxxx's Avatar
2020 AMG GT C Roadster
Right 9,5 in the front and 10,5 in the rear. You could also go with the Coupe rims and some spacers
Old Jun 18, 2017 | 03:58 AM
SJY's Avatar
SJY
c63s sedan
Originally Posted by xxxPaulxxx
I drive 265 30 19 and 295 30 19 Conti Sport Contact 6.. Got a lot more traction than the 245 & 265 Michelin.
ive seen a lot people running 265 and 285+, any rubbing problems?
Old Jun 18, 2017 | 04:01 AM
xxxPaulxxx's Avatar
front is 9,5 x 19 265 30 19 Off 27.. no problem and you could maybe go to off 25
rear is 10,5 x 19 295 30 19 off 50.. just on realy hard bumps with a lot of speeds it rubs just a bit. If you would go to off 52-53 there would be no rubbing problem
...got my car lowerd with a kw v3, so without aftermarket coilover off 50 should also work
Old Jun 18, 2017 | 04:19 AM
SJY's Avatar
SJY
c63s sedan
I'm thinking of buying a couple rim and put it on my sedan. have u done this before?
Old Jun 18, 2017 | 04:22 AM
xxxPaulxxx's Avatar
No but I just bought some coupe rims for the next winter season. Rear is 10,5 Off 57, with 5mm spacers that should work. front is 9,0 off 35 that would also work..you could take 10mm so that it looks better
Old Jun 18, 2017 | 05:51 AM
MarkC63's Avatar
2016 C63 Wagon
Have you got any photos or your sedan? I didn't think the coupe rear wheels would fit. The offset is about the same as the sedan, but they are an inch wider. I thought about 15mm more poke was about as wide as you could go. Really interested in your setup.
Old Jun 18, 2017 | 06:02 AM
  #32
xxxPaulxxx's Avatar
Sure but you have to thint that one inch would mean 1/2 an inch outside an half an inch inside. Here you got some pictures
Attached Thumbnails c63 sedan tire questions-img-20170509-wa0026.jpg   c63 sedan tire questions-received_1430583716997800.jpeg   c63 sedan tire questions-received_1430584283664410.jpeg
Old Jun 18, 2017 | 12:33 PM
  #33
SJY's Avatar
SJY
c63s sedan
hey Paul, do u have pics of ur sedan with the coupe 19/20 rim? Im thinking of getting coupe rims, it will be very helpful!!!!
Old Jun 18, 2017 | 12:34 PM
  #34
xxxPaulxxx's Avatar
No I just got 19/19 Coupe rims and never mounted them
Old Jun 18, 2017 | 12:38 PM
  #35
SJY's Avatar
SJY
c63s sedan
i see, do u think the 19/20 will fit the sedan??
Old Jun 18, 2017 | 04:04 PM
  #36
xxxPaulxxx's Avatar
Sure from offset it would work but I did not calculated the wheel size
Old Jun 19, 2017 | 04:32 AM
  #37
SBH-'s Avatar
C63S 2016
I'm running 265/35 f and 285/35 r without any trouble !
Old Jun 19, 2017 | 05:47 AM
  #38
RobboAMG's Avatar
2015 C63s AMG wagon
Looks great ! What brand of wheel ?
Old Jun 19, 2017 | 05:19 PM
  #39
xxxPaulxxx's Avatar
Vossen Forged HC 3
Old Jun 20, 2017 | 01:53 AM
  #40
Mr. Pink's Avatar
W205 c63s AMG
Just ordered wheels, 19x9 +40 19x10 +60
Gonna run my stock 265/35 up front and now I'm trying to decide on rear tire size, thinking about opting for 295/30 R888r. I think i should be fine (no running) due to the conservative offsets. But will run 285s if i need to.... What do you guys think?
Old Jun 20, 2017 | 02:24 AM
  #41
Modio1234's Avatar
2016 C63S AMG
Should be fine with the r888rs. I have them in 295/30 on my stock 9.5 rims. The only problem I had so far was finding a installer that would install them.
Old Jun 20, 2017 | 05:56 AM
  #42
SJY's Avatar
SJY
c63s sedan
Hi there, I'm worried about the same problem. saw a guy from Instagram put 19f/20r coupe rim on a c63 estate, I believe those rims have the exact same size, width and offset with the coupe cross spoke rims.
can somebody confirm that the 19/20 coupe rims work on the sedan??
Old Jun 20, 2017 | 11:24 AM
  #43
Mr. Pink's Avatar
W205 c63s AMG
How are the r888r? I've always ran toyo tq radials but they don't make them in any size I can run lol.. Mainly worried about how they react in the wet
Old Jun 20, 2017 | 05:25 PM
  #44
Modio1234's Avatar
2016 C63S AMG
They were a little noisy in the beginning I either got used to them or they quieted down because they don't seem as loud anymore. As for the rain I only drove them in the rain once and they were fine at speeds around 35-45 while I was driving around town. Highway I would be a little sketched out about.
Old Jun 20, 2017 | 05:29 PM
  #45
Mr. Pink's Avatar
W205 c63s AMG
Meh. I think im just gonna send it. I dailyed my 800whp 135 on toyo tq and didn't ever have an issue in the rain. How much worse could they be, especially on more sophisticated traction system
Old Jun 20, 2017 | 05:30 PM
  #46
Mr. Pink's Avatar
W205 c63s AMG
Idgaf about noise, just turn the music up louder 😂
Old Jun 21, 2017 | 07:52 PM
  #47
Vertice's Avatar
2016 C63S AMG
Originally Posted by SJY
Hi everyone, I'm thinking of putting Pilot Sports 4s (front 255/Rear 275) on my c63 sedan. I'm not Familiar with the aspect ratio, should I go with 30 or stay with 35? and I'm running with the stock 19 cross spoke wheel. thanksss!
Getting this setup (PS4s 255/35/19 front x 275/35/19 rear) installed on Friday with no spacers. Stock 19in 20 spoke rims. Will report back with my findings!
Old Jun 22, 2017 | 03:23 AM
  #48
SJY's Avatar
SJY
c63s sedan
thanks man! wondering if 275/255 will change the mess up the esp setting?
Old Jun 22, 2017 | 03:33 AM
  #49
xxxPaulxxx's Avatar
No in the front and back the tire gets 1% bigger.. No problem for the esp, in Germany it won't be allowed because your car is running faster than it displays.. But if that is allowed in the US... Sure
Old Jun 22, 2017 | 05:08 AM
  #50
MarkC63's Avatar
2016 C63 Wagon
Looks great. Thanks. You are right about the inch being 1/2 on the inside and 1/2 on the outside. I forgot about that.
I am really surprised at how good the front looks. That setup is nearly an inch more poke than factory according to my calcs. I didn't realize that would fit. Nice one!
