C63/C63S AMG
Brabus Piggyback Performance Kit
Old Jul 21, 2017 | 10:23 AM
nl88's Avatar
C63
Hi All,
Just realised that there have been a few piggybacks mentioned here. However, I noticed that the Brabus Performance Kit hasn't been mentioned before.
Anyone have any experience with them ?
BRABUS PowerXtra CGI B40-600
base C 63 S (W/S 205). Please specify basic Version!
+66 kW / 90 hp, +100 Nm auf 441 kW / 600 hp, 800 Nm
Vmax: ca. 300 km/h (depending on the base)
BRABUS PowerXtra B40S-650
Base C63 S (W/S 205) Please specify basic version!
+ 103 kW / 140 hp, + 120 Nm to 478 kW / 650 hp, 820 Nm
Vmax: 320 km/h (depending on the base)
Old Jul 21, 2017 | 11:17 AM
Vassago's Avatar
2017 C63s Coupe
Originally Posted by nl88
Hi All,
Interesting, not much info on Brabus site. Subscribing to this thread to see what people have to say.
Old Jul 21, 2017 | 01:38 PM
4dr.no's Avatar
2019 AMG C63
Quick Google turned up this review. Looks like ECU reflash is needed.
https://www.topspeed.com/cars/merced...-ar172602.html
"True to its reputation, the German tuner developed a unique performance upgrade on the AMG C 63 S, dubbed the PowerXtra B40S - 650.” The kit is made up of a pair of turbochargers with larger compressors, new core assemblies, and reinforced axial bearings. There’s also an engine-specific ECU remap to improve the fuel-injection and ignition systems of the V-8. The result is an improvement of 140 horsepower and 80 pound-feet of torque over the engine’s standard output of 510 horsepower and 524 pound-feet of torque."
Old Jul 21, 2017 | 05:02 PM
vaelin's Avatar
EQS 580+ SUV, G550, Porsche Taycan Turbo S, McLaren Artura Spider
That's almost the equivalent of their Stage 3 package; milder tune is via piggyback, above.
Old Jul 21, 2017 | 05:09 PM
digitalnav's Avatar
C63S Sedan
Brabus or Dinan... hmm...
Old Jul 21, 2017 | 05:22 PM
vaelin's Avatar
Dinan is down the road (101) from you and I and warrantied. Brabus is on the other side of the world.
Old Jul 21, 2017 | 06:13 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
There is a Brabus piggyback for stock turbos, and a Brabus ECU flash for their kit with upgraded turbos.
I believe the piggyback was something crazy like $9000.
I recommend looking into the RaceChip Ultimate for the C63S or wait for Dinan to release. RaceChip is TUV certified and it's a legit operation in Germany... I'm very tempted to try them out, it's under a grand.
Old Jul 21, 2017 | 06:24 PM
digitalnav's Avatar
C63S Sedan
I know i know... just that brabus name haha.
99% going with DINAN though just need them to realse the damn thing.
Old Jul 21, 2017 | 06:54 PM
nl88's Avatar
C63
Seems like brabus is also covered by warranty. Managed to dig a little for the price. €59xx .. However it seems to only be available to c63S and not the non-s.
Old Jul 22, 2017 | 12:30 AM
Zelvy Carbon's Avatar
2016 AMG C63S edition 1
I have the Racechip on my C63s I just took it out to see what difference (if any) I could notice.
I was also informed by my dealer that I have voided engine warranty by installing it. I uncoupled the chip before taking it to the dealer for some warranty work (unrelated) but they noticed the wiring. I am in Australia. And I will be pursueing them legally as they are not within their right to void all engine warranty.
Old Jul 23, 2017 | 08:25 PM
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
Wow good to know, I'm also in Australia.
Old Jul 24, 2017 | 02:09 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
Not surprising in the least... if you leave parts of a piggyback still plugged in and they find traces of the device, say bye-bye to engine/trans/ECU warranty. If you removed it entirely before service, it would not have been detectable. Live and learn.
Old Jul 24, 2017 | 02:46 PM
digitalnav's Avatar
C63S Sedan
False, new ECUs for a while now keep track of boost pressure etc. they can easily backtrace to see if the car was running excessive boost. Very common on BMW's and the JB4, etc.
Old Jul 24, 2017 | 04:27 PM
dforman15's Avatar
2016 C63s
I'm no legal expert and I'm not taking Mercedes side but I do believe they have the right to void your warranty in regards to the engine/transmission. If you chose to modify the engine parameters set by Mercedes ie. boost pressure, air/fuel ratio, and put additional stress on the motor and trans (which is what they will say), they can void the warranty. If for some reason down the road your motor or trans blows up, there is no way they will cover it. They will place blame on you for modifying your car. Of course you can fight them in court if you wish.
Old Jul 24, 2017 | 04:50 PM
digitalnav's Avatar
C63S Sedan
^^^ precisely.
This is why I'm waiting for DINAN and their warranty coverage.
Old Jul 24, 2017 | 05:06 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
That's true if you do an ECU flash and overwrite table values (and I'm sure a flash log will be counted internally). But when you use a piggyback, you're tricking the ECU into thinking it's running OEM parameters (by modifying the voltages of the various sensors). This allows the ECU to stay within OEM parameters and maintain OEM safety measures without raising any flags.
Basically the ECU thinks it's running stock boost/timing/AF, so there won't be any "excessive boost" or changed parameters to the ECU if they were to go digging.
Old Jul 24, 2017 | 05:50 PM
digitalnav's Avatar
C63S Sedan
False again. A Piggyback will send info that the stock ECU reads. This has been debated and debunked on various BMW models which im sure is the same for Mercedes.
I dont remeber the exact technical terms, i went down this route with my previous car and it was with it for over a year. All i know is that a piggyback, even when removed, will still store the higher values within the ECU.
If you have proof otherwise that its different on Mercedes, i'll glady retract my statement. Im all for learning new things, this is just from previous experience.
EDIT: as far as i recall they just "piggyback" onto the turbo lines and increase pressure and some other parameters. Its just manipulating the signal as a middleman.
Old Jul 24, 2017 | 06:04 PM
I did some more digging, and you are both right really.
BASICALLY. Either way you are screwed.
REFLASH, they can count / see when the reflash has occured, so if something went bang and you took it to your tuner to get put back to factory before returning it to the dealer for "warranty". They can't see your settings, but you are sure to raise a lot of suspeicions, and given they can see the ECU was interfered with, you are voiding warranty.
PIGGYBACK, they can tell that too.
Meh, I don't care, I added aftermarket air filters, and ripped the 2nd cat from the downpipe ages ago, thus voiding warranty technically..
Under Aussie law, if I have a engine/trans issue that they cannot prove to be caused from the mods, I have a right to claim. IE, oil leak etc..
Old Jul 24, 2017 | 08:21 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
They manipulate two manifold air pressure sensors, two boost pressure sensors, and one camshaft sensor.
If the manipulated voltages sent back to the ECU are outside the stock parameters (the manipulated signals are detected by the ECU), then the ECU will protect itself and go into limp mode. This happened with poor quality chips like the original Rebellion piggybacks that some people ran. Once you go into limp mode, you will more than likely throw a CEL and/or store a code… and dealers could probably determine why the car went into limp mode.
On high quality piggybacks with smart processors (Dinan, RaceChip), this isn't an issue. The manipulated signals aren’t detected by the ECU, so the car doesn’t enter limp mode or throw a code. In that case, removing the piggyback would be virtually undetectable.
Old Jul 24, 2017 | 09:16 PM
digitalnav's Avatar
C63S Sedan
Well, this could be true. Guess we have to wait and see till someone actually takes a car with a piggy back into the dealer to get serviced with it removed and if they run into any hiccups.
Thanks for the insight!
Old Jul 24, 2017 | 11:01 PM
AV1's Avatar
AV1
C204 C250-CDI
[QUOTE=AlexZTuned;
[/QUOTE]
This ^^^^^
There's a Brabus workshop located almost right next door to my place of work - which is a good thing - but unfortunately the prices they charge for their MB/AMG associated mods is just crazy...with regards to tuning boxes they can charge up to 10x the price of other typical products
Most people source these and other mods from other O/S suppliers.
Old Jul 25, 2017 | 09:59 AM
subzero05's Avatar
CL500
^^^ precisely.
+1
