DIY 2015 C63S Rear Brake Pad Replacement
Subscribe
Sep 21, 2017 | 07:46 PM
I recently changed the rear brake pads on my 2015 C63S and thought I'd share my findings on part numbers, tools & my procedure. I can't guarantee the accuracy of these instructions but believe them to be accurate. Hope they help someone out!
Reply 9
Sep 21, 2017 | 08:20 PM
Quote: I recently changed the rear brake pads on my 2015 C63S and thought I'd share my findings on part numbers, tools & my procedure. I can't guarantee the accuracy of these instructions but believe them to be accurate. Hope they help someone out!
Very detailed write up. Thank you!
Reply 0
Sep 21, 2017 | 10:37 PM
Great job
Reply 0
Sep 22, 2017 | 10:30 AM
Great write-up!
One question: in Step 10, you say "jack using central jack position". I wasn't aware there WAS a central jack position, and the Owner's Manual doesn't make note of it. Where is this central jack position?
Reply 0
Sep 22, 2017 | 04:36 PM
I only did the rear pads this time and I didn't check to see if there was a central point in the front but I thought that during my research I had seen that there was one. The next time I'm under there I'll see if there is one and post what I find.
Reply 0
Sep 25, 2017 | 04:38 PM
Two thumbs up to a great write-up!
Reply 0
Jul 25, 2018 | 06:28 AM
Hi BD-C63,
Finally changed the pads today.
I would like to thank you from the bottom of my heart for the great helpful article.
It took about three goes to have the brake release, but, all else was flawless.
One comment, but, my lug nuts were actually 17mm not 18.
Again, thank you very much and please whenever you do some repairs/replacements; please let us know.
Cheers,
Mark
Reply 0
Nov 16, 2018 | 05:39 PM
Just did my rear brakes using this guide, great job OP! Only change I'd make is to highlight how you need to grab the inner nut with pliers/Vicegrips/wrench (20mm?)/etc. I know you call it out in your write-up, but I somehow glossed over how essential it is, as otherwise the caliper bolts just turn and turn while trying to remove them.
Also, thought I'd add: I did this work because the dealer told me I needed rear brakes (pads/rotors) at my first B service (20k). I declined (because ~$900) and let them go until 22k (today). After I pulled off the first rotor, I threw a set of micrometer calipers on them and found they were down 0.5mm vs the new ones. I had zero scoring, and no ridge at the edge. Personally, I'd let them go for another 20k and not worry about them. The pads themselves were definitely worn though; I probably had 5k left tops before I hit the wear limit sensor. Though I bought the OEM discs from FCP Euro, so a lifetime guarantee is nice to have. YMMV.
I installed Porterfield pads, I'm expecting much less brake dust AND squealing.
Reply 1
Explore
Nov 17, 2018 | 02:00 AM
Replacing rear pads
Quote: Just did my rear brakes using this guide, great job OP! Only change I'd make is to highlight how you need to grab the inner nut with pliers/Vicegrips/wrench (20mm?)/etc. I know you call it out in your write-up, but I somehow glossed over how essential it is, as otherwise the caliper bolts just turn and turn while trying to remove them.
Hi,
Keep us posted as to how you are finding the Porterfield pads
Reply 0
Nov 17, 2018 | 07:28 AM
Will do!
Reply 0
Dec 8, 2018 | 02:41 PM
Thank you for the write up.
I just finshed my fronts they installed with ease. As for the backs, even in serivce mode their is so much meat I can’t get the pistons back by hand. Can you recommend a the piston retracting tool that you used?
Reply 0
Dec 8, 2018 | 02:43 PM
Go to Home Depot and get a squeeze grip. They're in the tool isle and work like a charm. The Two pack is maybe 14 bucks
Reply 0
Dec 8, 2018 | 02:49 PM
Quote: Go to Home Depot and get a squeeze grip. They're in the tool isle and work like a charm. The Two pack is maybe 14 bucks
ahh shoot never thought of that, large vice grips.
Reply 0
Dec 8, 2018 | 04:31 PM
Here you go
Reply 0
Dec 8, 2018 | 04:55 PM
Quote: Here you go
That’s the exact one I used worked perfectly. Got the backs on with no problem. Took it out did 5 stops from about 35 then 3 from 45. Never came to a full stop.
Reply 0
Dec 17, 2018 | 08:14 AM
Good information in this thread. I'm accumulating information on DIY work for this car as I've got one on order. I come from the VAG world where there is a ton of DIY guides and am a little surprised there are so few for this platform.
Could some of these get 'stickied' to the top?
Reply 0
Dec 13, 2019 | 02:20 PM
Thank you! will use this for my GLS63.
Reply 0
Jan 21, 2020 | 05:50 PM
I am about to install both front and rear brake rotors/pads on my W205 C63S. What are the torque specs you guys used when you reinstalled the parts? I've searched and couldn't find the answer.
Reply 1
Subscribe
Currently Active Users (1)
