C63/C63S AMG
Official MB power figures
Old Sep 29, 2017 | 03:03 AM
michael640D's Avatar
2018 E63S,2016 C63 S Edition 1 Coupe(gone), 2011 640D M Sports Coupe, 2015 435i M Sports Coupe
MB official figures for hp are 503hp @ 5500rpm-6250rpm and 700Nm @1750rpm-4500rpm does anyone know what Dynamic setting what gear and if manual or auto gear box setting should you be able to get these figures.
As I would like to check to see if after the up date my car makes the quoted figures or not.
Old Sep 29, 2017 | 09:09 AM
zdonner's Avatar
2015 C63S
Dyno runs should be made in 5th gear as that is the 1:1 Auto/Manual doesn't matter but it would be recommended to do this in Auto and you will have to set the cat into Roller Mode or else it'll shut down early.
I Dyno'ed mine at it made 480 RWHP stock - which puts it closer to 550 Crank. (Depending on what math you use for the transmission loss).
Last edited by zdonner; Sep 29, 2017 at 10:49 AM. Reason: Bad info on gear selection
Old Sep 29, 2017 | 09:45 AM
amg8's Avatar
MY17 C63s Sedan
Originally Posted by zdonner
Dyno runs should be made in 4th gear as that is the closest to 1:1 Auto/Manual doesn't matter but it would be recommended to do this in Auto and you will have to set the cat into Roller Mode or else it'll shut down early.
According to this http://www.automobile-catalog.com/auta_details1.php closest 1:1 is actually 5th gear. But it would seem 4th should make more power?
Old Sep 29, 2017 | 10:48 AM
zdonner's Avatar
2015 C63S
My mistake, I went from memory - it is 5th gear.
Old Oct 1, 2017 | 05:03 AM
zdonner do you know how accurate the data screen read out is as on mind C63 S I can not get passed the 400hp mark in any of the mode settings this is why I want to have a dyno power run to see what's happening. The car had the enginee and gear box update.
Old Oct 1, 2017 | 05:11 AM
Does it mater which dynamic mode it's in or does'nt it matter.
Old Oct 1, 2017 | 09:52 AM
zdonner's Avatar
2015 C63S
The screen is a party favor - it means nothing, it's basically a boost gauge more than it is a "power meter". I wouldn't use to to quote power numbers but given what you've described I'd say there is something strange going on, if you're taking the car to full revs then I would suspect there is a boost issue as that's my personal theory on the gauge is that it is essentially just a gimmicky boost gauge.
I didn't test the driver modes but I can say that the power numbers wouldn't be different as that will not change mode to mode but it does control how the car holds gears, I told the tech to set it into RACE and make sure it was in Manual but I'm fairly sure he was going to do that anyway.
Old Oct 1, 2017 | 10:45 AM
Does'nt the information shown on the engine data screen come from sensors on the crank shaft which would be a accurate representation of engine power output.
Old Oct 1, 2017 | 10:56 AM
ItalianJoe1's Avatar
2003 CL 600
The info screen uses the 'Calculated torque' value that the engine computer uses for all it's running calculations. Basically it looks at the airflow through the engine and all the combustion data, timing, boost, rpms, etc. Then it references a Volumetric Efficiency table to determine how much torque the engine should be making at that moment.
The car uses this info for transmission calculations along with other things, and it's reasonably accurate on a stock vehicle. The engine should be capable of producing the max allowed torque in proper conditions, if there's nothing stopping it like excessive temperatures or poor fuel quality. The car will adjust boost levels and timing targets to reach the torque level it's allowed to, so it should get to the max on that display screen assuming everything working as it should.
Old Oct 1, 2017 | 11:13 AM
zdonner's Avatar
2015 C63S
It's a culmination of different data points but it doesn't MEASURE power - thus it's a best guess, it's about as accurate as the old "Butt Dyno", this is why I consider it a gimmick. Can it be used to give rise to suspicion of a problem? Yes, but it's a guideline to show overall how the engine is performing and not specifically how well it's performing and should be mostly used to WoW your friends that don't know this or in your case as a talking point to the dealer as if you are not seeing more than "400 HP" on that display, there is a likely hood you have an issue that's causing the car to pull timing or perhaps you have a boost leak.
Old Oct 1, 2017 | 02:57 PM
Thanks for the info I always use 98-99 octane fuel outside temp was 17 degrees gear oil and temp was at normal running temp as had been driving for 30min before I had chance to do a high speed run with a clear stretch of motorway. The car pulled well but never seem to get pasted the 400hp mark even after a kick down acceleration up to 6500rpm in 4 gear. I did expect it to go to the 500hp mark as I have followed the run in to the letter and have only covered 1480 miles
Old Oct 1, 2017 | 03:55 PM
2003 CL 600
It should hit the indicated max power. Many people have had adaptations reset and gotten the power back, I haven't had to mess with one yet personally to say why that happens.
Old Oct 1, 2017 | 04:11 PM
Does the adaptations reset need to be done by MB garage or is it something that you can do your self, is it the gear box rest you are talking about in some threads.
Old Oct 1, 2017 | 04:18 PM
2003 CL 600
I have only seen people say here they had everything reset by the dealer. I assume it's adaptations because that's all you can "reset" with even a dealer scan tool. There's no way to reset everything yourself without a full function, OEM level scan tool.
Old Oct 1, 2017 | 04:57 PM
Old Oct 2, 2017 | 12:17 AM
vaelin's Avatar
EQS 580+ SUV, G550, Porsche Taycan Turbo S, McLaren Artura Spider
Here's hp and tq figures at the rear wheels. Stock is the thin red line.
The yellow and green numbers are swapped on each chart.
Old Oct 2, 2017 | 03:12 AM
Thanks Vaelin what mode was the run done in Sports + or race, Auto or manual traction control on or off and is there any thing else I to make sure is done for the run.
Does your engine data screen show full 510hp and 700Nm reading when you floor it?
Had you had the software update done when you had the dyno run?
Old Oct 2, 2017 | 06:58 PM
vaelin's Avatar
Dyno mode, race, 5th gear pulls.
I have a 2015, I don't have the fancy fake engine data screen. I'm also in California, so we get 91 octane and thus reduced power output; 503 instead of 510.
No, my car has not had the update, which I've seen everyone complaining about.
Old Oct 2, 2017 | 07:51 PM
RDOCA's Avatar
2016 C63S Sedan
The 503 or 510 is the difference in the US and European measurements for HP--It would help to have 93 octane but no luck here in CA.
Old Oct 3, 2017 | 01:01 AM
vaelin's Avatar
Ah, I was told it was due to our 50-state-legal emissions equipment.
Either way, 463hp at the wheels stock would mean a drivetrain loss of only 8% if we believed MB. The usual 15% calculation yields around 544 crank hp.
Old Oct 3, 2017 | 02:56 PM
tekfoc's Avatar
Veteran: Army
18 E63S
these cars are underrated from factory
it's actually what you posted at the crank
544 - 555hp
Old Oct 4, 2017 | 06:04 PM
black63s's Avatar
2018 750i Msport, 2018 Range Rover Autobiography, 2019 C63, 2017 F Type R
Is this the before and after sheet from your dinan tune?
Old Oct 4, 2017 | 06:05 PM
vaelin's Avatar
Yup.
Old Oct 4, 2017 | 06:40 PM
Modio1234's Avatar
2016 C63S AMG
Car stops making power at 5k rpms? What's the point of the 7k rpm limit.
Old Oct 4, 2017 | 09:01 PM
2003 CL 600
Torque falls off at high rpms, turbos are out of flow at that point. Bigger turbos will carry the powerband out much further.
