C63/C63S AMG
Cant remove hub caps
Old Oct 7, 2017 | 12:39 PM
dkirn's Avatar
C63 AMG
Hey guys new to the world of amg and need some help. I cant get these hub cape off some one please help
Old Oct 7, 2017 | 01:08 PM
amg8's Avatar
MY17 C63s Sedan
The removal tool should be in your trunk under the cover board.
Old Oct 7, 2017 | 01:55 PM
dkirn's Avatar
C63 AMG
Any chance you have a pic or part number looks like I am missing the tool
Old Oct 7, 2017 | 02:14 PM
amg8's Avatar
MY17 C63s Sedan
Scroll down this post here there is a pic of it https://mbworld.org/forums/amg-gt-gt...-hub-caps.html
Old Oct 7, 2017 | 02:22 PM
dkirn's Avatar
C63 AMG
Thank you so much
Old Oct 13, 2018 | 02:13 PM
Juniorp187's Avatar
C63 S AMG
Use the tool mentioned above. If the tool gets stripped at the socket area meaning it was too hard and you basically rounded the socket you will need a big channel lock wrench and grab the tool mounted on the hub cap by the side. The wrench teeth will grab onto the tool side lines and twist and turn to remove. My rear hub caps get frozen on my C63 and I need the channel lock wrench which is the only way. Do not try to use the wrench on the socket as you will strip it even further and possibly break the center offf the removal tool. You have better torque to remove it by grabbing the tool by the sides. Good luck and remember not to scratch the rim. I would use some cardboard the side of the rim and cut a hole in the center so you can place the tool. This way you don’t miss with the wrench and mess up your $10k rims
Old Oct 13, 2018 | 02:18 PM
skim7x's Avatar
Mercedes-Benz E63s AMG
Yeah I don't have that tool -- I swear I remember it being in there when I bought the car but it's more gone... My MB dealer says there is no such too and to remove the covers with an exacto knife ::SMH:: amazing, the stupidity of some of these employees.
Old Oct 13, 2018 | 07:02 PM
Juniorp187's Avatar
C63 S AMG
You crazy!!! I had to buy the entire thing just for the mercedes. center logo that went missing. I got it on ebay for $120 ebay ID 222872148480. The entire cap cover OEM price are $250+ each one. The one I got was matte not even gloss for my car,but i just used the center logo. Make sure to liquid nail glue them center caps from the inside.There are no replacements for the logo. I tried them all and different sizes. They don’t even sell the retaining ring....
Here is the tool part number
A000-581-00-00 spanner tool
Find it online. They are like $50 and use a very big channel lock wrench that opens wide 3-4 inches to grab around it. If it’s frozen stuck, you will strip the plastic socket and only the channel lock will help. Good luck. Btw, that center is plastic but the entire piece around is metal, good luck with an xacto knife LOL
Old Oct 13, 2018 | 09:20 PM
BD-C63's Avatar
2015 C63S AMG
Once you get them off be careful not to over tighten when you reinstall them, should just be hand tight. Also, please clean those wheels/tires!
Old Oct 13, 2018 | 09:45 PM
ScottsC63's Avatar
2015 C63 AMG sedan
My OCD wants to clean that wheel so bad!
Old Feb 11, 2019 | 04:58 PM
Ryane8182's Avatar
18 Benz C63
what do you do if you do end up breaking the whole cap off? Mine was way over tight and snapped right off.
Old Dec 27, 2021 | 05:48 AM
huijbershubcaps's Avatar
a250 amg
Centre cap/ hub cap Mercedes amg screw on 60mm
For new ones u can contact me
HuijbersHubcaps@gmail.com
they are €40 a piece
