Who's Upgraded their Turbos
As for this...WOAH. This changes *EVERYTHING*. 752 RWHP on pump?! On OEM fuel system? Just DP and tune? If that's legit, that's *AMAZING*. And I'm buying. Except that something here doesn't add up...
Just how conservative is that? Cuz that's 45 RWHP than they made on their Stage I setup, and a whopping 127 RWHP less than what they made on their Stage II setup. At the same boost, on the same tune??
yes they said pump gas and downpipes. No meth or ethanol.
FYI Eurocharged centers will install Pure turbos and put their tune on it and not charge you the core charge as they just keep your factory ones.
my cars in at the shop currently getting pure stage 1”s turbos put in.
Just to clarify, as well all know the stage 1 uses the stock turbine but what I didn’t know was that it is back cut.
Ill post the dyno comparison of my between the car with a tune and then with downpipes / turbos / new tune on Friday when I get the car back
Stage 1 turbine backcut
Full power tunes to compare how quick boost comes on between the three turbos, power across the mid range, out right power and torque differences.
Who is doing the swap and tune for you?
You should see if they can take a heap of photos as I'm sure a lot of us here would be interested in seeing a step by step of the turbos being swapped out.
I would paticularly like to see some detailed detailed photos of what the engine valley looks like with the heat shields removed and how much room there is under the turbo manifolds.
"MB C63S M177 PURE Turbos Upgrade
-700whp, Race Gas, No meth, just DP and exhaust!
-752whp, Race Gas, No meth, 22-23psi:
But on Instagram (as was posted earlier in this thread), they listed Stage 2s as making 752whp and 681wtq "Same boost, Same tune, Same mods, Same fuel". So I guess their Stage 1 makes 630whp on pump, and 670whp on race gas?
The below graph is comparing between the first tune and then the modified tune.
Or is this purely turbos, tune & downpipes???
I wanna know any other supporting mods you have too, but most importantly:
1) Are these rwhp #s or is it calculating bhp (crank)?
2) Is this on race fuel or pump? Cuz if it’s pump, that’s the most impressive part.
If it’s on pump, were you running a wideband and measuring AFRs? Wondering just how lean you’re running (ie how safe the tune is). From the sound of it, you had someone rewrite a tune remotely based on existing data points and then reflash the ECU with those data points. My suggestion is, you NEED to check and make sure the AFR you’re running at is safe if you wanna keep your motor. That’s the difference between a bench tune (preloaded with margin for safety) vs a custom tune (need to check).
2) At what PSI did you make these numbers? Stock or did you up the boost as well?
Ill find out tomrrow what calculation the dyno used to arrive at this but it can be vehicle specific ( other dynos I’ve used you put in the gear ratio to the program and run at a certain rpm then select neutral and it measures the spin down time and calculates drive train losses from this). But if you use 10% drive train loss it’s the same numbers as what other guys have been getting with the same mods.
I have no formal information about this, but based on reverse calculations from Renntech and other tuners and their baseline vs tuned Dyno plots, it seems 13% drivetrain loss is what ppl are experiencing across the board. That would put you at 579rwhp. Much more realistic. So the biggest achievement in the tune would be the tune itself; early power and linear torque curve.
