C63/C63S AMG
OEM OFFSETS C63S
Old Feb 14, 2018 | 11:21 PM
c63prob's Avatar
c63
OEM OFFSETS C63S
What's the OEM front offsets for a sedan? Is it 38 or 25?
I'm getting conflicting info.
Trying to figure some offsets for aftermarket wheels.
Looking at 19x9 25 offset and 19x10.5 52 or 57 offset
thanks
Old Feb 15, 2018 | 08:15 AM
crazy1eye's Avatar
2016 C63S, 2012 ML350
Sedan is 38 front & 56 rear 👍
Old Feb 15, 2018 | 01:26 PM
C63S8ABMW's Avatar
2016 C63 AMG S
thanks
So I just ordered HRE wheels in a custom offset. I can give you my specs I just ordered them in. I should get them about 2.5 to 3.5 weeks. I will be putting 265/35/19 front 305/30/19 if they fit if not go down to 295/30/19
I used my stock wheel offset which also had 15mm wheel spacers
19x9.5 offset 35
19x10.5 offset 52
Old Feb 15, 2018 | 01:54 PM
c63prob's Avatar
c63
Thanks guys! I like these offset. I'm gonna roll with them instead of the 19x9.
19x9.5 offset 35
19x10.5 offset 52
Old Feb 16, 2018 | 01:59 PM
thewb's Avatar
SPONSOR
www.wheelsboutique.com
19x9.5 offset 35
19x10.5 offset 52
We've perfected the fitment on the W205 C63 Coupe, Convertible, and Sedan. We know what works and what doesn't. If you need help in ordering the right fitment let me know and I'll take care of you.
Old Feb 18, 2018 | 08:34 AM
crazy1eye's Avatar
So what would be the perfect fitment for the sedan staying with the stock size wheels?
c63prob’s rear wheels will stick out 16.7mm, is that too aggressive?
Can we adjust the camber on the rears, add a bit more negative camber?
thanks!
Old Feb 19, 2018 | 09:57 AM
thewb's Avatar
SPONSOR
thanks!
If you check out the Sedan we did here - https://flic.kr/s/aHsm6WkjFh - it used a 9" front and 10.5" rear and the fitment was on point. We can even move up to a 9.5" front on the Sedan as well.
No, 16.7 mm closer to the fender from where the factory wheels sit is not too aggressive.
Old May 10, 2018 | 12:42 AM
Jaydavid93's Avatar
C63 Amg coupe 2018
So i have a 2018 c63 coupe non S. My wheels are the 10 spoke 18in front 255/40/18 tire.... 18 in rear 285/35/18 tire. I'm wanting a flush fitment. I can't seem to find the wheel widths or offsets for my stock wheels. It is hard for me to calculate what offsets i need to be flush and still change my rear tire to a 305 for better grip. What sort of offset would i need to come flush with the fronts and stick out slightly in the rear? I plan on doing 19x9.5 front 19x10.5-11 rear or a staggered front 19x9.5 rear 20x10.5-11. Im clueless right now because i don't even know the width of my stock fronts and rears so i can't calculate anything. Any advice would be appreciated thanks! Oh and the car will be lowered about 1in all the way around.
Old May 10, 2018 | 10:26 AM
thewb's Avatar
SPONSOR
I'd be happy to help you out. Can you email me a photo of your wheel so I can figure out what the OEM specs are and work our way forward from there? David@WheelsBoutique.com
