C63/C63S AMG
Recommended tire pressure to soften up the ride on a C63S sedan
Old Feb 25, 2018 | 03:34 PM
wolfturbo's Avatar
2012 CLS63, 2009 Scud, 1978 930 Turbo
Guys,
I have a 2015 C63S sedan and my one and only complaint about the car is that I findthe ride to be rather unbearable. I realize the suggested setting is something like 48 PSI all around, but I am wondering if others are running lower tire pressures to make the car more comfortable.
Suggested settings? I am running the Michelin PSS 265/35/ZR19's by the way.
Thanks to all for any input!
Rob
Old Feb 25, 2018 | 03:42 PM
Fame Douglas's Avatar
2018 C63 Coupe
48 sounds very high. I run 36 in the rear and 38 in the front of my coupe. Measured after 20 to 30 min of normal driving to get the tire temps warm.
Old Feb 25, 2018 | 04:18 PM
RDOCA's Avatar
2016 C63S Sedan
Originally Posted by wolfturbo
Guys,
Rob
Lets start with the fact that 48 PSI is not the recommended tire pressure.
The recommended pressure for a C63S sedan is 38 front and 33 rear.--(up to 155 MPH and 3 passengers)
The chart is on the back of the gas door.
Do not use the numbers on the door pillar.
The numbers on the door pillar are only for the EPA so MB can get better mileage to advertise and NOT to actually use in every day driving.
Old Feb 25, 2018 | 07:37 PM
sack5000's Avatar
2015 AMG C63 S
regardless of PSI this car rattles my bones, worst riding vehicle lol
Old Feb 25, 2018 | 07:45 PM
Passat774's Avatar
2015 W205 C63 AMG S Edition One
Do they make 18" wheels for the sedan?? I would love to also soften the ride
Old Feb 25, 2018 | 08:01 PM
msd3075's Avatar
'15 C63S
They are standard on the non-S model, but my understandng is that they won't clear the bigger brakes on the S.
Old Feb 25, 2018 | 08:52 PM
ChrisCF's Avatar
Porsche GT3 RS / C63S sedan
Maybe softer springs? I am looking into that.
Old Feb 25, 2018 | 09:26 PM
AlfaGTA's Avatar
'92 500E, '07 SL550
If it has air suspension, the rear accumulators might need replacing.
Old Feb 25, 2018 | 09:40 PM
JWreck's Avatar
C63 S AMG, Jaguar F Pace S
does any C63S have air suspension?
Old Feb 25, 2018 | 09:41 PM
JWreck's Avatar
You’ll need to flatten your tires to get something like what it seems you’re looking for. I just drove mine 400 miles round trip, and while it’s certainly harsh, wouldn’t say it’s back breaking...that’s just the car though. It’s harsher than a GT cruiser.
Old Feb 26, 2018 | 01:16 AM
RDOCA's Avatar
2016 C63S Sedan
No
Old Feb 26, 2018 | 02:35 AM
RJC's Avatar
RJC
Various
Any changes cnfm'd for 19 re the rough ride?
Old Feb 26, 2018 | 01:16 PM
bing1221's Avatar
2016 C63s
i downgraded to 18inch wheel, way better.
Old Feb 26, 2018 | 03:10 PM
jadatis's Avatar
Seat Alhambra
Googled your tires and they where Loadindex 98 and XL ( most ZR low H/W division tires are XL) So they are allowed to carry 750kg/1650 lbs AT 42 psi up to 160km/99m/h, without overheating if that weight is realy on it and you realy drive that speed constant.
The tiremakers even say you can drive 190km/118m/h with 42 psi if W speedrated and even 220km/135m/h if Y speedrated, but keep it at what I first gave.
This would cover a GAWR ( gross axle weight rating is maximum allowed weight to law) of 3300 lbs wich your car dont have .
Better is to add 10% for reserve so a GAWR of 3000 would be better as max.
For higher speed then 99m/h the pressure should be higher.
To make it short, determine the real weights on axles and give the maximum speed you use ( and wont go over for even a minuten), and I can calculate a save lowest pressure .
Normal use weight is mostly lower then the GAWR's so for that pressure can be lower.
The 48 psi would probably be enaugh for the maximum technical car speed of your car, but who rides that as max ?
If you cant determine the weights , try to find empty weight and give the way you load it ( persons and load) , and sertainly those GAWR's you can find on car.
My estimation is that 40psi all around will be save enaugh for your use.
Greatings from a "Dutch Pigheaded Selfdeclared Tirepressure -Specialist"
Peter
Old Feb 26, 2018 | 05:33 PM
ChrisCF's Avatar
Sorry to hijack the OP's thread, but curious if there was a suspension kit involving springs and other pieces and the end result was a better ride with increased rear end traction what would be the level of interest? The development of the kit was done by a world renowned suspention tuner, not somebody throwing together parts who doesn't understand their impact.
Old Feb 26, 2018 | 08:05 PM
Passat774's Avatar
Can you post a picture of the 18" wheels you got for your car? And specifications
Old Feb 26, 2018 | 08:42 PM
bing1221's Avatar
2016 C63s
I swapped to default one 18inch amg one, only about to 2mm clearance. Have to remove all weight balancers.
Old Feb 26, 2018 | 08:57 PM
sack5000's Avatar
2015 AMG C63 S
Would like to see a PIC as well. I owned 2007 and 2009 E63 with big brakes and they both had 18 in.??
Old Feb 26, 2018 | 11:10 PM
ManveerS's Avatar
2016 c63
18 inch wheels
Old Feb 27, 2018 | 10:14 AM
msd3075's Avatar
'15 C63S
Originally Posted by ManveerS
These are 18" wheels mounted onto a non-S C63 which has smaller diameter front brakes than a C63S. Those same wheels would not be able to properly clear the front brakes on a C63S.
C63 = 360 mm (14.2 in) diameter front rotors
C63S = 390 mm (15.4 in) diameter front rotors for standard brakes or 400 mm (15.8 in) diameter front rotors for CCB
Old Feb 27, 2018 | 07:59 PM
Passat774's Avatar
ugh, maybe need to have a custom set of 18" wheels made.....
Old Feb 27, 2018 | 10:16 PM
larrypmyers's Avatar
Veteran: Air Force
16 GLC 19 Volvo XC40 06Corvette Z06
Optimally tire pressure should be checked and set in the morning prior to the vehicle being driven. Set pressure as specified on the decal inside the fuel filler door.
Old Feb 27, 2018 | 10:32 PM
RDOCA's Avatar
2016 C63S Sedan
What he said^^^
With the pressure correct (sedan 38f--33r) and in C mode for suspension you are good to go.
I just put on a set of the new PS4S and they ride better and are quieter and have better traction.
With all of above done and knowing this car rides firm --it is what it is so get over it and quit whining or put on an after market suspension.
Old Feb 27, 2018 | 10:48 PM
JWreck's Avatar
What he said^^^
Or buy another car, that isn’t a sports car....
Old Feb 28, 2018 | 07:23 PM
Passat774's Avatar
What other MB AMG cars share our brake system in the S model?
Did the W204 C63?
