C63/C63S AMG
Dinan Install Question
Old Mar 3, 2018 | 02:19 PM
Art138's Avatar
2017 c63s coupe Fordfgt Supercar
Can anyone tell me who done the installation if the plastic ties depicted in my pic need to be cut to move the harness cover, I see no alternative.
Old Mar 4, 2018 | 12:01 AM
vaelin's Avatar
EQS 580+ SUV, G550, Porsche Taycan Turbo S, McLaren Artura Spider
No, you shouldn't need to cut those. There's enough slack to move it a bit to get to the sensors.
Old Mar 4, 2018 | 05:53 PM
JoelSolid's Avatar
2016 C63 S
I agree with Vaelin. But too be honest it is easier if they are cut. But not worth it to cut since redoing the zip ties is a HUGE pain.
Old Mar 4, 2018 | 06:17 PM
Art138's Avatar
I have loosened everything as much as I can. I may have to take off connectors to provide more slack ( which I prefer not to do). I will call Dinan tomorrow. Their intructions show arrows to the areas where the sensors are but I do see the harness pulled to the side in any of their pics. At least 3 inches of slack is need to get to both passenger side sensors. I have done many upgrades,but this one is not easy as the instructions depict.
Old Mar 4, 2018 | 08:18 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
I actually agree with this. I've done this install a few times and I can never manage to get much slack from the front engine harness, it really makes getting to two of the four sensors a major PITA. I've followed the instructions perfectly, counted all bolts/screws and even used another installation guide from a different piggyback manufacture as a supplement to Dinan's... still, I can only manage 1-2 inches slack from the harness. It's just barely enough to squeeze in there with some pick tools to undo the sensor and use a few fingers to finagle the Dinan plug in. It would be great if someone had tips on how to get more slack from the front engine harness.
I would NOT cut those factory zip ties though, I think they would be nearly impossible to put back on since they were likely installed when MB assembled the harness.
Old Mar 5, 2018 | 05:01 PM
vaelin's Avatar
Since Dinan did the harness install for mine I can't speak to the Dinan harness, but I previously installed the Rebellion harness and that was the same experience, you'll get 1-2 inches of slack, and then if you really put some pressure you'll get the last bit. But it's going to be tight either way. Just take your time.
Old May 7, 2018 | 03:44 PM
amalgam's Avatar
W213 E63
How the hell do you access plug 2? It's merely impossible to even get 2 inches of play with with harness, any help appreciated!!!
Old May 7, 2018 | 04:10 PM
Art138's Avatar
The instructions do not tell you,but it helps to release the remaining sensor connectors that feed the harness along the fuel rail. You might consider an extra pair of hands....one person to pull the harness while you pick at the sensor connector in question.
Old May 7, 2018 | 08:05 PM
amalgam's Avatar
W213 E63
Ok got finished with the install -- Was kind of a PITA but doable. Getting to the sensors and plugging in the new harness especially #2 was a *****. Having 2 people would be helpful as Art had mentioned, to pull the harness up and hold it while you try to plug in the DINAN harness. The instructions from DINAN were sparse but was enough get you through the install. I found that if you can cup your hand (facing upwards) you can barely reach the clip release from #2 then take a flat head screwdriver and pop it off through the top of the hole. Here are photos of where harness 3 and 4 are to compliment the Dinan instructions. Also in step 4 of the instructions, the photo shows the airbox and intake ducts still on -- At this point, it should be off. Also, remember when you go to unplug 1 and 2, label them, or set them far enough apart, so you don't confuse it later when you go to plug it into the DINAN harness. I mixed them up, but think I got it right (50/50 chance, no CEL light and runs so I guess I got it right lol) -- Dinan instructions read you should get 5-6" of movement from the harness to access the sensors, I was only able to get about 1". Cutting the plastic ties is not necessary as OP asked.. Overall I'm very satisfied with the results. The car pulls significantly harder now and from a rolling 10mph start in Sport+, the wheels break loose a little. Probably will go get it dyno'd soon. Glad I went with the DINAN piggyback, as this is my daily and I can't afford to ship my ECU out to have it tuned and untuned when I return the car after the lease is over. It's plenty of power for a daily for anyone considering this tune, I would recommend it. And nice thing is you can uninstall it and sell later on if need be. Also, I'm left with one black screw, 2 go to the coolant tank, where's the last one go? And where did you guys mount the ECU?
Old May 7, 2018 | 08:42 PM
Art138's Avatar
Here are two views...between cabin air filter and positive pole connect...
Old May 7, 2018 | 08:56 PM
Art138's Avatar
Insofar as the remaining black screw...check the aluminum piping bracket.
Old May 7, 2018 | 09:59 PM
amalgam's Avatar
W213 E63
That was it! Thanks! Also mounted the ECU where you did
Old May 8, 2018 | 10:09 AM
Swordfish99's Avatar
2021 GLE 53 Iridium Silver
Has anyone in Canada done this update, particularly in Alberta? I tried to order this directly from Dinan and I keep getting a message they won't accept international orders via credit cards. I would love to get from someone local if possible.
Old May 8, 2018 | 11:00 AM
amalgam's Avatar
W213 E63
Don't know anyone in Canada but you can contact Golan from Autotalent, I'm sure he wouldn't have a problem sending to Canada
Old May 8, 2018 | 03:07 PM
So I found a dealer in Vancouver that ordered me one from Dinan. How long did it take you to install this?
Old May 8, 2018 | 03:31 PM
amalgam's Avatar
W213 E63
Nice, about 3 hours -- It was my first time. Make sure you have some Torx drivers/bits (I think 17 and 25). Having a person to help is helpful but not necessary, good luck!
Old May 23, 2018 | 08:49 AM
Got home last night and found this waiting for me. Can't wait to get this plugged in!
Old May 23, 2018 | 11:17 PM
vaelin's Avatar
You will have that same grin that you had when you first bought your C63.
Old Aug 1, 2019 | 01:10 AM
ansonkk1's Avatar
2019 C63S Coupe
Can anyone help me? I have been stuck with this map sensor 4 for a while. It is very deep unlike the one on the instructions.
Old Aug 1, 2019 | 11:53 AM
untamedd's Avatar
2019 AMG GT R
Question on the Dinan piggyback.. Lets say I get it installed by a dinan authorized dealer but then I want to go back to stock for the winter or for any visit to the dealer, is that possible? If so, is it only a simple step required because I cannot be installing/uninstalling the entire thing by myself and nor would i want to pay someone to do that each time. Thanks.
Old Aug 1, 2019 | 12:13 PM
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
This is one of the main reasons I went with the RENNTECH , can load and unload the tune by just plugging the dongle into the odb port
Old Aug 1, 2019 | 12:17 PM
untamedd's Avatar
2019 AMG GT R
But thats a tune whereas Dinan is just a piggyback. From my understanding if you tune your ECU, the dealer can and will find out even if you back to stock prior. However, with a piggyback it seems that there shouldnt be a concern on that front since the piggyback is just 'fooling' the ECU which never really goes above stock boost etc on paper at least so the dealer wouldnt know.
I wonder if that is true or just my misunderstanding.
Old Aug 1, 2019 | 12:23 PM
FLC63s's Avatar
Well they ony will tell if they GO real deep, and if you are flashing it alot... if you are NOT flashing it over and over again, then the counts are low, and more so, would have to be a reason for them to dig deep. (which I believe can only be done at AMG or the like) as I dont think dealerships have the tools to do that type of investigation local. <- I could be wrong on this point
With a piggy back, you would have to uninstall the harness etc, as if a tech looks under the hood they will see it. (because its installed) now some companies have ones that you can put a cap on, and remove the box, and this works if the tech has no reason to look for somethings else.
Old Aug 1, 2019 | 12:29 PM
untamedd's Avatar
2019 AMG GT R
Yeah removing and installing the harness just seems like a PITA. OBD tunes are prob the easiest but i just cant get myself to go that route since i believe anything goes wrong with the car and the dealer will blame the tune. My exhaust valves were malfunctioning and the dealer refused to fix them because they blamed the sec cat delete.. i mean how ridiculous is that and these are AMG performance centres that im going to.
I guess im just gonna end up staying stock as far as power is concerned sigh
Old Aug 1, 2019 | 12:49 PM
FLC63s's Avatar
It sucks that you have that bad of a dealership... The local dealer ships dont look at ECU flash data unless there is an overwhelming issue..(someone on here had turbo's go out) and they were concerned they would look at that, and they didnt.
My dealer knows I have the exhaust swaped (from the DP's back) and they dont give a crap.) and I have heard of some dealerships being dicks about it.
I LOVE my renntech tune.. it made the car even that much more !
