C63/C63S AMG
Pops and crackles
Old May 3, 2018 | 03:57 PM
Fame Douglas's Avatar
2018 C63 Coupe
I test drove a 991.2 S before I bought my C63. The AMG Perf exhaust is much more aggressive than the Porsche sports exhaust.
Old May 3, 2018 | 04:19 PM
FDNewbie's Avatar
'17 AMG S63 Convertible, '17 AMG C63S Edition 1 Coupe
Originally Posted by KJ
I looked at the previous one as well, but everything was the same (including which DVD version to use and the "Topic Number" etc.)
I coulda sworn the #s were different, but I don't have it readily in front of me to compare.
What does "Cleanpoint Entered" mean?
I have ZERO proof for this, but I'm *assuming* this simply means "problem solved" in technical terms lol. A "final solution reached" lingo.
Old May 3, 2018 | 04:48 PM
WellesleyGL's Avatar
'16 E63s Wagon
I have a build date in 2017 and have a 2018, do I need an update?
Old May 3, 2018 | 05:29 PM
FDNewbie's Avatar
It's applicable through build date of 11/2017. Not applicable/necessary for build dates of 12/17 and beyond.
To check, if your car has the new software, one can try the following procedure:
Accelerate in "S+" to ~4,000rpm and lift the throttle. You should hear at least (!) 4 exhaust pops. Also, when slowing down in "S+" to a standstill, the 2->1 Shift should take place at 10mph (with the old software it was at around 15mph).
Old May 3, 2018 | 07:07 PM
'16 E63s Wagon
Mine's updated.. thanks!
Old May 3, 2018 | 11:33 PM
brevets's Avatar
'18 C63s Coupe
"It's applicable through build date of 11/2017. Not applicable/necessary for build dates of 12/17 and beyond."
The XENTRY states "up to production date 12/2016". Where are you getting the date of 11/2017 for applicable builds?
Old May 4, 2018 | 12:47 PM
  #32
MBzW205's Avatar
2018 C63S Coupe
Originally Posted by Chigs
I roll on and off the throttle in traffic when I want to be entertained.
Hahah I thought I was the only one. Its best at crosswalks or crowded areas
Old May 5, 2018 | 07:47 AM
  #33
FDNewbie's Avatar
Typo. My bad. I meant 2016
Old May 5, 2018 | 09:41 AM
  #34
'16 E63s Wagon
Maybe because I have just over 1k miles or the weistec BOV -seems to be louder and more pops and crackles. Needs to be louder though..
Old May 7, 2018 | 09:49 PM
  #35
JonAG72's Avatar
2018 C63s Coupe
Originally Posted by Mikey_boy
That seems not enough. I hear it very slightly in Sport and pretty loudly in S+ and Race when auto downshifting.
Same here. I hear it popping in Sport but it’s not as pronounced as in Sport+
Old May 8, 2018 | 11:57 AM
  #36
right_mr's Avatar
W212E63s[rwd sold]W211E63[sold] 645ci [sold]2018 C63s Estate[sold], 2017 gla 45 [Sold] E46m3 [sold]
Originally Posted by lyjw88
I just got my car (C63s Coupe) back from the dealer after requesting to upgrade engine, tranny, and map softwares.
Honestly, I do not think the exhaust got any louder and the pops/crackles are the same.
How frequent do you guys hear the pops and crackles?
For me, if I put the dynamic select to sport +, it pops and crackles ONLY when I manually downshift or crank up the RPM to 5-6k and let the throttle go.
That rings true for me as well. No pops and crackles in any mode other than sport + or race. In neutral/park at a dead stop, if i rev it in sport plus, it pops and cracks like crazy as soon as i let go of the throttle. In sport plus while moving( i dont use race at the moment), i have to take the revs up to 4.5 to 5k (usually in 2nd gear because otherwise i'll be well above the speed limit in most situations IN second gear 5k revs equates to around 45ish miles an hour) and when i let go i get between 2 and 6 or 7 pops/crackles spew out. Usually the longer i hit the revs at that range, the greater the pops and crackles.
No real pops and crackles in sport mode, or even in individual mode with exhaust set to sport plus and throttle to sport. For the snap crackle and pop rice crispies, it has to be in sport plus or race.
Old May 8, 2018 | 03:12 PM
  #37
TLDream's Avatar
a UFO
I think people are mixing experience with sports exhaust and regular exhaust, I wish people clarify what they have in this post. Sports exhaust is an optional feature for 2016 model. I don't have that, but my does downshift from 2 to 1 at ~10mph (digital reads any where from 13 to 11 as it start to decrease in large increments). Mine upshifts and do not hold gear to produce the pop if you don't drive it like you stole the car. Often tires will loose traction if you do drive it hard and traction control kills power and engine is throttled down. If you do manual/race mode, its the only way to hold the gear, and it will pop (didn't try this but from S+ experience, I am assuming it will). I have regular exhaust, and the service bulletin done, the advisor was nice enough to do it before I even know about this thing. The pops are not as loud as gun fire most of the time. Its a more subdued gunfire pop if that makes any sense. I even manage to get it to pop (once very notably, but several smaller pops) during hard 20 to 85mph acceleration as it popped during shifting in between 2nd to 3rd gear i think.
I have the velos tune now, and it definitely sounds a bit more aggressive (more notable and more often), as the car simply runs more aggressive. But I kind of wish i have the sports exhaust now, I think w/o changing dp or other exhaust component, having sports exhaust is probably the best balance of it being a loud amg car while staying classy enough (just louder than anything manufactured but quieter than any bad aftermarket). I think with sports exhaust, you must get a tune, it'll make the car unmistakenbly an "AMG". While regular exhaust, you just need to drive it like an "AMG" to get that sound.
Old May 11, 2018 | 07:03 PM
  #38
TLDream's Avatar
a UFO
hmm just checked my car, parked, in s+ throttle on and off, doesn't pop.
in race mode, pulled to 4k doesn't pop. 5k, kind of pops.
mind you i have the regular exhaust, is this expected, does it mean i have or don't have the update? i found past work order campaign 1710P54C67 ESP control unit update, i assume that's not it. yet, my 1st gear down shift is ~11mph. I have the velos tune (dyno coming soon) is it safe to ask the dealer to perform the xentry?
Old May 11, 2018 | 07:54 PM
  #39
2018 C63 Coupe
Yesterday I was driving beneath an overpass and I kind of rolled into the throttle in third gear and then let off right as the boost came on. The pop from the exhaust was so loud that it sounded like a gunshot. Part of me felt bad for scaring the unsuspecting drivers next to me, but I was still laughing my *** off at how rude these cars can be straight from the factory.
Old May 11, 2018 | 10:26 PM
  #40
AlexZTuned's Avatar
2017 Porsche 911 C4
Your ECU flash will get wiped with this update because it updates both the ECU and TCU. I have a sneaking suspicion the reason you don't have as pronounced pops is because of your Velos tune... unless it didn't pop or crack before the tune.
Old May 12, 2018 | 01:46 AM
  #41
TLDream's Avatar
a UFO
Thanks Alex, not exactly what I want to hear... but thanks for the warning, I am definitely going to avoid that xentry update until I figure out more details.
Can someone confirm if there is some difference between regular exhaust and sports exhaust with this bulletin/xentry? If so, how is it different. Also if it will for sure wipe aftermarket ecu tune.
Old Mar 27, 2019 | 11:26 PM
  #42
seek3n's Avatar
C63S
Originally Posted by Sanch
Between 2 - 5
Thats crazy! my 2019 c63s didnt crackle at all yet. sports plus 5k rpm crank up or down shift it does not crackle but sometime it randomly makes one deep poof sound when auto downshift... im scared to go to 6k.
Old Mar 27, 2019 | 11:36 PM
  #43
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
That's odd you should have the most updated software as well.
Old Mar 27, 2019 | 11:50 PM
  #44
seek3n's Avatar
C63S
I know 😓😢... And when i hit 1100 miles thinking yes finally get to try out this beast and before i could even try to hit 4k rpm the engine light came on and 4 of 8 cylinders gone off line causing P030800 misfire lol fml... dealer changed all 8 spark plugs and coil. Just got my car back this morning and want to try the crackles and is not happening!!! lol fml again....
Old Mar 31, 2019 | 11:12 AM
  #45
William23's Avatar
C450 AMG
I'm having the same issue, just bought a 19 c63s coupe and I'm not getting ANY pops or crackles. I have the performance exhaust too. Its driving me nuts
Old Mar 31, 2019 | 11:43 AM
  #46
Xec's Avatar
Xec
IG: @amg.svr
Make sure you're in true S+/Race and not just Individual. I just this out recently lol. Makes a world of a difference.
Old Apr 5, 2019 | 01:48 PM
  #47
William23's Avatar
C450 AMG
Of course. I'm in s+ with performance exhaust on and I get ZERO crackles or pops. My c43 sounded better in regards to downshift exhaust crackles.. I don't know what the issue is. I have 500 miles on the car and tried all driving modes.... 🤬
Old Apr 8, 2019 | 12:46 PM
  #48
esquesk's Avatar
2019 C63
I really only get them in first or second gear - try taking it to 5K RPM and letting off the throttle. Still in break-in so I'm not pushing too hard.
Old Apr 8, 2019 | 01:05 PM
  #49
raudiace4's Avatar
19 E63s, 23 M3 compX, B9 SQ5
Just got my car back from 20K miles B service, this update was performed and the pops and crackles are still there the same in S+ and Race. 2017 C63s coupe.
Old Apr 8, 2019 | 01:26 PM
  #50
benzbell's Avatar
2023 Urus Performante 2018 Huracan Perf. - 2017 Ferrari 488 GTB
I talked to the shop foreman who works on my cars about this. Last year he mentioned to me that you drive this car hard/fast. I said yes, and how do you know. He told me because of the way it drives and the way the exhaust sounds. Your car adapts to your driving style over time. Since most of you are still following the break in procedure, you won't get a lot of them if any. Once past the break in and you mash the throttle to 6k and back off, you will hear them and they will be there. After several days of that and seasoning the ecu to your driving style. They'll be there.
