Wheel offsets
I had to raise the fronts for the long drive, it usually sits lower
, as the p4s 285 are still losing traction (but maybe because I only have like 300 mi on them). I had bookmarked your thread for reference, so at least we have some definitive numbers with offsets for each setup on the sedan. Yours only has the KW HAS and no K-MAC rear, correct?
The fronts in the photo are 8.5" x 20 +38 offset. They needed to be pushed out so I got a 15mm hub centric spacer which is slightly too aggressive for me. I think 10 - 12 mm would be ideal. I don't have a photo with the spacers. Just about to get the KMac kit fitted to the front. The negative camber is eating the tyres and low speed steering is terrible. Hope this helps.
what the offsets of this wheels ?
ive found a set of alloys for sale
spec:
front 9j et +25
rear 10.5j et +35
will these fit my w205 C63s saloon ?
or will I need spacers of anything? Or if it’s just a plain old no. I’d like to stay away from modifying the car to accommodate these alloys.
thanks
spec:
front 9j et +25
rear 10.5j et +35
thanks
whats the exact fitment spec/suspension setup.
this is exactly what i’m after for my 15 ED1.
So it is safe to assume that a a front 8.5 x 19 +35 and a rear 9.5 X19 +40 will work on the sedan?
hey guys I’m changing my wheels and I want that aggressive muscular look of the A205 edition 1 I think some deep dish whees would do the trick I’m on stock suspension the roads are like dirt roads where I’m from hence why Im changing why wheels the front two are smashed and are in desperate need of a change
