C63/C63S AMG
Wheel offsets
Old May 29, 2018 | 08:04 PM
Amrinder's Avatar
2016 C63S
Wheel offsets
Hey im looking into getting some new wheels for my 2016 c63s sedan. Dont have too much of a budget so im looking into some rotary forged wheels possibly. Looking for some help as to whether a 9.5" rear with +40 offset would fit just fine? I believe OEM offset is +56 so hoping its not too aggressive. I'll probably being putting new rubber in the back aswell, most likely 285/35/19 so hoping it wont rub. Any help is appreciated, thanks.
Old May 29, 2018 | 09:16 PM
KJ's Avatar
KJ
2020 GLE 53 AMG
You should be fine with +40.
My winter wheels are +35 in the back, but since they're winter tires, they aren't 285 wide.
Still, never anywhere close to rubbing.
Old May 29, 2018 | 09:45 PM
Amrinder's Avatar
2016 C63S
Thank you! Very reassuring to hear you are running +35. Im assuming it would be a different story if i were to go with a wider wheel. Thank you for the response.
Old May 30, 2018 | 07:52 AM
crazy1eye's Avatar
2016 C63S, 2012 ML350
This is a 19x9.5 39 offset with 275/35/19 PS4S...
Old May 30, 2018 | 11:20 AM
KJ's Avatar
KJ
2020 GLE 53 AMG
Old May 31, 2018 | 03:38 PM
JaeJin Sohn's Avatar
2015 W205 C63S, 2015 328i xdrive, 2008 Mercedes R-Class 350, 2009 Hyundai Equus
I have a sedan with an 11in rims in the rear. Its 19x11 +55 with 305/30/19. The fronts are 19x9.5 +25 with 255/35/19. I would say for the rears, you shouldn't go any more aggressive than what I have unless you are going crazy with camber and lowering with coil-overs and adjustable lower and upper control arms. If you are looking into getting 9.5s in the rear, I recommend +36 ~ +42. You can look at my thread regarding 11s if you are interested.
Old May 31, 2018 | 05:02 PM
Amrinder's Avatar
2016 C63S
Thanks for all the replies guys and the images for visuals. I think ill be sticking with 8.5" and 9.5" rims in the front and rear, same as oem. Would I be able to go +25 in the front on an 8.5" wheel? The wheels im looking at right now are out of stock in +35 and they only have +25. I dont have a big budget so I wont be able to go forged =/
Old May 31, 2018 | 06:49 PM
With 8.5s in the front, you can get anything from +12 or above. +25 would definitely work
Old Jun 1, 2018 | 03:28 AM
Amrinder's Avatar
2016 C63S
Awesome thanks.
Old Jun 1, 2018 | 02:39 PM
KJ's Avatar
KJ
2020 GLE 53 AMG
If you go with cast wheels, make sure the shop you go to "guarantee's" the wheels will fit.
I had a shop that said a set of cast wheels would fit for my winter wheels and the drop lip (added for strength since the wheel was cast) was touching the brake caliper.
They gave me back my money and ordered another set (the ones in the picture) that fit perfectly.
Old Jun 1, 2018 | 08:25 PM
Amrinder's Avatar
2016 C63S
Looking at some flowform/rotary forged wheels as of now. Like forgestars or a local brand that makes flow form wheels. What brand are yours if you dont mind me asking?
Old Jun 1, 2018 | 08:33 PM
KJ's Avatar
KJ
2020 GLE 53 AMG
Braelin BR06
https://www.braelin.ca/productinfo.a...an+(w205)_s_pp
Old Jun 1, 2018 | 08:53 PM
Amrinder's Avatar
2016 C63S
Haha i had a feeling those were braelins, i couldnt quite make out hte center cap though, i take it youre canadian aswell? Im looking at the BR10 wheels from braelin, theyre flow formed apparently and i like that design.
Old Jun 2, 2018 | 12:32 AM
KJ's Avatar
KJ
2020 GLE 53 AMG
Yes, I'm from Toronto!
I got some matte black Mercedes caps for next winter, will have those on for next season!
Old Jun 6, 2018 | 02:06 PM
Amrinder's Avatar
2016 C63S
Hey just a quick question if someone can help me, if i were to go upto 10.5" in the rear, would a +45 offset work? Also I would be increasing the fronts to 9.5", would a +35 be better or a +40? Thanks.
Also, I spoke with a sales rep who was selling me the wheels and he claims they will not clear my calipers, now I am unsure if they will or will not. Any ideas why this could be?
Old Jun 6, 2018 | 02:41 PM
c63prob's Avatar
c63
I'm currently running 19x9 +30 and 19x10.5 +52 if that helps.
Old Jun 6, 2018 | 02:46 PM
Chino075's Avatar
c63s
Your rears will poke out with +45, if you are ok with that. For the fronts I have +35 and it is at it's limit. Don't think +40 would work as you are pushing it in and you will hit the knuckle. Just for reference I have the following setup on my sedan: 19x9.5 et +35 (265/35/19) front and 19x10.5 et +57 (285/35/19) w/ stock height.
Old Jun 6, 2018 | 03:01 PM
I have 19x9.5 with +25 in the fronts. Although I do have -3.2 degrees of camber in the front. 10.5 inch wide wheels with +45 offset probably won't work. I have 11 inch wide wheels with +55 (which is equivalent to 10.5 +49) with -2.6 degrees of camber. Unless you plan to lower your sedan with a coil-over and not springs and modify the control arms, 45 offset probably wont work.
Old Jun 7, 2018 | 01:45 AM
Amrinder's Avatar
2016 C63S
Thanks for the replies guys you all have been a huge help!
Old Jun 7, 2018 | 05:33 AM
RDO247's Avatar
C63S
Any pics of the front and rear?
Would your setup work if you were lowered?
Old Jun 7, 2018 | 10:47 AM
SuperNik's Avatar
W205 C63S AMG
I’m running 20x10 rear wheels at et38. Only had issues when running Michelin cup 2 285 tyres. 285 pss and ps4s fit with no issues.
Old Jun 7, 2018 | 11:11 AM
Chino075's Avatar
c63s
I'm not 100% sure if there will be issues if lowered or not. I don't plan to lower as NYC is the worst. Lets just say that it's paper thin on the inside. I'm going to get an alignment and hopefully get a clearer picture of how much I have or not have.
Old Jun 7, 2018 | 11:20 AM
you'll still have about 8~12mm of clearance in the inside, you can go wider or more aggressive if you want XD
Old Jun 7, 2018 | 11:21 AM
can I see what the fitment looks like with 20x10 +38?
Old Jun 7, 2018 | 11:27 AM
SuperNik's Avatar
W205 C63S AMG
